Install LinuxCNC to USB DiskOnKey, Ubuntu Gnome
13 May 2016 02:29 #74581 by webmanoffesto
I'm learning CNC and I want to install LinuxCNC to a USB DiskOnKey. I'm running Ubuntu Gnome on my laptop. (I understand that I cannot simply install LinuxCNC onto my Ubuntu Gnome system.)
I used DiskImageWriter to write the image to a DiskOnKey. But then it wouldn't mount and would systems didn't see it on reboot.
Just now I used
> pmount sdb1
So now I can open the drive and I see that it seems to have the whole Wheezy LinuxCNC system in there on a partition.
Using "Disks" I can get to "Edit Mount Options"
Under "Automatic Mount Options - ON"
- "Mount at Startup" is not checked.
- "Show in User Interface" is checked.
So how do I get this working?
17 May 2016 14:21 #74791 by andypugh
dd ought to create a bootable LinuxCNC USB Key.
You could try using that instead of the software that you did use.
linuxcnc.org/docs/2.7/html/getting-start...to_a_bootable_device
Time to create page: 0.167 seconds
