Good bye to Ubuntu 10.04
9 years 11 months ago #82610 by bkt
Replied by bkt on topic Good bye to Ubuntu 10.04
Actually Ubuntu 14.04 (and the derivative Mint 17) work fine with LinuxCNC,
Ubuntu 16.04 (and Mint 18) also work but have a few minor issues (mostly fixed in master)
ohh well done ... so I can use your (@PCW) 6i25 or E7i76 on 14.04 using the master version ?? and with that kernel rtai ??
Regards
giorgio
9 years 11 months ago #82611 by PCW
Replied by PCW on topic Good bye to Ubuntu 10.04
Any of Mesas PCI/PCIE/Ethernet cards work fine with 2.7.x or master on 14.04
I would not bother with RTAI unless you are using a parallel port and software stepping
Its much easier to get modern hardware support via a Preempt-RT kernel
(though if you have older hardware I would stay with a 4.1.xx or lower kernel version)
9 years 11 months ago #82620 by bkt
sorry but my ultimate reading is these:
precise install
& these ..
14.04 patch
what did I miss? because you tell me that I can Please install with a preempt-rt ... it is available in the repo for Ubuntu 4.14? .. For work in real time & for sim? Master (JA completed) and 2.7.7 ??
Sorry I read nothing about !! can you send me some links about??
Regards
giorgio
9 years 11 months ago - 9 years 11 months ago #82624 by PCW
I just installed a standard ubuntu 14.04 (same with Mint 17 and Mint 18)
then compiled/installed a Preempt-RT kernel and compiled LinuxCNC from source
Last edit: 9 years 11 months ago by PCW.
9 years 11 months ago #82625 by jtc
Replied by jtc on topic Good bye to Ubuntu 10.04
PCW wrote: I just installed a standard ubuntu 14.04 (same with Mint 17 and Mint 18)
its the same process to install on ubuntu 16?
9 years 11 months ago #82627 by PCW
Yes, same process. there are some minor issues with 16.04/Mint18
There's a setuid issue with 16.04 and Mint18 that causes trouble
with Ethernet cards ( something related to not getting root permissions to launch iptables )
I think this is only fixed in master
There's also a python numpy fix needed for 16.04/Mint18 but this has been added to 2.7.8
(but not added to master yet AFAIK)
Also for some reason Axis starts up minimized in Mint18. probably a window manager issue
The following user(s) said Thank You: jtc
Time to create page: 0.168 seconds
