Can I retreat from noman's land to 2.5
9 years 11 months ago #82353 by Baithog
user@debien:-$ linuxcnc
Machine configuration directory is '/home/user/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
Splash screen is displayed, machine freezes. Nothing in the other desk tops.
Sometimes I can mouse to other features, but response is slow, if at all. Task manager reports (among other threads)
io -int /home/user/linuxcnc/configssim.axis/axis.ini #PID 4343, RSS 1216 KIB, CPU 0%
linuxcnc #PID 3879, RSS 13 MiB, CPU 0%
linuxcncsvr -ini /home/user/linuxcnc/configs/sim.axis/axis.ini #PID 3881, RSS 4 MiB, CPU 0%
It seems to be waiting for something to happen, but it never does. After many, many installs I can say that 2.4 and 2.5 work., 2.6 loads but doesn't work, 2.7 doesn't load. I am now convinced that it is hardware that is the problem. I ordered a refurb win7 era machine to replace it. I might have been able to get some kind of work around from the Ubuntu people, but it is a tired old machine that has already seen repairs. Tomorrow I suspect that things will resolve. It is hard to support every chip set, and the older they get, the more likely there will be problems. I should be happy that I got around 5 years out of a computer from the dump.
9 years 11 months ago - 9 years 11 months ago #82354 by Todd Zuercher
Could you try opening Linuxcnc on your 2.6 install with a different user interface? I wonder if it is an openGL problem, (Try TKemc). If that opens fine, then the problem is with the graphics adapter, and or the driver you are using it with.
Last edit: 9 years 11 months ago by Todd Zuercher.
Time to create page: 0.124 seconds
