NGCGUI - metric mode? [Solved]
- Transistor
13 Aug 2016 14:24 - 14 Aug 2016 14:16 #78710
by Transistor
NGCGUI - metric mode? [Solved] was created by Transistor
I'm working my way through my NGCGUI problems. The latest is that I find that it defaults to quaint inch measurements.
Is there a quick way to fix this? The answer is probably buried in this 33 page thread but l can't find it.
Last edit: 14 Aug 2016 14:16 by Transistor.
- Rick G
- Thank you received: 114
13 Aug 2016 18:27 - 13 Aug 2016 23:03 #78723
by Rick G
Replied by Rick G on topic NGCGUI - metric mode?
quaint ?
linuxcnc.org/docs/html/gui/ngcgui.htmlSome of the subs examples are metric. In most case if you use a preamble and then just edit the sub for the unit you want.
Rick G
NGCGUI_PREAMBLE = in_std.ngc - the preamble file to be added in front of the subroutines. When concatenating several common subroutine invocations, this preamble is only added once. For mm-based machines, use mm_std.ngcRick G
Last edit: 13 Aug 2016 23:03 by Rick G.
- Transistor
14 Aug 2016 09:30 - 14 Aug 2016 09:30 #78735
by Transistor
Replied by Transistor on topic NGCGUI - metric mode? [Solved]
That's what I needed.
Thank you.
Thank you.
Last edit: 14 Aug 2016 09:30 by Transistor.
Time to create page: 0.075 seconds
