Installed parallel port wont function
- neil52
02 Feb 2017 15:55 #87158
by neil52
Installed parallel port wont function was created by neil52
Do I need to install driver?if so how. error message=
Print file information:
- Thank you received: 5325
02 Feb 2017 16:27 #87159
Replied by PCW on topic Installed parallel port wont function
Did you set the parallel port address?
If this is a plug in card you either need to determine its address with lspci -v
or try the "0" or "1" address options (which means use the first or second parallel port found)
- neil52
02 Feb 2017 16:55 #87161
by neil52
Replied by neil52 on topic Installed parallel port wont function
I have done both ,I think maybe I have bad card and have ordered another in case.
Time to create page: 0.145 seconds
