Latest version of LinuxCNC for Ubuntu 10.04?
- ehrichweiss
12 Mar 2016 02:53 #71474
by ehrichweiss
Latest version of LinuxCNC for Ubuntu 10.04? was created by ehrichweiss
(sorry if this is going through twice, I don't see it in the subject list and there wasn't anything about it being in a moderation queue or the like)
What I've tried:
Latest ISO w/2.7.4 works but too much latency, so I tried
older ISO w/Ubuntu 8.04. Much faster but won't import my Mach3 settings(and I'm guessing it won't import my 2.7.4 settings either since it's a newer version)
So I tried just updating LinuxCNC but Ubuntu 8.04 only supports Python 2.5/2.6 and it needs 2.7(and there are a LOT of libraries that can't be easily upgraded).
That's when I decided to install Ubuntu 10.04 in hopes I could get the libraries in a PPA or the like but now despite everything I've done when I configure it keeps complaining that
"configure: error: boost::python is required to build LinuxCNC"
except I have libboost-python-dev installed. It's only 1.4.2 but it's indeed installed.
Any ideas what I might be doing wrong? I'm normally a Gentoo user but compiling the RTAI sources proved a lot harder than I expected since it seems the instructions for EMC2 on Gentoo are waaay outdated. I use Ubuntu a little but am no guru.
Any help appreciated.
What I've tried:
- BigJohnT
- Thank you received: 994
13 Mar 2016 13:33 #71559
by BigJohnT
When you post the message there is a big green box that pops up noting your success and warning you that the message will not show up until it has been approved.
JT
Replied by BigJohnT on topic Latest version of LinuxCNC for Ubuntu 10.04?
JT
The following user(s) said Thank You: ehrichweiss
13 Mar 2016 23:03 - 13 Mar 2016 23:04 #71593
Unfortunately the Moderators have to remember to check that a post needs approval.
I don't actually approve of this setting. I prefer the occasional spam message to new users not getting timely help.
Replied by andypugh on topic Latest version of LinuxCNC for Ubuntu 10.04?
Last edit: 13 Mar 2016 23:04 by andypugh.
- BigJohnT
13 Mar 2016 23:30 #71596
by BigJohnT
After some research I have changed to two emails that are sent out to be more pedantic and repetitious about the way it works. If you experienced what I did a while back with hundreds of spammers a day you might have a different view on this.
JT
JT
- ehrichweiss
14 Mar 2016 02:22 - 14 Mar 2016 02:26 #71599
by ehrichweiss
Replied by ehrichweiss on topic Latest version of LinuxCNC for Ubuntu 10.04?
Yeah, I must have missed that the first time around. The second time I saw it but figured it made zero sense to try to send an "oops" message. I'm cool with moderation. I've had to deal with an equal amount of spam over the years. Not an easy job.
I'm assuming there is a point at which people are taken off moderation?
For the record, after importing the 2.7 settings into 2.5, it said they were fine but then when I started 2.5 with those settings it complained about some extra settings flags(not sure which as I didn't write them down) and I think it said it removed them), I restarted it and everything works like before. Now I'm not getting any realtime errors so that's a huge plus.
Last edit: 14 Mar 2016 02:26 by ehrichweiss.
- BigJohnT
15 Mar 2016 21:17 #71698
by BigJohnT
Only the first post is moderated plus the CAPTCIA game, the next two posts you get to play the CAPTCIA game, after that we figure you not part of the collective.
JT
JT
Time to create page: 0.075 seconds
