Where is the calculator in linuxcnc 2.7.3?
- Davenc
18 Jan 2016 18:14 #68705
by Davenc
Where is the calculator in linuxcnc 2.7.3? was created by Davenc
I've looked through every pull down menu available and there is no calculator to be found? I can't believe that there wasn't a calculator included in the build so where would that little sucker be hiding?
Thanks,
Dave
Thanks,
Dave
- BigJohnT
- Thank you received: 994
18 Jan 2016 19:23 #68713
by BigJohnT
Replied by BigJohnT on topic Where is the calculator in linuxcnc 2.7.3?
LinuxCNC does not have a calculator. I assume you meant the OS your using like Debian Wheezy.
JT
JT
18 Jan 2016 19:30 #68714
Slightly bizarrely there actually isn't a calculator in the default Debian install. (other than the command-line one)
If you go to the Synaptic package manager (System->Synaptic Package Manager) then you can install one easily.
"gcalctool" is probably the one you were expecting to find.
Replied by andypugh on topic Where is the calculator in linuxcnc 2.7.3?
Time to create page: 0.390 seconds
