Updated to 2.7.2 and now the Y axis has issues
19 Nov 2015 14:49 #65505 by johnpaul2
I recently upgraded to ver 2.7.2 now my Y axis only doesn't respond correctly. Sometimes it will move back and forth about 1" only, sometimes the direction will only go 1 way no matter which way you jog it. Switched drivers y and X the driver and board work fine. Using the Axis, 3 axis mill with 8 wire steppers. Worked great for the last year until the upgrade. Only Y axis issue?
19 Nov 2015 14:54 #65506 by cncbasher
Replied by cncbasher on topic Updated to 2.7.2 and now the Y axis has issues
which version did you upgrade from ?
it could be tuning due to change of realtime
19 Nov 2015 17:31 #65524 by johnpaul2
Replied by johnpaul2 on topic Updated to 2.7.2 and now the Y axis has issues
Hello and thank you for the quick reply.
Original was 2.5.4 then upgraded to 2.6 then 2.7.2
19 Nov 2015 17:37 #65525 by johnpaul2
Kind of a newbie, is tuning only for servo's? I'm using steppers.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
19 Nov 2015 20:34 #65535 by Todd Zuercher
Replied by Todd Zuercher on topic Updated to 2.7.2 and now the Y axis has issues
Usually, but their are exceptions. He is probably referring to getting the proper settings for the step timing. I think he is saying that if your timings were close to the edge, subtle changes in timing from the upgrade could have pushed a marginal setting over the edge.
I have also seen steppers behave queerly, in a similar fashion when there is a bad wire or loose connection somewhere.
19 Nov 2015 20:58 #65537 by cncbasher
theirs a big difference from 2.5.4 , i'd suggest re-adjusting your timing and velocity speeds etc
yes Todd was correct in that i was refering to timing etc
could i suggest you try making a new configuration using stepconf
that should sort your problem
20 Nov 2015 00:16 #65550 by tommylight
Replied by tommylight on topic Updated to 2.7.2 and now the Y axis has issues
I have to agree that the issue might be timing since i had the same hiccup last year with the 2.7 pre .
Use stepconf or if you prefer edit the HAL file .
Tom
Time to create page: 0.129 seconds
