Why was debian chosen over ubuntu?
- tjmarch
- Thank you received: 22
I have made a ISO to install Linuxcnc software it contains Deb files that I created and packages downloaded from Canonical IP to be used on a pre-installed operating system of Ubuntu 14.04 or Linux Mint 17. The install process of Linuxcnc only will take about 5 minutes. The ISO image must be mounted then a script file is run to install the needed packages that are contained in the image. If any packages that are still needed for the install due to flavor differences will download from Canonical Trusty repo. I am requesting permission to make this ISO public and for no personal gain on the Linuxcnc.org web site. ISO image will be free of charge and no gain for Linuxcnc.org.
If I have over stepped my bounds please let me know
Tim March
- lincamx
- Thank you received: 4
For the most part all distro's work the same, If you know one it should not be hard to pickup on another with the help of the distro forum and google.
Good luck and have fun.
- Thank you received: 2181
little things like input focus don't work correctly in Wheezy and I relied on some libraries (eg onboard keyboard)
that is not in Wheezy. Like them or not Ubuntu 's package was well polished and rounded.
And I am using my computer for more then just cnc so that was important to me.
And anything that makes a casual user's life easier is a good thing for linuxcnc
Chris M
- tjmarch
forum.linuxcnc.org/forum/9-installing-li...-8-mint-lmde-2#68341
Tim
Chris M
- tjmarch
I wonder what response you would get from MINT as they must jump through the same hoops to use Ubuntu base.
I think Mint must have a special agreement with Canonical, because they still use Trusty repository.
Tim
- tjmarch
You may want to take a look at this it is not a ISO but you have to compile but it works, very easy to follow readme instructions
forum.linuxcnc.org/forum/9-installing-li...mint-with-rtai#65402
Enjoy
Tim March
