building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
10 Apr 2018 00:45 - 10 Apr 2018 00:58 #108685 by dbanks
make -j4 is taking a lifetime.
Last edit: 10 Apr 2018 00:58 by dbanks.
10 Apr 2018 01:18 #108688 by PCW
it will if you dont have 4 cores...
10 Apr 2018 01:21 #108689 by dbanks
Definitely a quad core.
10 Apr 2018 02:17 #108690 by dbanks
Having a hard time selecting the new kernel, can someone fill me in on where advanced options---> select new kernel is?
10 Apr 2018 02:23 #108691 by thang
i forgot how to set up grub but u can try this:
askubuntu.com/questions/82140/how-can-i-...older-kernel-version
the easiest way is press shift while booting
10 Apr 2018 02:30 #108692 by dbanks
Running into no such file or directory errors with dkph check builddeps, ./configure-with and ./autogen is this as a result of the wrong kernel?
10 Apr 2018 02:31 #108693 by dbanks
Pressing shift while booting didn't do anything, I appreciate it though!
10 Apr 2018 02:39 #108694 by thang
you can check what kernel you are using in terminal by command: uname-r .
10 Apr 2018 02:40 #108695 by dbanks
Comes up with 4.13.0-38 generic, which by my masterful googling seems to be no good.
10 Apr 2018 02:48 #108697 by dbanks
I got to Grub it was esc AFTER my bios screen. However selecting the kernel says unable to mount root fs on unknown block. Any ideas?!
Time to create page: 0.159 seconds
