LinuxCNC on Debian Stretch
9 years 3 months ago #96363 by 10K
Replied by 10K on topic LinuxCNC on Debian Stretch
Tim-
I have the following versions:
Debian 4.11.6-1 (i386)
Kernel 4.11.0-1-rt-686-pae
LinuxCNC 1.2.7.9
Gmoccapy 1.5.7
I'm getting really good latency times. The new 4.11 RT kernel works a little better than the 4.9 that I was using. I'm getting latencies around 2,500 average and infrequent peaks of 15,000.
I was getting occasional latency spikes of over 1,000,000 that played havoc with LinuxCNC. I had to do three things to address this:
Change GRUB to boot with isocpus=1
BIOS - Disable Intel Dynamic Power Technology
BIOS - Set the fan speed to constant instead of adaptive. (Thanks to arceye for mentioning this in a post. I had never seen it anywhere else.)
I have one additional problem that I think I understand. If I load up LinuxCNC right after booting, I may get a latency spike and error message. I don't get this (yet) it I wait a couple of minutes for Linux to do whatever it does after it first boots. I just got this working last week, so I'm still in testing mode. In any case, doing the three things above has improved the problem immensely.
Like you, I've had trouble with Intel network drivers. I've had to round up iwlwifi-7265D-23.ucode, -24, -25, and -26 driver files. With the latest Debain update, it now wants -27 and -28 drivers. (These can be found at github.com/NetBit73/NeteXt73_pakiety/tree/master/iwlwifi ) I'll have to install those when I get a chance.
9 years 3 months ago #96364 by Todd Zuercher
Todd Zuercher wrote: Just for shits and giggles I gave the new Stretch ISO a whirl on an old P4 system, and I actually got better latency score numbers than I had been seeing with the Wheezy RTAI ISO. (Not great, but possibly usable numbers).
Monday morning I want to try plugging that HD into another old P4 system with an ISA card, and see if it works. That system has been running Lucid fine for a long time, but I can't get the Wheezy ISO to work at all on that machine.
This was a dismal failure, for me The machine (an old 2.8GHz P4 with ISA slots 1G ram) performed pathetically with the HD I set up on another old 2.4GHz P4. The ISA slotted machine would not even plot lines on the latency plot screen, everything was either over or under runs. By comparison the slower machine I setup the disk on, was showing max latency of about 35us. So I plugged the Lucid disk back in. I wish I understood why that old machine refuses to work with any of the newer kernels.
9 years 2 months ago #97061 by grump
Replied by grump on topic LinuxCNC on Debian Stretch
Since this resource has been made available I have tried and tested every edition to the current version 7.
Without failure to this date, why mess with a struggle when there is no need to?
I too was installing from here, there and everywhere, adding and deleting as was my want.
The latest version 7 has even picked up mt wifi card which until now I always had to install separately.
I would recommend this route above all at the moment.
Still not so keen on the xfce DE and all the other stuff that comes with it but that is only personal preference and soon changed.
www.linuxcnc.org/testing-stretch-amd64-rtpreempt/
Looks like it has been taken down, didn't last long did it?
9 years 2 months ago #97067 by skunkworks
Nothing so nefarious.... The linuxcnc buildbot server seems to be down currently. (Where the ISO was hosted)
9 years 2 months ago #97068 by grump
I had noticed the buildbot had been down for some time now, hope it comes back on soon.
I need my monthly fix of reinstall.
9 years 2 months ago #97082 by skunkworks
this is the actual link..
www.linuxcnc.org/testing-stretch-rtpreempt/
grump wrote: I had noticed the buildbot had been down for some time now, hope it comes back on soon.
Time to create page: 0.443 seconds
