Linuxcnc + LFS + BLFS
- Ozzyrob
- Visitor
26 Aug 2016 13:43 #79489
by Ozzyrob
Linuxcnc + LFS + BLFS was created by Ozzyrob
Hi Guys,
Not too sure if this the right spot for this question.
So far I've managed to do a Linux From Scratch & Beyond Linux From install, chose RTAI-4.1.1 & a 3.13.33 kernel.
plain vanilla kernel install went ok, install Linuxcnc simulator ok. Ran a few tests of axis and all appeared to go ok.
Patched the kernel for RTAI, built the new kernel, rebooted and all went well, installed the RTAI modules, that again went ok.
Now to Linuxcnc 2.7
Using version 2.7.4, found I had to make a change to rtai_rtapi.c
From
To
Then the next step was to replace the whitelist section in module_helper.c (2.7.4) from the whitelist in the 2.6 branch, this was need to be able to load rtai_shm .
So far so good, can run the latency test and a quick run of axis, not connected my mill as of yet. All required modules load and unload as required...after a few tweaks to rtai.conf.
The big question I have is, does anyone have an opinion or knowledge whether these changes will have any affect to the operation of linuxcnc...or do I need to start doing some testing connected to some hardware ?
I did try building a 2.6 branch built configure complained about no version.h .
Thanks for your time
Cheers Rob
Now to Linuxcnc 2.7
From
#if RTAI <= 3
#define rt_free_timers rt_free_timer
#endifTo
#if RTAI <= 4
#endifThen the next step was to replace the whitelist section in module_helper.c (2.7.4) from the whitelist in the 2.6 branch, this was need to be able to load rtai_shm .
Cheers Rob
26 Aug 2016 13:53 #79490
Replied by andypugh on topic Linuxcnc + LFS + BLFS
Can I ask why you are doing things the hard way?
Do you have a particular Linux distribution or kernel that you want to run on? It isn't normally necessary to compile LinuxCNC, and it is especially not normally necessary to compile a custom RTAI kernel.
Have you tried running a latency test? If that looks OK then you probably do need to start testing with hardware. A free-running stepper is quite a good thing to test with, you can easily hear any glitches in the pulse stream.
- Ozzyrob
- Visitor
27 Aug 2016 00:11 - 28 Aug 2016 00:57 #79522
by Ozzyrob
Replied by Ozzyrob on topic Linuxcnc + LFS + BLFS
Had some time to kill, was interested in giving it a go. I've taken a bit out of the kernel, like sound, that I don't think is required to run a cnc machine.
Actually wasn't all that hard, have a bunch of scripts to build all the required packages I needed/wanted (I saved the tools dir from previous builds). So far I'm using about 4404MB and this includes 1858MB for a couple of extracted Linux trees (and tarballs) and RTAI sources in /usr/src & 524MB of sources for the BLFS portion of the build, removing firefox would save about another 155MB.
But yes I guess it's some time for some real world testing, biggest issue ATM is the latency spiking when loading firefox for the first time, if I close firfox, reset the latency timer and restart Firefox everything stays within spec for software step generation. This is with a very old PATA drive, thinking of getting my hands on a SATA driver and seeing how that goes. BTW the machine is a SFF HP\Compaq d530, with 1GB ram and a NV agp card.
I know there's a good chance I'm barking up the wrong tree and may fail.
Last edit: 28 Aug 2016 00:57 by Ozzyrob. Reason: it's not a Dell, you dummy Rob
27 Aug 2016 00:32 #79523
Have you compared your setup to a "normal" LiveCD install?
- Ozzyrob
- Visitor
27 Aug 2016 00:36 #79524
by Ozzyrob
Not thouroghly and not with a recent release. Which is something that I really should endeavour to do.
- Ozzyrob
- Visitor
28 Aug 2016 01:07 #79574
by Ozzyrob
Installed wheezy linuxcnc.....not really a fan of Debian to begin with, more of a Slackware kind of guy.
No matter what distro or what kind of driver, SATA or PATA, still get a spike to 50k when opening FF for first time, reset the statistics and open FF again all is good.
ATM moment I have LXterminal running with 4 tabs, one running the latency test and the other three each running glxgears, Servo thread max jitter is about 8500 and Base thread is about 9700.
I'll let it run for a bit longer and report back, btw I'm just using a window manager, ICEwm and no desktop manager, so no shortcuts on the desktop.
I'll install JWM and give that a whirl.
28 Aug 2016 09:22 #79583
A 50k spike is unlikely to cause a problem unless it happens at just the wrong time.
The following user(s) said Thank You: Ozzyrob
- Ozzyrob
- Visitor
29 Aug 2016 11:51 #79643
by Ozzyrob
I only see the spike when opening firefox, not something I'd do whilst running the Mill.
OK Rob enough talk, time to do some testing with something hooked up.
Time to create page: 0.172 seconds
