Machine only moves 1/12 the distance in G1 code line
- Les91
07 Dec 2016 19:40 #83750
by Les91
Machine only moves 1/12 the distance in G1 code line was created by Les91
When runnig the cnc config wizard, I checked each axis and they moved the specified amount. When I run the attached G code file, the machine moves only 0.39 inches for the 2 - 5 inch moves. Do I have to config the G code interpreter? Can you help.
- Thank you received: 1476
07 Dec 2016 20:06 #83752
Replied by Todd Zuercher on topic Machine only moves 1/12 the distance in G1 code line
That is easy, your first line of your G-code file has G21 (mm-mode) in it. Change it to G20 (inch mode).
(Test Link CNC)
G21 G90 G61 G40 F3 (change the G21 to G20 here!)
G0 X5 Y5
G91
G1 X5 F10
G1 Y5 F3
G1 X-5
G1 Y-5
G90
G0 X0 Y0
M2Please Log in or Create an account to join the conversation.
07 Dec 2016 22:59 #83758
Replied by andypugh on topic Machine only moves 1/12 the distance in G1 code line
There might well still be a factor of 2 error. If there is then it is likely to be due to the driver microstep setting not matching what LinuxCNC was told.
You can fix it in Stepconf, edit the INI file or alter the settings on the drive, as you feel fit.
But only one of those, not all three
08 Dec 2016 02:28 #83767
Good catch Andy. Lazy me, I didn't bother to do the math.
