execv(clasicladder): No such file or directory
- schmidtmotorworks
- Thank you received: 6
21 Jul 2016 01:49 - 21 Jul 2016 01:50 #77752
by schmidtmotorworks
Replied by schmidtmotorworks on topic execv(clasicladder): No such file or directory
Thanks for finding that!
I will look into the graphics issue.
I had an interesting problem related to graphics in the beginning with Linux thinking there were two monitors so I made an edit to a startup file somewhere to specify the monitors. I hope it isn't related to that, I am so relieved to have that working.
Before I made the edit, the screen only showed the background because it was recognized as the 2nd screen.
Last edit: 21 Jul 2016 01:50 by schmidtmotorworks.
- Thank you received: 2181
21 Jul 2016 05:14 #77753
according to the error message...you _still_ haven't fixed the spelling of classicladder on line 95
Chris M
Replied by cmorley on topic execv(clasicladder): No such file or directory
Yes I just finished that (there were about 100 of them), thanks a lot, that is great progress.
So far I can't find anything useful about the classic ladder message.
Chris M
- schmidtmotorworks
21 Jul 2016 05:23 #77754
cmorley,
Has the correct spelling of classicladder changed?
I didn't change that in the hal file; it is the same way it was in the previous install.
I don't know what to change.
21 Jul 2016 06:26 #77756
note classicladder in your HAL file line 95 has only one s in it. classicladder has two s in it.
that would be why it cant find the file.
Try spelling it properly and see if it gets past that error.
No the name has never changed.
Chris M
Chris M
The following user(s) said Thank You: schmidtmotorworks
- schmidtmotorworks
21 Jul 2016 08:11 #77759
Thanks for noticing that, I hope I can get back to it but I am afraid that I may have made a mistake that I might not be able to recover from.
While trying to follow the instructions to possibly resolve a graphics issue I made a mess of xorg.conf.
I edited it to use the vese driver then restarted the computer.
Next is starts in terminal mode.
So I navigate to xorg.conf and try to edit it with vi.
I did something wrong, now it is named xorg.conf~
Now when I restart it, it never goes to terminal mode at all. just black screen forever.
So I start with F2 recovery mode that gets me to a strange linux background with no usable tools
I try restarting with F2 again, every time seems to get a different result
This time it gets to a menu that gets me to a terminal mode with very big text.
Now I can get to the folder again and try vi.
there is no xorg.conf, but the xorg.conf~ is still there
I have tried to recover it and I can get an option to open a version in vi that looks like what I want to go back to.
The problem now is, I have not been able to write it.
Every combination I try with different combinations of login, owner returns "read only file system"
Every attempt I make to chmod also returns "read only file system" (including using sudo.
I am not expert at LINUX so I am looking up the commands on Google, every time I think I may have found the key I find the same problem "read only file system".
Is there any way I can get past this, or have I bricked the drive?
- schmidtmotorworks
21 Jul 2016 16:14 - 21 Jul 2016 16:16 #77785
I found a way to fix the xorg.conf file issue (I think)
I connected the problem drive and a working linux drive to a PC
Booted to the working linux drive
Then edited the the xorg.conf files in the problem linux drive.
I find myself with a strange situation now.
When I start the drive it comes to a login page (it didn't do that before)
When I log in it takes me to a desktop with no icons
It has a sort of menu at the upper left "activities" but it is useless.
There are controls to adjust volume and turn off the computer, I can't seem to do anything else.
It seems that I have made a mess of this.
Last edit: 21 Jul 2016 16:16 by schmidtmotorworks.
- schmidtmotorworks
22 Jul 2016 15:39 - 22 Jul 2016 15:40 #77843
For now I have decided to postpone going to Mint, and went back to my previous version.
I checked the hal file and found that it does have classic ladder spelled incorrectly.
It is interesting that no problem messages are raised by this.
If I fix the spelling, it causes a second dialog that looks like it is used to develop the ladder code.
This is good to know because i have been wanting to learn classic ladder to get the tool-changer working.
Another interesting thing that I found in regards to the classic ladder spelling; an error message will be raised for it when certain other problems are found. I discovered this when I still had the incorrect spelling and was trying to connect a 4th and 5th axis.
For now, i am going to work on getting the 4th and 5th axis working and take another try at Mint later,
Thanks to everyone that helped on the problem.
Last edit: 22 Jul 2016 15:40 by schmidtmotorworks.
