Baithog wrote: linuxCNC 2.5 loads and works - no wifi
linuxCNC 2.6 loads but crashes - wifi
linuxCNC 2.7 doesn't load
If I could get cat5 to the mill without boring through concrete walls and digging trenches, I'd stay with 2.5.
andypugh wrote:
What is the crash report message with 2.6? Do any of the sample configs launch? I assume that the fact that you can say that WiFi works means that it is LinuxCNC that is failing to start, not the underlying OS. I would focus your nergies on that one and see why LinuxCNC isn't starting. It might be a config change.
Have you considered HomePlug? That is how I get the network to my workshop, down the same wires as the electricity.
Baithog wrote:
andypugh wrote: No crash report because the OS thinks linucCNC is running. The splash screen displays after the interface (axis) is selected. Eventually the splash screen disappears, but nothing happens after that
I wonder if the GUI is simply appearing on a different desktop, or off-screen or something odd like that.
Can you try starting LinuxCNC from the command line (command "linuxcnc") and then copy/paste the output here.
Ditto for the last 20 lines of the output of the dmesg command after launching LinuxCNC.
It seems to have got better. It even lets me wake-up the CNC machines with Wake-on-LAN from the house if I want access to them, or to get them reay for my arrival in the workshop. You can't do that with WiFi.I didn't realize that they still did the power line thing. I was a beta tester for a comcast home networking back in the '80s. That was before wifi and not all that reliable.
