Where are the Sample-Configurations
26 Dec 2016 20:30 #84712 by Holzwurm56
Where are the Sample-Configurations was created by Holzwurm56
Hello,
when I install Wheezy with LinuxCNC there some sampleconfigurations. Can some tell me where are the directory with the samples is?
Hans
26 Dec 2016 21:20 #84715 by tommylight
Replied by tommylight on topic Where are the Sample-Configurations
You do need the directory, from the aplications menu choose Linuxcnc, it opens a config picker where you can choose from the sample configs, then it will copy that config to /home/yourname/linuxcnc/configs , there you can edit and modify them at will.
26 Dec 2016 21:57 #84720 by Holzwurm56
Replied by Holzwurm56 on topic Where are the Sample-Configurations
Hello,
I get a configuration with many files. In what kind of way can I install this configuration?
Hans
26 Dec 2016 22:18 #84721 by tommylight
Just chose a config and run it, it automaticly copies it to above mentioned folder. No istallatiom needed.
Time to create page: 0.165 seconds
