Parallel Port Setup
- jinnicky
21 Jun 2016 15:54 #76350
by jinnicky
Parallel Port Setup was created by jinnicky
I'm just getting started with LinuxCNC to run a CNCEST 3040T.
My first question is about the parallel port. The BIOS has 4 options:
Curiously enough, the BIOS shows 2 parallel ports even though there is only one connector and no header on the board for a second. The first one is set to 0x3F8/IRQ4 and I turned the second one off.
- Normal
- BiDirectional
- ECP and EPP 1.9
- ECP and EPP 1.7
21 Jun 2016 16:12 #76351
Replied by andypugh on topic Parallel Port Setup
They should all work.
You don't need EPP but some ports have a higher drive capacity in EPP, so there is no harm in using that.
Time to create page: 0.092 seconds
