Vanilla dev installation fails at 'yapps'
8 years 8 months ago #106081 by GaryLa
When using make, I get plenty of normal compiler and linker output, followed by:
Compiling hal/user_comps/xhc-hb04.cc
Linking xhc-hb04
make: yapps: Command not found
make: *** [objects/hal/utils/halcompile.py] Error 127
Does anyone know what this is? I have yapps installed, and I cannot find yapps referenced in the makefile or the makefile.inc
8 years 8 months ago #106086 by cmorley
I know there was recent changes regarding yapps.
You might try the IRC - Jeff Eppler would be the guy to ask.
Chris M
8 years 8 months ago #106131 by dgarrett
The following user(s) said Thank You: Mike_Eitel, GaryLa
8 years 8 months ago #106133 by GaryLa
Thanks. For whatever reason, my yapps was named yapps2. All working now.
8 years 8 months ago #106480 by allistar
I'm using Gentoo with a RT kernel and it's failing to make linuxcnc at the same place. I have yapps2 installed but that is called yapps2, not yapps2. I have tried symlinking yapps2 to yapps, copying it with the new name yet the make still fails. How did you workaround the yapps vs yapps2 name difference?
8 years 8 months ago - 8 years 8 months ago #106489 by dgarrett
The makefile requirement is that there is an executable named
'yapps' in the PATH
$ find src -type f -iname '*akefile*' -exec grep -H yapp {} \; src/hal/utils/Submakefile: $(Q)yapps $< $@
The 'which' command will show (or not) if you have an executable
named yapps (a proper link will work too)
$ which yapps /usr/bin/yapps $ ls -lL $(which yapps) -rwxr-xr-x 1 root root 4130 Nov 8 2016 /usr/bin/yapps
Last edit: 8 years 8 months ago by dgarrett.
Time to create page: 0.415 seconds
