Runs ok from Live DVD - Install turns PC off
- JammyJulien
20 Sep 2016 07:45 - 21 Sep 2016 09:20 #80656
by JammyJulien
Runs ok from Live DVD - Install turns PC off was created by JammyJulien
Morning all,
I have just finished building myself a CNC mill - but I have a problem installing LinuxCNC (why else would I be here ?!)
Can I please note I do not have any hardware details at this moment as I am in work - This is a preliminary enquiry to see if anyone has any initial ideas.
I found a donor PC laying around with a on board parallel port - downloaded the latest version of the live CD and booted fine. I could use it and run the desktop, latency tests etc without issue.
However - If I try to do either a graphical install or a text install - the PC turns itself off after a few seconds - I do not get any prompts at all - its as though its getting ready to do something then just powers off.
The PC had a SATA CD Rom and HDD - which I swapped for IDE on both - but that made no difference. I also reset the BIOS to defaults but that didnt help either.
Has anyone got any trouble shooting tips please ?
I did some more tests last night. Ran the memory tests and hardware detection from the "Advanced Options". Everything worked out - but still wont install. I also added a GFX card (the previous attempts were using on-board) - still just turns off when attempting to install.
If I create the image on a USB stick instead of DVD - would I be able to inspect any log files to try to debug the issue ?
Last edit: 21 Sep 2016 09:20 by JammyJulien.
- BigJohnT
- Thank you received: 994
21 Sep 2016 17:59 #80729
by BigJohnT
Replied by BigJohnT on topic Runs ok from Live DVD - Install turns PC off
The following user(s) said Thank You: JammyJulien
- JammyJulien
22 Sep 2016 05:09 #80761
by JammyJulien
Replied by JammyJulien on topic Runs ok from Live DVD - Install turns PC off
Thanks Big John,
That version installed ok. I suspect it will be enough for my needs.
- BigJohnT
22 Sep 2016 15:01 #80772
by BigJohnT
- JammyJulien
23 Sep 2016 07:19 #80822
by JammyJulien
Thanks again John - I'll look into that.
