Updating to latest version
03 Jan 2016 21:07 #67775 by TarHeelTom
Updating to latest version was created by TarHeelTom
I'm running 2.4.6 currently, and can't get the mill and computer to talk to each other.
Downloaded the latest version and want to build a live install (Do we still do that?)
Currently my DVD writer seems to work fine on CDs, but not on DVDs. So suppose I need to get a new reader/writer and install in.
In the interim, I'd like to make a live USB memory stick, but can't seem to find instructions to do so. Any help?
Tom
04 Jan 2016 14:07 #67825 by andypugh
Replied by andypugh on topic Updating to latest version
[quote="TarHeelTom" post=67775[In the interim, I'd like to make a live USB memory stick, but can't seem to find instructions to do so. Any help?[/quote]
linuxcnc.org/docs/2.7/html/getting-start...to_a_bootable_device
04 Jan 2016 22:03 #67881 by TarHeelTom
Replied by TarHeelTom on topic Updating to latest version
I'm going to go try this on my Linux machine now.
But although the instructions are there for making a DVD on a Windows machine, there seem to be no instructions for creating the memory stick on a Windows machine. Any chance of someone adding this one item?
Tom
05 Jan 2016 00:27 #67884 by TarHeelTom
Trying to generate a live memory stick. Went through the "dmesg" info, and it appears that my memory stick is showing up as "sda". Am I reading this right?
But when I finally got the .iso moved into the home directory and asked for the "dd", I got a "Permission denied" message.
What am I doing wrong?
Here's part of the terminal output:
[ 363.344771] usb 1-1.2: USB disconnect, address 4
[ 374.289600] usb 1-1.2: new high speed USB device using ehci_hcd and address 5
[ 374.386509] usb 1-1.2: configuration #1 chosen from 1 choice
[ 374.386637] scsi5 : SCSI emulation for USB Mass Storage devices
[ 374.386726] usb-storage: device found at 5
[ 374.386727] usb-storage: waiting for device to settle before scanning
[ 379.384219] usb-storage: device scan complete
[ 379.476810] scsi 5:0:0:0: Direct-Access Kingston DataTraveler G3 PMAP PQ: 0 ANSI: 0 CCS
[ 379.477178] sd 5:0:0:0: Attached scsi generic sg0 type 0
[ 379.895281] sd 5:0:0:0: [sda] 7669824 512-byte logical blocks: (3.92 GB/3.65 GiB)
[ 379.895777] sd 5:0:0:0: [sda] Write Protect is off
[ 379.895787] sd 5:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 379.895789] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 379.898147] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 379.898152] sda: sda1
[ 379.913139] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 379.913141] sd 5:0:0:0: [sda] Attached SCSI removable disk
tom@tom-server:~$ dd if=linuxcnc-2.7-wheezy.iso of=/dev/sda
dd: opening `/dev/sda': Permission denied
05 Jan 2016 00:35 #67885 by tommylight
Replied by tommylight on topic Updating to latest version
You need to add sudo before any command that needs root permissions, in your case
instead of
you do
tom@tom-server:~$ sudo dd if=linuxcnc-2.7-wheezy.iso of=/dev/sda
nothing more, and you have a working bootable usb stick in 5 minutes (or thereabouts).
Regards,
Tom, the other!!! :)
05 Jan 2016 00:47 #67887 by TarHeelTom
Thanks. Nice to get a quick reply like that. I'm also looking at installing a tinyG, and it takes me a day or two to get an answer on their forum.
Wish I used Linux more often. I maintain several Linux based web sites, so remember the basics, but have never had to use "sudo" or many of those other commands there. In fact, they are probably blocked by the admin.
Big change being my own admin at home.
05 Jan 2016 01:10 #67888 by tommylight
Glad to help, and this is my usual time here on the forum (currently 2AM here).
I use linux exclusively for nearly 10 years now, had to use windoze a lot since i owned computer shops, and i am positive 90% of my stress was from having to use windoze (daily over 20 installs and virus removal and data recovery and......oh nevermind, never again,).
Been using ubuntu till some months ago, namely the 10.04 since newer versions vent to c@#$#@, using Mint on my main laptop last 2 years and now switched all my systems to Mint or Debian wheezy.
Sleeping time, have to build a cnc engraver tomorrow, only 5 days to finish and sell it.
Regrds,
Tom
Time to create page: 0.094 seconds
