Ubuntu Xenial LTS Repository
8 years 8 months ago - 8 years 8 months ago #105519 by ted1735
Thank you for the directions. These are also here with more detail if interested:
Build Dependencies - linuxcnc.org/docs/devel/html/code/buildi...g-Build-Dependencies
I am on a 32bit chroot and had to go the long way as outlined above. I installed all the missing dependencies and then re-ran dpkg-checkbuilddeps and it was CLEAR!
the "debuild -uc -us" didn't work for me, it was glad I had the reference link above. So the command I used and it compiled was:
"dpkg-buildpackage -uc -us"
Also of note in case someone on the same issue :
"Once the Debian package scripts and meta-data are configured, build the package by running dpkg-buildpackage (note that it needs to run from the linuxcnc-dev directory, not from linuxcnc-dev/debian):"
One more think I had to install fakeroot to get it to start compiling
Last edit: 8 years 8 months ago by ted1735. Reason: forgot something
8 years 4 months ago #112991 by bkt
Replied by bkt on topic Ubuntu Xenial LTS Repository
very interesting project ... but not possible to have an access to your repo these day .... is still active?
Giorgio
8 years 3 months ago #114798 by eFalegname
szechyjs wrote: If there is enough interest I've been considering setting up something to add daily development builds of version 2.8 as well.
Note: I plan on adding 18.04 Bionic LTS packages as well once it is released later this year.
Hi szechyjs!
Is your project still standing?
I need your help to install Linuxcnc 2.8 on Ubuntu gnome 18.04....please
8 years 3 months ago #114848 by szechyjs
It is, but at this time it still only supports Xenial (16.04) and v2.7.
I've been debating how to handle the RT kernel for Bionic as the released kernel does not have RT support. Bionic ships with 4.15, however there is only RT support for 4.14 and 4.16.
If we can decide on the RT kernel I can easily start publishing that and v2.7 debs. The v2.8 daily/nightlies are still on the back burner though.
The following user(s) said Thank You: irakandjii
8 years 3 months ago - 8 years 3 months ago #115013 by eFalegname
Hi szechyjs, but it would be possible to install linuxcnc 2.7 in a simulator mode on Ubuntu 18.04 (Pop!_OS 18)?
Last edit: 8 years 3 months ago by eFalegname.
8 years 3 months ago #115104 by irakandjii
Hi I am very new to this topic. I have some Ubuntu experience for IoT but that is it.
I am buying a new MB/CPU (I3/Z370 chipset) etc for my CNC setup. I was planning on installing Ubuntu 18.04, but from this thread it sounds like I should stay with 16.04. Is this correct?
At a later date can I update to 18.04?
I want to run LinuxCNC intermittently, (a few times a week), but I need to run some IoT automation software using nodeJS all the time (very low loading but 7/24 is imperative). I was hoping to have just one Linux platform. I am assuming this is possible with current coffee lake CPU's and MB's
I have no opinion of the RT kernel for 18.04 and just hope a decision is forthcoming so I can avoid the mess I tend to make when upgrading a major release in the OS.
Thanks in advance, I am grateful for this forum
Time to create page: 0.214 seconds
