RTAI Terminal?
- spinnaker
16 Jan 2016 22:36 - 16 Jan 2016 23:03 #68540
by spinnaker
RTAI Terminal? was created by spinnaker
I have been having a devil of a time getting Linux and Linux CNC to install. I first tries the Debian ISO install disk but it just would not play well with my dual boot Windows 10 system.
So first I tried Unbuntu version 14. But when I got to the step 8 of the Unbuntu instructions and have some confusion.
The instructions say to boot to the terminal and type uname -r and I should get 3.4-9-rtai-686-pae but I am getting 3.13.0-74-generic.
But the instructions say "make sure you boot into the rtai kernel". And I am guessing that is where I am going wrong.
How do I boot to the RTAI kernal? Should it be in my Grub menu? If so I am not seeing that option.
Please give details as I am brand new to Linus and Linus CNC.
P.S. I am seeing an RTAI folder under my usr folder.
P.S. I am using Easy BCD in Windows 10 to set the dual boot options. Could I be overwriting the grub configuration?
Last edit: 16 Jan 2016 23:03 by spinnaker.
- spinnaker
16 Jan 2016 23:24 #68544
by spinnaker
Replied by spinnaker on topic RTAI Terminal?
I think I figured it out. I needed to select previous versions of linux from grub. Then select the rtai kernel. How do I load that by default?
- Thank you received: 1476
17 Jan 2016 00:25 #68546
Replied by Todd Zuercher on topic RTAI Terminal?
for a relatively simple way to reconfigure Grub is to install and use Grub-customizer, But if your problem is that something else is messing with your settings from the outside???
The following user(s) said Thank You: spinnaker
- spinnaker
17 Jan 2016 01:35 #68549
by spinnaker
How do I do that? Remember I am a newbie.
I did find this
www.calazan.com/how-to-set-an-older-kern...bootup-ubuntu-12-04/
Grub does position itself to Previous Versions but that is it. It does not pick the rtai kernel.
My settings are
GRUB_DEFAULT=2>2
My Previous version item is the 3rd item down and the rtai kernel is the 3rd item down on the Previous version menu.
I did find this
My settings are
GRUB_DEFAULT=2>2
- spinnaker
17 Jan 2016 01:43 #68550
by spinnaker
Found it and installed. I can't believe it was that easy after all I went through today
- spinnaker
17 Jan 2016 01:50 #68552
by spinnaker
Excellent tip! Thanks! Got it all working perfectly now!
Time to create page: 0.526 seconds
