"LinuxCNC terminated with an error" on 2.7.6 upgra
- Transistor
10 Aug 2016 22:01 - 12 Aug 2016 21:37 #78587
by Transistor
"LinuxCNC terminated with an error" on 2.7.6 upgra was created by Transistor
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.6
Machine configuration directory is '/home/cnc1/linuxcnc/configs/ia-mill-linuxcnc'
Machine configuration file is 'ia-mill-linuxcnc.ini'
INIFILE=/home/cnc1/linuxcnc/configs/ia-mill-linuxcnc/ia-mill-linuxcnc.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./ia-mill-linuxcnc.hal
Killing task linuxcncsvr, PID=1305
Debug file information:
./ia-mill-linuxcnc.hal:6: Can't find module 'probe_parport' in /usr/realtime-2.6.32-122-rtai/modules/linuxcnc
1305
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.6
TASK=milltask
HALUI=
DISPLAY=axis
1305
Last edit: 12 Aug 2016 21:37 by Transistor. Reason: Edited down to relevant error listing.
- Thank you received: 1480
10 Aug 2016 23:00 #78589
Replied by Todd Zuercher on topic "LinuxCNC terminated with an error" on 2.7.6 upgra
The component probe_parport is depreciated and has been removed from Linuxcnc 2.7 onward.
linuxcnc.org/docs/html/getting-started/u....html#_parallel_port
Simply comment out or delete that line from your hal file.
The following user(s) said Thank You: Transistor
Time to create page: 0.336 seconds
