Where is scripts/rip-environment on linuxcnc-2.7-wheezy
8 years 10 months ago #103042 by AndrewHsasku
I am fed up with lack of documentation and sense in LinuxCNC.
Where is ./scripts/rip-environment located on linuxcnc-2.7-wheezy?
8 years 10 months ago - 8 years 10 months ago #103043 by Todd Zuercher
That depends on where you saved your git pull. There in the scripts dir.
Last edit: 8 years 10 months ago by Todd Zuercher.
  • ozzyrob
  • New Member
  • New Member
8 years 10 months ago #103044 by ozzyrob
If you have compiled run-in-place in will be in:
/path-to-some-directory-you-chose/linuxcnc/scripts
If you haven't yet compiled it wont be there.
If you are running form the live image or installed form the live image there is no need for it.
The wiki & docs are full of information, then there is also the source code to browse through, you wont garner a solid understanding after a few days, it takes a while, the more you use Linuxcnc to control a machine the better the understanding gets.
As for a "lack of sense" can you provide some examples ?
8 years 10 months ago #103129 by AndrewHsasku
Its pure copy installed from iso. Nothing added from git.
Starting linuxcnc, there is a lot of error like "Module xxx is in use by xxx". Some posts suggests using rip-environment to fix this error, but I cant find rip-environment anywhere.
  • ozzyrob
  • New Member
  • New Member
8 years 10 months ago - 8 years 10 months ago #103130 by ozzyrob
The rip-environment script sets up the environment variables for linuxcnc when it's compiled for run-in-place and installed via make setuid. You "source" this script before launching linuxcnc.
I think the best course of action would be to upload any logs relating to this issue, along with your hal files and any other files related to the config you are trying to run.
Does this issue appear when you run one of the supplied configs ?
What conditions are you seeing this error ?
Last edit: 8 years 10 months ago by ozzyrob.
8 years 10 months ago #103148 by BigJohnT
The . ./scripts/rip-environment is only for a RIP (Run In Place) which means you downloaded a clone not for an installed LinuxCNC.
The exact error message is a big help...
JT
Time to create page: 0.419 seconds
