Install entire LinuxCNC precompiled package 2.5.4
- jstoquica
- Thank you received: 8
Is there some reason your not using the LiveCD to install Ubuntu 10.04 with LinuxCNC?
Yes, It is. I have new kinmeatics file (*.c) for a manipulator robot. Let see:
forum.linuxcnc.org/forum/10-advanced-con...b6-s2-simulation-pre
Then I need to compile the entire linuxcnc package in RIP mode to test, and then compile in the entire system.
Thanks.
- BigJohnT
- Thank you received: 994
gnipsel.com/files/linuxmint/mint17.3.txt
JT
- jstoquica
But I have my own configuration in the package source file, It is not a new installation. I compiled the entire linuxcnc package with:
cd src
.autogen.sh
./configure --prefix=/usr
make
sudo make setuid
make installBut after compile entire package, I can't run linuxcnc without root permissions. If I type "linuxcnc" in command line with normal user, system returns:
LINUXCNC - 2.5.4
Error in startup script: couldn't read directory "/usr/share/doc/linuxcnc/examples/sample-configs/": permission denied
while executing
"glob -nocomplain $dir/*"
(procedure "walktree" line 7)
invoked from within
"walktree $dir"
("foreach" body line 4)
invoked from within
"foreach dir $::configs_dir_list {
if {[info exists visited($dir)]} continue
set visited($dir) {}
walktree $dir
(file "/usr/lib/tcltk/linuxcnc/bin/pickconfig.tcl" line 325)Thanks.
- BigJohnT
JT
- cncnoob1979
- Thank you received: 75
Not sure what the issue was that caused this. But I tried multiple times and that is how I got mine working without the headache
- BigJohnT
I had the same issue as you with Mint 17.3, what I did was go to users and make myself an admin user. This cleared it up. I couldn't find another way to "fix" my issue. I still have to use an su password for anything admin related.
I wonder what you did different than me, I've never had to play with the user. I've installed LinuxMint 17.3 with Mate desktop about 20 times to be sure I had it right. I use the instructions here
JT
- cncnoob1979
I used your directions to install Linux mint with
Thanks!
- jstoquica
I made a mistake. I deleted "Makefile" from /usr/src/linux-headers-2.6.32-122-rtai, and when I try to compile linuxcnc from source with any modification of my config, It generates error!
make[1]: Entering directory `/usr/src/linux-headers-2.6.32-122-rtai'
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-122-rtai'
make[1]: *** No rule to make target `modules'. Stop.
make: *** [modules] Error 2
I think with compiling linuxcnc from source the linuxheaders files will recover, but nothing ....... How can I fix that?
Thanks.
So, before panicing, do the ./configure and ./autogen.sh steps. (I ave managed to foget which order they come in)
- jstoquica
I did it, a lot of times:
./autogen.sh
make clean
make
make installBut It generates the same error. It didn't re-create the Makefile....
Thanks....
