Help, need gcc 4.8 or above (c++11 support)
- Gibbz
14 Nov 2016 05:47 #82763
by Gibbz
Help, need gcc 4.8 or above (c++11 support) was created by Gibbz
Ive just installed linuxcnc using the image from the website. Was wondering if there is a way to install linuxcnc on ubuntu 16.04?
I need to have gcc 4.8 so i can compile pcb2gcode.
And ive stuffed around with a few things with no luck...
Does anyone have any ideas?
Also would like to install kicad and freecad on the machine, but struggling to find current builds of these for such an old version of debian...
17 Nov 2016 12:58 #82891
Replied by andypugh on topic Help, need gcc 4.8 or above (c++11 support)
I think it has been done. You might need to compile from source, though, as there are no precompiled packages.
Which kernel do you intend to use?
- ArcEye
- Thank you received: 240
17 Nov 2016 15:35 #82903
by ArcEye
Why do you need to compile it, you can install it as a package for wheezy?
packages.debian.org/wheezy/pcb2gcode
kicad is available from the main repo and backports
packages.debian.org/wheezy/kicad
packages.debian.org/wheezy-backports/kicad
freecad is in backports too
packages.debian.org/wheezy-backports/freecad
Replied by ArcEye on topic Help, need gcc 4.8 or above (c++11 support)
- Gibbz
18 Nov 2016 05:59 #82949
by Gibbz
Replied by Gibbz on topic Help, need gcc 4.8 or above (c++11 support)
ok thats great, is the pcb2gcodeGUI available in a repo somewhere also?
That will all save a world of pain
- ArcEye
20 Nov 2016 11:48 #83032
by ArcEye
If you put 'wheezy pcb2gcode GUI' into a search engine, you will find, amongst others
github.com/pcb2gcode/pcb2gcodeGUI
The README in this tends to suggest that by enabling wheezy-backports, you can compile the GUI in the same manner as if building on Jessie.
It must mean that the libc6 / libc++ changes etc using gcc/g++ 4.9 are not a major problem.
You can let us know when you try it
