Linuxcnc Simulator on Mac
- Big_Mas74
27 Sep 2016 20:33 #81016
by Big_Mas74
Linuxcnc Simulator on Mac was created by Big_Mas74
Hi everybody,
I have an old Mac Core2Duo and i'm using it for gui development mainly and gcode subs, but while using my mac with vmware fusion and linux to run linuxcnc it's impractical.
I've read that it's not that easy to install linuxcnc on mac, but it can be done (compiled).
Now after long hours installing libraries i've reached to the following point.i got to the point i couldn't solve it anymore
i've googled about insmod and i know now it's only for linux and it's equivalent to kextload .
my question can i bypass these conditions to build linuxcnc?
i've edited ".confgure.in" and delete the request for insmod but is it really that way? or should I look for another approach?
./configure sim --disable-userspace-pci --without-libmodbuschecking for insmod... none
configure: error: insmod not foundi've googled about insmod and i know now it's only for linux and it's equivalent to kextload .
27 Sep 2016 22:56 #81017
What problems do you have? I actually do quite a lot of dev work using a Mac and VMware Fusion.
For stuff that needs realtime, I tend to ssh into a headless LinuxCNC motherboard sat on the bookshelf.
But, I would still quite like to see LinuxCNC running native.
Replied by andypugh on topic Linuxcnc Simulator on Mac
Hi everybody,
28 Sep 2016 08:33 #81026
As Linux uses insmod and OSX uses kextload I think that the way to handle this would be with conditional compilation.
As far as I can see "insmod" is only used in one place in the code. (one utility is used to load/unload every kernel module)
github.com/LinuxCNC/linuxcnc/blob/7bcf62...module_helper.c#L230
So you would need something a bit like
And then the configure.in would need to check for the presence kextload if the search for insmod fails.
if(inserting) {
check_whitelist_module_path(mod, argc, argv);
#ifdef __linux__
exec_argv[0] = "/sbin/insmod";
#elif __APPLE__
exec_argv[0] = "/sbin/kestload";
#endif
exec_argv[1] = mod;
for(i=3; i<argc; i++) {
exec_argv[i-1] = argv[i];
exec_argv[argc-1] = NULL;
} else {
check_whitelist_module(mod, argc, argv);
#ifdef __linux__
exec_argv[0] = "/sbin/rmmod";
#elif __APPLE__
exec_argv[0] = "/sbin/kextunload";
#endif
exec_argv[1] = mod;
exec_argv[2] = NULL;
}And then the configure.in would need to check for the presence kextload if the search for insmod fails.
The following user(s) said Thank You: Big_Mas74
- robksawyer
02 Nov 2016 01:23 #82333
by robksawyer
Replied by robksawyer on topic Linuxcnc Simulator on Mac
Were you ever able to get it running natively? Able to provide binaries?
- JetForMe
- Thank you received: 27
30 Jun 2020 04:22 - 30 Jun 2020 04:22 #173174
by JetForMe
Replied by JetForMe on topic Linuxcnc Simulator on Mac
Unfortunately, that won't be enough. Kernel Extensions on macOS need an XML plist file indicating how they're loaded and run, and extension names are reverse-domain style: org.linuxcnc.modFoo.
It might be that that's outside the scope of module_helper, which will get an appropriate extension name from an external source.
I'd sure like to be able to run and develop for LinuxCNC natively, too.
Last edit: 30 Jun 2020 04:22 by JetForMe.
30 Jun 2020 10:11 #173182
Things have moved on a bit since this discussion started. Specifically the "uspace" build of LinuxCNC will run on a plain non-realtime kernel.
This might make things easier.
See, for example, that the module load and unload commands are abstracted to macros:
github.com/LinuxCNC/linuxcnc/blob/master...ipts/realtime.in#L59
I would guess that a Mac sim would want to satisfy the conditions to reach this line:
github.com/LinuxCNC/linuxcnc/blob/2291af...ce_rtapi_app.cc#L781
