LinuxCNC 2.7.3 Latency-Test strange results
12 Dec 2015 15:38 #66872 by Paciente8159
LinuxCNC 2.7.3 Latency-Test strange results was created by Paciente8159
Hi there,
I'm trying to install a bare minimum linuxcnc 2.7.3 on an old PC (about 17 years old Celeron 433Mhz+512Mb Ram) but i'm running into some problems. When I run latency-test I get some strange results. The base thread (25us) is running as low as 200ns instead of the expected 25000ns. I'm guessing RTAI is not working properly, but it's wild guess.
I'm not a linux expert so I'm hoping you guys can help me.
This is what I did:
1. Installed debian 8.2 netinst without any extras
2. added the linuxcnc repository to sources.list and updated aptitude
3.Installed the linux-image-3.16.0-9-rtai-686-pae and rebooted to the rtai kernel
4.Installed lightdm and lxde-core and rebooted
5.In lxde environment installed the linuxcnc-uspace
Any thoughts?
Thanks.
12 Dec 2015 17:34 #66878 by PCW
You should use standard LinuxCNC with a RTAI kernel not the uspace version of LinuxCNC
Also a 433 Mhz Celeron is likely to work better with an older OS, say Ubuntu Hardy (8.04)
so downloading the linuxcnc/ubuntu 8.04 live CD image is (IMHO) more likely to lead to a usable system
12 Dec 2015 17:55 #66880 by Paciente8159
Replied by Paciente8159 on topic LinuxCNC 2.7.3 Latency-Test strange results
Thanks for the reply.
I thought I should use RTAI version but the repository for linuxCNC 2.7-rtai is empty.
I can only install linuxCNC using the uspace
I currently using the ubuntu 8.04 version (with linuxCNC 2.5.3), but by installing this "minimal" debian, I feel the PC is alot more "responsive". Don't know if the results of the latency test will show corroborate that.
12 Dec 2015 18:15 #66881 by seb_kuzminsky
Replied by seb_kuzminsky on topic LinuxCNC 2.7.3 Latency-Test strange results
Hi there, thanks for trying the new 3.16 RTAI kernel. We do not yet have linuxcnc debian packages built for this new kernel, it's in an early experimental stage still. If you want to try LinuxCNC on this kernel, you'll have to build it from source.
The following user(s) said Thank You: Paciente8159
12 Dec 2015 18:26 - 12 Dec 2015 19:30 #66883 by Paciente8159
Thanks!!
Ok.
I'll make one final try with Debian Wheezy "minimalistic" instalation and the RTAI kernel for it available at machinekit .
I've tried the Preempt RT version of Wheezy but when I run latency test the PC freezes completely.
EDIT:Actually I didn't realized that the linuxcnc repository for wheezy already add a rtai kernel. :P I'll try that instead.
Last edit: 12 Dec 2015 19:30 by Paciente8159.
  • Moderator
  • Moderator
14 Dec 2015 02:09 #66940 by tommylight
Replied by tommylight on topic LinuxCNC 2.7.3 Latency-Test strange results
Had 8.04 running on a PII 400 and a desktop celeron 500 quite usably. Haven't used them in a while so i did not try wheezy.
I also have a PI 233 somewhere in the shop so i can give that a try if i can find some spare time (and some heat, it is -7 degree Celsius here right now so i need to find a reason to start the heating), but i doubt it would be anywhere near usable.
Regards,
Tom
14 Dec 2015 11:07 #66949 by Paciente8159
-7º C now Thats cold. I have 19º and it's almost winter. lolol
I've managed to get the "minimum" wheezy+linuxcnc running on my PC. Although the OS is more responsive and feels more fast, the latency-test results are worse(about 40~50% more jitter) and linuxCNC crashes...
In ubuntu 8.04 - base thread jitter is about 19000ns
In wheezy - base thread jitter is about 30000ns
If you decide to try I did this:
Installed the netinst version without any options.
Installed the rtai kernel from linuxcnc repository
Installed lightdm and lxde-core (JWM is even lighter but it's too hardcore for me! :P )
Installed linuxcnc
NOTE: lapic is not active so I had to follow the instructions in linuxcnc doc to activate it on grub
I used StepConfig fine.
When trying to run linuxCNC it crashed.
I gave up on it (given the latency results) and returned to 8.04. I'll probably go has it is for now.
Time to create page: 0.103 seconds
