Running linuxcnc on a Vnc connection
- jamby
- Thank you received: 6
19 Mar 2016 03:14 #71888
by jamby
Running linuxcnc on a Vnc connection was created by jamby
Hi
I have lcnc installed on a computer in the garage and its setup and running fine on my 3 axis mill. But now I want to be able to run debug my gcode in the preview window of lcnc from my computer in the house. For that I installed tightvnc on the lcnc computer and logged into it frrom the house. However when I attempt to start lcnc axis sim I get a Linux CNC Errors message.
It appears the error is about the XError of failed request: BadWindow (invalid Window parameter) perhaps because of vnc using :1 instead of the normal operation in :0 window.
Any help appreciated
Jim
Here is the pertinent part of the message the zip file below is the complete message:
Debug file information:
X Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 3 (X_GetWindowAttributes)
Resource id in failed request: 0xffffffff
Serial number of failed request: 451
Current serial number in output stream: 452
9557
PID TTY STAT TIME COMMAND
9623
Stopping realtime threads
Unloading hal components
Jim
9557
9623
- geoffs
19 Mar 2016 10:48 #71891
by geoffs
Replied by geoffs on topic Running linuxcnc on a Vnc connection
What version of Linux (Debian/Ubuntu_ are you running?
I'm running Debian Wheezy and VNC without any issues.
Are you viewing this with Windows or Linux VNCviewer?
- jamby
19 Mar 2016 13:19 #71894
by jamby
Replied by jamby on topic Running linuxcnc on a Vnc connection
geoffs
Its lcnc 2.7.4 from the linuxcnc distro Linux mill 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
Viewing with tigervnc on centos the connection works fine and the desktop works otherwise.
Jim
Jim
29 Mar 2016 11:44 #72313
Replied by andypugh on topic Running linuxcnc on a Vnc connection
You don't need VNC.
I run LinuxCNC on my machines through a remote X session. The LinuxCNC GUI is displayed on my Mac as just another app.
On the Mac:
ssh -Y andypugh@mill
linuxcnc
Something related that I often do, if I am already running the machine with a local GUI.
halcmd -kf
loadusr halmeter pin motion.program-line
That creates a tiny window on the Mac that shows me how the remote job is going.
Rather usefully it displays "0" if the program has finished or if a tool change is needed.
On the Mac:
linuxcnc
halcmd -kf
- jamby
29 Mar 2016 14:55 #72328
by jamby
andy
That worked, actually both worked but I have a program paused on the mill right now so I didn't start up linuxcnc as it appeared to want to restart the session. I'll try it after I've finished the part.
I just ran into another problem maybe you know the answer to. Is there a way to get linuxcnc to reload the .ini file without restarting linuxcnc? I need to adjust the compensation amount on Z axis between coming to a plane from above or below its coming up short or long now as the scallop hight is doubled up once it comes to the plane from both directions.
Jim
Jim
29 Mar 2016 16:48 #72342
No. The INI data (and the HAL file) are only read once at startup.
But, your compensation file can be bidirectional:
linuxcnc.org/docs/2.7/html/config/ini-co...s__lt_num_gt_section
The following user(s) said Thank You: jamby
- jamby
29 Mar 2016 20:10 #72349
by jamby
Andy
I thought that was the answer so I made my changes and restarted linuxcnc. I put a 0.01 backlash value into my Z axis and wrote a little gcode to come back to the same plane from both directions and stop. Now comes back to zero from both directions. Now I have to see how that will effect the depth setting when I do a .01 deep finish pass over my existing contour.
Oh yeah before shutting linuxcnc down I moved to a know position then did the restart and reset all axis to the original location.
Jim
Jim
- lorenzn
04 Jun 2019 23:31 #135877
by lorenzn
Replied by lorenzn on topic Running linuxcnc on a Vnc connection
I use:
Sometimes VNC is also convenient. I believe a normal vncserver does not work due to OpenGL.
For vnc I do (on the cnc machine):
This is x0vncserver from TigerVNC. tigervnc.org/doc/x0vncserver.html
First define your password with vncpasswd. Then connect with:
ssh -Y mymachine mycncstartscriptSometimes VNC is also convenient. I believe a normal vncserver does not work due to OpenGL.
x0vncserver -display :0 -rfbauth ~/.vnc/passwd &This is x0vncserver from TigerVNC. tigervnc.org/doc/x0vncserver.html
vncviewer thecncmachine:0Please Log in or Create an account to join the conversation.
- Thank you received: 7488
04 Jun 2019 23:56 #135883
Replied by tommylight on topic Running linuxcnc on a Vnc connection
VNC did work several years back when I was using a Nokia N900 to control my machines running Linuxcnc on Ubuntu 8.04 or 10.04.
Have not used it since, but I do not think opengl will be an issue as it is running on it's own machine and sending pictures to vnc viewer.
Time to create page: 0.132 seconds
