Is the wheezy 2.7 build broken?
12 Dec 2017 02:10 - 12 Dec 2017 03:43 #102966 by DeckelHead
Is the wheezy 2.7 build broken? was created by DeckelHead
I've been beating myself up trying to get the current wheezy 2.7 ISO to work properly. I've tried both creating a DVD using the ISO and have followed the bootable USB (dd if=linuxcnc-2.7-wheezy.iso of=/dev/diskX) approach, both without success. And, yes, I have validated that I have the correct MD5 (978ca074c51194e72f93e8c8d7110cfa) so I should not have corruption issues.
I am doing all of this on a Mac High Sierra OSX machine, although I have performed the dd approach using Linux too. I have created bootable versions of LinuxCNC before, but that was pretty long ago. I am finally getting back to my mill project (mothballed for 3 years) and I figure I'll start with a brand new LinuxCNC from the OS on up. That is the reason I'm not doing an upgrade to my existing machine.
When I try to create a CD, I simply right click on the downloaded ISO in Mac Finder and select "burn to disc". The result is a CD that will not boot. I am guessing the boot sector is missing.... When I try to create a bootable USB using dd, I also end up with a non-bootable device. Interestingly, the partition also seems to be very messed up, although I guess that isn't too surprising as the ending partition should be about the size of the DVD I guess. Here is the result of my dd:
Alans29z30iMac9:Downloads alan$ sudo dd if=linuxcnc-2.7-wheezy.iso of=/dev/disk4 bs=1m
Password:
1140+1 records in
1140+1 records out
1196163072 bytes transferred in 270.495525 secs (4422118 bytes/sec)
Is the image corrupted or am I just doing something brain dead? I'm guessing the problem is most likely between the chair and the keyboard. That is usually where I find most errors! :side:
Last edit: 12 Dec 2017 03:43 by DeckelHead.
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
12 Dec 2017 03:40 - 14 Dec 2017 00:04 #102969 by ozzyrob
Replied by ozzyrob on topic Is the wheezy 2.7 build broken?
Last edit: 14 Dec 2017 00:04 by ozzyrob. Reason: Wasted time
12 Dec 2017 03:52 - 12 Dec 2017 03:55 #102971 by DeckelHead
Replied by DeckelHead on topic Is the wheezy 2.7 build broken?
Good questions and I should have put some additional information in there....
One thing that I found very interesting is that I can mount the ISO on my Mac or my (old) Linux (LinuxCNC) machine. So, yes, it is not a corrupted image; I agree with that.
However, when I try to read the DVD I created on my Mac, I am unable to do so; I get a "The disk you inserted was not readable by this computer." dialog. I have a similar experience with the USB. As soon as the dd is complete, OSX tries to mount the USB stick. I am then presented with the (near identical) message but with an additional option to Initialize the USB again.
I have written many ISO images to disk before on the Mac. They've changed the process a little, but it is fundamentally the same. Most of what I write are not bootable, but I've never had a problem like this before. One last bit of interest is that I ran into a similar problem when I tried to perform the dd from my Linux box. In that case, I copied the ISO over with my (then reformatted into a USB memory stick) to the Linux machine. From there, I went through the explicit directions presented in the "How do you make a USB..." section of the LinuxCNC download. The result was the same, namely a corrupt USB.
The USB is a brand new 16GB Kingston stick. The USB based DVD writer is also brand new.
Oh, and the MB is a 4+ year old Asus. I was able to successfully boot/install LinuxCNC onto it in the past, so unless something has radically changed with the process, I don't think that is it. But, at this point, I am flat out perplexed....
Last edit: 12 Dec 2017 03:55 by DeckelHead. Reason: added info about MB
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
12 Dec 2017 04:27 #102973 by ozzyrob
Try either a 2GB or 4GB USB stick, I had the same problem when I was setting up my server trying to boot off an "old" MB with a 16GB USB stick.
If you know the exact MB you are booting from it'll help nail this issue.
12 Dec 2017 05:11 #102975 by DeckelHead
It is an:
Asus P8H61-MLX PLUS r2.0
I shall search for a 2 or 4gb USB. I hope I have one!
Any idea why the ISO burn to a CD would fail? That seems like it should be the bullet-proof approach. I've had issues with sticks before, but CDs always seem to work (well, they did!)
12 Dec 2017 05:36 #102976 by DeckelHead
I found a 2GB thumb drive and performed:
sudo dd if=linuxcnc-2.7-wheezy.iso of=/dev/disk5 bs=1m
I get the same behavior before... When I reinsert the drive into the USB port, I get the message:
I'm not having much luck here... All of this is independent of the Asus target MotherBoard, frankly. I can't even get my machines to write the disk. I have that as a plural because I've tried it on multiple machines (Linux and Macs). I am quickly coming to the conclusion that either my process is wrong or there is an issue with the build/ISO.
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
12 Dec 2017 08:15 - 14 Dec 2017 00:04 #102980 by ozzyrob
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
12 Dec 2017 08:24 - 14 Dec 2017 00:05 #102982 by ozzyrob
Last edit: 14 Dec 2017 00:05 by ozzyrob. Reason: Wasted time
12 Dec 2017 14:38 #103000 by DeckelHead
Thanks ozzyrob. That is exactly what I was looking for (confirmation that the MD5 verified ISO is working fine. Clearly there is a problem with what I'm doing. I pretty much assumed as much, but having confirmation is worth its weight in gold.
I pulled out my T61 (running Linux, not Windoze) and I'll try that this evening when I get home from work.
Regarding errors on the dd. I don't recall what the final output is supposed to be but it doesn't have an explicit error message. This is one run I had (from a previous post here):
1140+1 records in
1140+1 records out
12 Dec 2017 14:46 #103002 by PCW
Replied by PCW on topic Is the wheezy 2.7 build broken?
Did you do a sync before unmounting the USB drive?
Time to create page: 0.191 seconds
