Why Debian 7 and not newer? systemd?
- cupakm
26 Apr 2018 18:48 #109679
by cupakm
Why Debian 7 and not newer? systemd? was created by cupakm
Hi there. I'm wondering why here linuxcnc.org/docs/html/getting-started/g...th_preempt_rt_kernel is explicitly stated to download Debian 7 and not 8 (I guess 9's also outta game... isn't it?) Because of the systemd?
- Online
- Thank you received: 1480
26 Apr 2018 19:20 #109681
Replied by Todd Zuercher on topic Why Debian 7 and not newer? systemd?
I believe that that particular section of the docs is a little out of date. It was written before Linuxcnc had precompiled versions for Debian 8 and 9 available on buildbot. I know that I have installed Debian 9 using those instructions as a rough guide and it worked fine.
- cupakm
26 Apr 2018 20:21 #109687
by cupakm
Replied by cupakm on topic Why Debian 7 and not newer? systemd?
So I could grab any distro, put PREEMPT or RT kernel into it, compile linuxcnc from sources and there should be a good chance it will work, right?
- Online
26 Apr 2018 20:33 #109689
Yes, but that isn't what I was advocating. The trick to doing that is meeting all the required dependencies to build it from the source code.
It is generally much simpler to use one of distros and kernels that have precompiled versions available here.
buildbot.linuxcnc.org/
- ozzyrob
- Visitor
27 Apr 2018 01:50 #109693
by ozzyrob
Yep I've done that with Slackware (32 bit) ,and going to do it again with slackware64 and using the Linux from Scratch & Beyond Linux from Scratch docs.
I prefer the SysVinit way, nice and simple.
Replied by ozzyrob on topic Why Debian 7 and not newer? systemd?
- Thank you received: 7490
27 Apr 2018 19:40 #109728
Yep, done it with all versions of Linux Mint, several Ubuntu flavours, and some other Linux distros.
I also agree with the sysV way, sysD put to much eggs into one basket, you drop the basket and end up with to many broken eggs.
Replied by tommylight on topic Why Debian 7 and not newer? systemd?
- Grotius
- Thank you received: 2349
27 Apr 2018 23:26 #109737
by Grotius
Replied by Grotius on topic Why Debian 7 and not newer? systemd?
@Todd,
The linuxcnc aftermarket : www.linuxcnc.org/testing-stretch-rtpreempt/
This debian 9, 64 bit strech version is the best you can get.
Change the reprository to the master version after install. You can see it on the linuxcnc buildbot site how to update to master version.
Good luck !!
Good luck !!
Time to create page: 0.134 seconds
