Update from 2.7.0 to 2.7.6
17 Aug 2016 06:33 #78918 by terkaa
Update from 2.7.0 to 2.7.6 was created by terkaa
I noticed that I have 2.7.0 installed. And I would like to update to 2.7.6. My question is how to proceed? I just accept suggested updates from top menu bar? Also I have modified few HAL components and added couple will this update overwrite modified ones or remove added ones? Main reason for this update is that I have Mesa cards and VFD so I would like to avoid communication errors.
Tero
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
17 Aug 2016 11:36 #78924 by Todd Zuercher
Replied by Todd Zuercher on topic Update from 2.7.0 to 2.7.6
If you have an internet connection, yes, just let the updater do it's thing. No changes will be made to your configuration files. But if you have modified standard Hal components or other standard Linuxcnc files, those will be over written. It is often a good idea to save your modified files with a new name when modifying them to prevent these problems.
The following user(s) said Thank You: terkaa
19 Aug 2016 11:50 #79047 by terkaa
Replied by terkaa on topic Update from 2.7.0 to 2.7.6
Update succesful. I recompiled custom HAL components after update and everything seems to work, Now I am with 2.7.6
Tero
19 Aug 2016 21:31 #79104 by BosniaCNC
Replied by BosniaCNC on topic Update from 2.7.0 to 2.7.6
Does the end of these upgrades or it goes on forever?
  • Moderator
  • Moderator
20 Aug 2016 01:12 #79110 by tommylight
Replied by tommylight on topic Update from 2.7.0 to 2.7.6
It will go on and on and........on !
I use it for a long time and i have seen and noticed the changes, mainly the new trajectory planner and now on the latest iteration the axis<>joints separation and the new possibilities with it, and the overall speed of code execution now are magnificent. Until yesterday i was using 2.7.4 and it was great, but after installing the 2.8-pre, things got a lot faster and smoother.
So more updates, please ! :cheer:
20 Aug 2016 06:32 #79117 by terkaa
If you mean that does installer finish its work. Here it did. Loading partition went to about 140% and after that installation part started and finished without errors.
Tero
20 Aug 2016 21:30 #79177 by BosniaCNC
So they worked with Mach3 but eventually paid licenses are not valid.
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
21 Aug 2016 01:10 #79190 by Todd Zuercher
Linuxcnc is FREE, you will never be charged for licenses or updates.
  • auto-mation-assist
  • auto-mation-assist's Avatar
  • Platinum Member
  • Platinum Member
22 Aug 2016 03:36 #79231 by auto-mation-assist
Replied by auto-mation-assist on topic Update from 2.7.0 to 2.7.6
I have been trying to upgrade for 2.7.0 to 2.7.6 my run from the "linuxcnc-dev" folder without success.
When I run the following from a terminal it always ends up being 2.7.0
git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev
cd linuxcnc-dev
git checkout gmoccapy_5_axis
git pull
Do I need to specify a version somewhere in the git clone line?
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
22 Aug 2016 11:49 #79245 by Todd Zuercher
I am no git master, but maybe the branch you are checking out is only based on 2.7.0?
The following user(s) said Thank You: auto-mation-assist
Time to create page: 0.287 seconds
