LinuxCNC on Debian Stretch
9 years 4 months ago #94961 by tommylight
The root password thing on Debian has been mentioned a lot of times on this forum, and elsewhere on the net. It should be left blank. Always. That is there for system administrators. For normal use it is not needed, ever.
9 years 4 months ago #94971 by grump
Replied by grump on topic LinuxCNC on Debian Stretch
While I appreciate what you say Tom I rarely install commercial or prebuilt distros in fact this is a first in my memory.
I usually compile my os and need to have root privileges in order to even grant a sudo user let alone anything else.
A normal install for me is from the net and a root password has to be given to proceed.
I am now using this on 4 confusers and yes if I leave the root password blank I am automatically granted sudo privileges.
My normal install would be as root and then add the sudo user and install the packages I want rather than delete what I don't want.
It's only a matter of preference but I don't want or need an office suite, media players, sound blaster, torrent, cd burner, a choice of terminals, power manager or anything else to slow my machine and interfere with my work, I simply want a computer to do what I want it to do.
I want to administrate, simple as that, and I should be able to, and am now I know.
9 years 4 months ago #94973 by tommylight
Nice, thank you. I do that also very offten.
I worked for several large organisations ( United Nations and Organisation for Security and Cooperation in Europe, and some others.) So i am fully aware of the mess that can ensue leaving things unchecked and giving users full acces to systems.
Regards,
Tom.
The following user(s) said Thank You: grump
9 years 4 months ago - 9 years 4 months ago #94981 by grump
Just a side note, I see whilst adding my geometry to .ini file that the joints have disappeared.
It looks like I now have axis 2.7.9, a step back from where I was, not a problem for me, everything works as it should but may upset somebody.
And apologies to k10 for hijacking this thread.
Last edit: 9 years 4 months ago by grump.
9 years 4 months ago #94982 by skunkworks
Yes - The livecd will have the released version - not the development version.
sam
9 years 4 months ago #94985 by grump
Will this be an ongoing thing Sam?
I have bookmarked the page and am happy to test latest releases.
Aside from home use I also install to sd card and travel with it to other machines.
Once again thanks for doing this, I was making my own iso's to save time on installs but don't need to with this livecd.
Time to create page: 0.509 seconds
