LinuxCNC terminated with errors
- CNCKoala
15 Jul 2018 04:34 #114197
by CNCKoala
LinuxCNC terminated with errors was created by CNCKoala
Good day Linux Knowledge base
I am a total noobie to this software, even having to get a friend to help with the install, so please forgive my ignorance on may things. Also if this is in the wrong thread, can someone please point me to the correct board
I have a 6040 router from eBay that I am trying to get configured to run with LinuxCNC through TD4CD-P breakout / control box containing a TB6560 board.
The first couple of runs using the Stepconf Wizard worked fine as far as getting them to accept all the information required but I could not control the router with the software, which I put down to a pin allocation issue when trying to convert the instructions from MACH3.
Today however when I try and go in and start up the profile for editing I get a huge error message, the latest I have pasted below. I have tried creating new profiles,restarting the computer each time but still get a LinuxCNC termination error.
Thanks in advance for any insight your collective knowledge might offer.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/machineshop/linuxcnc/configs/6040-router'
Machine configuration file is '6040-router.ini'
INIFILE=/home/machineshop/linuxcnc/configs/6040-router/6040-router.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./6040-router.hal
Killing task linuxcncsvr, PID=3649
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hal_parport.ko: Device or resource busy
./6040-router.hal:6: exit value: 1
./6040-router.hal:6: insmod for hal_parport failed, returned -1
See the output of 'dmesg' for more information.
3649
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009e400 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007bbffc00 (usable)
[ 0.000000] BIOS-e820: 000000007bbffc00 - 000000007bc53c00 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007bc53c00 - 000000007bc55c00 (ACPI data)
[ 0.000000] BIOS-e820: 000000007bc55c00 - 000000007e000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fed00400 (reserved)
[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000feda0000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: Dell Inc. OptiPlex 760 /0F373D, BIOS A02 02/18/2009
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7bbff max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: write-back
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D3FFF write-protect
[ 0.000000] D4000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 07BE00000 mask FFFE00000 uncachable
[ 0.000000] 1 base 07C000000 mask FFC000000 uncachable
[ 0.000000] 2 base 07BD00000 mask FFFF00000 uncachable
[ 0.000000] 3 base 080000000 mask F80000000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fe710] fe710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009a000] 9a000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 3652e000 - 3728f000
[ 0.000000] ACPI: RSDP 000fec00 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT 000fc7ef 00074 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: FACP 000fc91f 000F4 (v03 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: DSDT fff1be4b 0536F (v01 DELL dt_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: FACS 7bbffc00 00040
[ 0.000000] ACPI: SSDT fff212d9 000AA (v01 DELL st_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: APIC 000fca13 00092 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: BOOT 000fcaa5 00028 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: ASF! 000fcacd 00096 (v32 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: MCFG 000fcb63 0003E (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: HPET 000fcba1 00038 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: TCPA 000fcdfd 00032 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: ____ 000fce2f 00030 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: SLIC 000fcbd9 00176 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1092MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007bbff
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x0007bbff
[ 0.000000] On node 0 totalpages: 506765
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f55b6200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3950 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2185 pages used for memmap
[ 0.000000] HighMem zone: 277368 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x05] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x07] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 8 CPUs, 6 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 7e000000 (gap: 7e000000:62000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f7769000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 502804
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=076b3ee5-c54e-4e49-9827-df7871ec7b85 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x3, cntxt size 0x240
[ 0.000000] allocated 4054904 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007bbff)
[ 0.000000] Memory: 1986304k/2027516k available (3495k kernel code, 40756k reserved, 1237k data, 416k init, 1118212k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:744 16
[ 0.000000] CPU 0 irqstacks, hard=f5006000 soft=f5008000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2792.835 MHz processor.
[ 0.004002] Calibrating delay loop (skipped), value calculated using timer frequency.. 5585.67 BogoMIPS (lpj=11171340)
[ 0.004006] pid_max: default: 32768 minimum: 301
[ 0.008030] Security Framework initialized
[ 0.008034] AppArmor: AppArmor disabled by boot time parameter
[ 0.008049] Mount-cache hash table entries: 512
[ 0.008229] Initializing cgroup subsys cpuacct
[ 0.008231] Initializing cgroup subsys memory
[ 0.008239] Initializing cgroup subsys devices
[ 0.008241] Initializing cgroup subsys freezer
[ 0.008243] Initializing cgroup subsys net_cls
[ 0.008245] Initializing cgroup subsys blkio
[ 0.008250] Initializing cgroup subsys perf_event
[ 0.008275] CPU: Physical Processor ID: 0
[ 0.008276] CPU: Processor Core ID: 0
[ 0.008278] mce: CPU supports 6 MCE banks
[ 0.008284] CPU0: Thermal monitoring enabled (TM2)
[ 0.008334] ACPI: Core revision 20120320
[ 0.155239] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.155600] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.195291] CPU0: Intel(R) Core(TM)2 Duo CPU E7400 @ 2.80GHz stepping 0a
[ 0.196011] Performance Events: PEBS fmt0+, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.196011] ... version: 2
[ 0.196011] ... bit width: 40
[ 0.196011] ... generic registers: 2
[ 0.196011] ... value mask: 000000ffffffffff
[ 0.196011] ... max period: 000000007fffffff
[ 0.196011] ... fixed-purpose events: 3
[ 0.196011] ... event mask: 0000000700000003
[ 0.204150] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.216035] CPU 1 irqstacks, hard=f5114000 soft=f5116000
[ 0.216038] Booting Node 0, Processors #1
[ 0.008000] Initializing CPU#1
[ 0.228041] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.228082] Brought up 2 CPUs
[ 0.228084] Total of 2 processors activated (11171.34 BogoMIPS).
[ 0.229571] devtmpfs: initialized
[ 0.229571] PM: Registering ACPI NVS region [mem 0x7bbffc00-0x7bc53bff] (344064 bytes)
[ 0.229571] dummy:
[ 0.229571] NET: Registered protocol family 16
[ 0.229571] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.229571] ACPI: bus type pci registered
[ 0.229571] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.229571] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.229571] PCI: Using MMCONFIG for extended config space
[ 0.229571] PCI: Using configuration type 1 for base access
[ 0.229571] dmi type 0xB1 record - unknown flag
[ 0.229571] bio: create slab <bio-0> at 0
[ 0.232039] ACPI: Added _OSI(Module Device)
[ 0.232041] ACPI: Added _OSI(Processor Device)
[ 0.232044] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.232046] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.232912] ACPI: EC: Look up EC in DSDT
[ 0.267189] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.289863] ACPI Warning: Incorrect checksum in table [TCPA] - 0x00, should be 0x7F (20120320/tbutils-323)
[ 0.291076] ACPI: Interpreter enabled
[ 0.291084] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.291111] ACPI: Using IOAPIC for interrupt routing
[ 0.397479] ACPI: ACPI Dock Station Driver: 1 docks/bays found
[ 0.397485] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.405653] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.422847] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7]
[ 0.422847] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff]
[ 0.422847] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.422847] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000effff]
[ 0.422847] pci_root PNP0A03:00: host bridge window [mem 0x000f0000-0x000fffff]
[ 0.422847] pci_root PNP0A03:00: host bridge window [mem 0xf0000000-0xfec00000]
[ 0.422847] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xdfffffff]
[ 0.422847] pci_root PNP0A03:00: host bridge window [mem 0xff980000-0xff980fff]
[ 0.422847] pci_root PNP0A03:00: host bridge window [mem 0xff97c000-0xff97ffff]
[ 0.422847] pci_root PNP0A03:00: host bridge window [mem 0xfed20000-0xfed9ffff]
[ 0.422847] pci_root PNP0A03:00: host bridge window [mem 0xfeda7000-0xfeda7fff]
[ 0.422847] PCI host bridge to bus 0000:00
[ 0.422847] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.422847] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.422847] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.422847] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000effff]
[ 0.422847] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff]
[ 0.422847] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfec00000]
[ 0.422847] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff]
[ 0.422847] pci_bus 0000:00: root bus resource [mem 0xff980000-0xff980fff]
[ 0.422847] pci_bus 0000:00: root bus resource [mem 0xff97c000-0xff97ffff]
[ 0.422847] pci_bus 0000:00: root bus resource [mem 0xfed20000-0xfed9ffff]
[ 0.422847] pci_bus 0000:00: root bus resource [mem 0xfeda7000-0xfeda7fff]
[ 0.422847] pci 0000:00:00.0: [8086:2e10] type 00 class 0x060000
[ 0.422847] pci 0000:00:01.0: [8086:2e11] type 01 class 0x060400
[ 0.422847] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.422847] pci 0000:00:02.0: [8086:2e12] type 00 class 0x030000
[ 0.422847] pci 0000:00:02.0: reg 10: [mem 0xfe800000-0xfebfffff 64bit]
[ 0.422847] pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.422847] pci 0000:00:02.0: reg 20: [io 0xec90-0xec97]
[ 0.422847] pci 0000:00:02.1: [8086:2e13] type 00 class 0x038000
[ 0.422847] pci 0000:00:02.1: reg 10: [mem 0xfe700000-0xfe7fffff 64bit]
[ 0.422847] pci 0000:00:03.0: [8086:2e14] type 00 class 0x078000
[ 0.422847] pci 0000:00:03.0: reg 10: [mem 0xfeda6000-0xfeda600f 64bit]
[ 0.422847] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.422847] pci 0000:00:03.2: [8086:2e16] type 00 class 0x010185
[ 0.422847] pci 0000:00:03.2: reg 10: [io 0xfe80-0xfe87]
[ 0.422847] pci 0000:00:03.2: reg 14: [io 0xfe90-0xfe93]
[ 0.422847] pci 0000:00:03.2: reg 18: [io 0xfea0-0xfea7]
[ 0.422847] pci 0000:00:03.2: reg 1c: [io 0xfeb0-0xfeb3]
[ 0.422847] pci 0000:00:03.2: reg 20: [io 0xfef0-0xfeff]
[ 0.422847] pci 0000:00:03.3: [8086:2e17] type 00 class 0x070002
[ 0.422847] pci 0000:00:03.3: reg 10: [io 0xec98-0xec9f]
[ 0.422847] pci 0000:00:03.3: reg 14: [mem 0xfe6d8000-0xfe6d8fff]
[ 0.422847] pci 0000:00:19.0: [8086:10de] type 00 class 0x020000
[ 0.422847] pci 0000:00:19.0: reg 10: [mem 0xfe6e0000-0xfe6fffff]
[ 0.422847] pci 0000:00:19.0: reg 14: [mem 0xfe6d9000-0xfe6d9fff]
[ 0.422847] pci 0000:00:19.0: reg 18: [io 0xecc0-0xecdf]
[ 0.422847] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.422847] pci 0000:00:1a.0: [8086:3a67] type 00 class 0x0c0300
[ 0.422847] pci 0000:00:1a.0: reg 20: [io 0xff20-0xff3f]
[ 0.422847] pci 0000:00:1a.1: [8086:3a68] type 00 class 0x0c0300
[ 0.422847] pci 0000:00:1a.1: reg 20: [io 0xff00-0xff1f]
[ 0.422847] pci 0000:00:1a.2: [8086:3a69] type 00 class 0x0c0300
[ 0.422847] pci 0000:00:1a.2: reg 20: [io 0xfc00-0xfc1f]
[ 0.422847] pci 0000:00:1a.7: [8086:3a6c] type 00 class 0x0c0320
[ 0.422847] pci 0000:00:1a.7: reg 10: [mem 0xfe6da000-0xfe6da3ff]
[ 0.422847] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.422847] pci 0000:00:1b.0: [8086:3a6e] type 00 class 0x040300
[ 0.422847] pci 0000:00:1b.0: reg 10: [mem 0xfe6dc000-0xfe6dffff 64bit]
[ 0.422847] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.422847] pci 0000:00:1c.0: [8086:3a70] type 01 class 0x060400
[ 0.422847] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.422847] pci 0000:00:1c.1: [8086:3a72] type 01 class 0x060400
[ 0.422847] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.422847] pci 0000:00:1d.0: [8086:3a64] type 00 class 0x0c0300
[ 0.422847] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.422847] pci 0000:00:1d.1: [8086:3a65] type 00 class 0x0c0300
[ 0.422847] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.422847] pci 0000:00:1d.2: [8086:3a66] type 00 class 0x0c0300
[ 0.422847] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.422847] pci 0000:00:1d.7: [8086:3a6a] type 00 class 0x0c0320
[ 0.422847] pci 0000:00:1d.7: reg 10: [mem 0xff980000-0xff9803ff]
[ 0.422847] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.422847] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.422847] pci 0000:00:1f.0: [8086:3a1a] type 00 class 0x060100
[ 0.422847] pci 0000:00:1f.2: [8086:3a02] type 00 class 0x010601
[ 0.422847] pci 0000:00:1f.2: reg 10: [io 0xfe00-0xfe07]
[ 0.422847] pci 0000:00:1f.2: reg 14: [io 0xfe10-0xfe13]
[ 0.422847] pci 0000:00:1f.2: reg 18: [io 0xfe20-0xfe27]
[ 0.422847] pci 0000:00:1f.2: reg 1c: [io 0xfe30-0xfe33]
[ 0.422847] pci 0000:00:1f.2: reg 20: [io 0xfec0-0xfedf]
[ 0.422847] pci 0000:00:1f.2: reg 24: [mem 0xff970000-0xff9707ff]
[ 0.422847] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.422847] pci 0000:00:1f.3: [8086:3a60] type 00 class 0x0c0500
[ 0.422847] pci 0000:00:1f.3: reg 10: [mem 0xfe6db000-0xfe6db0ff 64bit]
[ 0.422847] pci 0000:00:1f.3: reg 20: [io 0xece0-0xecff]
[ 0.422847] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.422847] pci 0000:00:01.0: bridge window [mem 0xfe500000-0xfe5fffff]
[ 0.422847] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.422847] pci 0000:00:1c.0: bridge window [mem 0xfe400000-0xfe4fffff]
[ 0.422847] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.422847] pci 0000:00:1c.1: bridge window [mem 0xfe300000-0xfe3fffff]
[ 0.424056] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.424065] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.424067] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.424070] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.424072] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000effff] (subtractive decode)
[ 0.424075] pci 0000:00:1e.0: bridge window [mem 0x000f0000-0x000fffff] (subtractive decode)
[ 0.424077] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfec00000] (subtractive decode)
[ 0.424080] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xdfffffff] (subtractive decode)
[ 0.424082] pci 0000:00:1e.0: bridge window [mem 0xff980000-0xff980fff] (subtractive decode)
[ 0.424084] pci 0000:00:1e.0: bridge window [mem 0xff97c000-0xff97ffff] (subtractive decode)
[ 0.424087] pci 0000:00:1e.0: bridge window [mem 0xfed20000-0xfed9ffff] (subtractive decode)
[ 0.424089] pci 0000:00:1e.0: bridge window [mem 0xfeda7000-0xfeda7fff] (subtractive decode)
[ 0.424105] pci_bus 0000:00: on NUMA node 0
[ 0.424108] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.424834] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI4._PRT]
[ 0.425285] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
[ 0.425500] ACPI Warning: For \_SB_.PCI0.PCI2._PRT: Return Package has no elements (empty) (20120320/nspredef-463)
[ 0.425563] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI3._PRT]
[ 0.425895] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.426308] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 2.321878] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 2.322670] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 2.323447] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 2.324347] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 2.325128] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 2.325906] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 2.326696] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 2.327473] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 2.328159] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 2.328172] vgaarb: loaded
[ 2.328173] vgaarb: bridge control possible 0000:00:02.0
[ 2.328200] PCI: Using ACPI for IRQ routing
[ 2.333339] PCI: pci_cache_line_size set to 64 bytes
[ 2.333351] pci 0000:00:03.0: no compatible bridge window for [mem 0xfeda6000-0xfeda600f 64bit]
[ 2.333383] pci 0000:00:1f.2: no compatible bridge window for [mem 0xff970000-0xff9707ff]
[ 2.333422] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 2.333425] reserve RAM buffer: 000000000009e400 - 000000000009ffff
[ 2.333427] reserve RAM buffer: 000000007bbffc00 - 000000007bffffff
[ 2.333552] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 2.333560] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 2.335578] Switching to clocksource hpet
[ 2.336146] pnp: PnP ACPI init
[ 2.336146] ACPI: bus type pnp registered
[ 2.345382] pnp 00:00: [bus 00-ff]
[ 2.345385] pnp 00:00: [io 0x0cf8-0x0cff]
[ 2.345387] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 2.345390] pnp 00:00: [io 0x0d00-0xffff window]
[ 2.345392] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 2.345394] pnp 00:00: [mem 0x000c0000-0x000effff window]
[ 2.345396] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 2.345398] pnp 00:00: [mem 0xf0000000-0xfec00000 window]
[ 2.345402] pnp 00:00: [mem 0x80000000-0xdfffffff window]
[ 2.345404] pnp 00:00: [mem 0xf0000000-0xefffffff window disabled]
[ 2.345406] pnp 00:00: [mem 0xff980000-0xff980fff window]
[ 2.345409] pnp 00:00: [mem 0xff97c000-0xff97ffff window]
[ 2.345411] pnp 00:00: [mem 0xfed20000-0xfed9ffff window]
[ 2.345413] pnp 00:00: [mem 0xfeda7000-0xfeda7fff window]
[ 2.345444] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 2.349282] pnp 00:01: [io 0x0060]
[ 2.349285] pnp 00:01: [io 0x0064]
[ 2.349287] pnp 00:01: [io 0x0062-0x0063]
[ 2.349289] pnp 00:01: [io 0x0065-0x006f]
[ 2.349290] pnp 00:01: [io 0x00e0-0x00ef]
[ 2.349292] pnp 00:01: [io 0x0800-0x085f]
[ 2.349294] pnp 00:01: [io 0x0c00-0x0c7f]
[ 2.349296] pnp 00:01: [io 0x0860-0x08ff]
[ 2.349340] system 00:01: [io 0x0800-0x085f] has been reserved
[ 2.349343] system 00:01: [io 0x0c00-0x0c7f] has been reserved
[ 2.349346] system 00:01: [io 0x0860-0x08ff] has been reserved
[ 2.349349] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 2.349629] pnp 00:02: [io 0x0080-0x009f]
[ 2.349631] pnp 00:02: [io 0x0000-0x001f]
[ 2.349633] pnp 00:02: [io 0x00c0-0x00df]
[ 2.349636] pnp 00:02: [dma 4]
[ 2.349660] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 2.349879] pnp 00:03: [io 0x00f0-0x00ff]
[ 2.349887] pnp 00:03: [irq 13]
[ 2.349910] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 2.350117] pnp 00:04: [io 0x0061]
[ 2.350141] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 2.350354] pnp 00:05: [io 0x0070-0x007f]
[ 2.350359] pnp 00:05: [irq 8]
[ 2.350384] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 2.364989] pnp 00:06: [io 0x0378-0x037f]
[ 2.364992] pnp 00:06: [io 0x0778-0x077f]
[ 2.364997] pnp 00:06: [irq 7]
[ 2.364999] pnp 00:06: [dma 0 disabled]
[ 2.366199] pnp 00:06: Plug and Play ACPI device, IDs PNP0401 (active)
[ 2.371370] pnp 00:07: [io 0x03f8-0x03ff]
[ 2.371375] pnp 00:07: [irq 4]
[ 2.371781] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 2.386327] pnp 00:08: [mem 0xfed00000-0xfed003ff]
[ 2.386360] pnp 00:08: Plug and Play ACPI device, IDs PNP0103 (active)
[ 2.386368] pnp: PnP ACPI: found 9 devices
[ 2.386370] ACPI: ACPI bus type pnp unregistered
[ 2.386373] PnPBIOS: Disabled by ACPI PNP
[ 2.422873] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
[ 2.422877] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 2.422885] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000
[ 2.422888] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 2.422901] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 2.422903] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 2.422906] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 2.422908] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 2.422913] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf0000000-0xf01fffff 64bit pref]
[ 2.422916] pci 0000:00:1c.1: BAR 15: assigned [mem 0xf0200000-0xf03fffff 64bit pref]
[ 2.422919] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.422922] pci 0000:00:1c.1: BAR 13: assigned [io 0x2000-0x2fff]
[ 2.422925] pci 0000:00:1f.2: BAR 5: assigned [mem 0xf0400000-0xf04007ff]
[ 2.422930] pci 0000:00:03.0: BAR 0: assigned [mem 0xf0400800-0xf040080f 64bit]
[ 2.422938] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 2.422941] pci 0000:00:01.0: bridge window [mem 0xfe500000-0xfe5fffff]
[ 2.422947] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 2.422949] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 2.422954] pci 0000:00:1c.0: bridge window [mem 0xfe400000-0xfe4fffff]
[ 2.422958] pci 0000:00:1c.0: bridge window [mem 0xf0000000-0xf01fffff 64bit pref]
[ 2.422964] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 2.422966] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 2.422971] pci 0000:00:1c.1: bridge window [mem 0xfe300000-0xfe3fffff]
[ 2.422975] pci 0000:00:1c.1: bridge window [mem 0xf0200000-0xf03fffff 64bit pref]
[ 2.422980] pci 0000:00:1e.0: PCI bridge to [bus 04-04]
[ 2.423016] pci 0000:00:1e.0: setting latency timer to 64
[ 2.423020] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 2.423022] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 2.423024] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 2.423026] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000effff]
[ 2.423028] pci_bus 0000:00: resource 8 [mem 0x000f0000-0x000fffff]
[ 2.423031] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfec00000]
[ 2.423033] pci_bus 0000:00: resource 10 [mem 0x80000000-0xdfffffff]
[ 2.423035] pci_bus 0000:00: resource 11 [mem 0xff980000-0xff980fff]
[ 2.423037] pci_bus 0000:00: resource 12 [mem 0xff97c000-0xff97ffff]
[ 2.423039] pci_bus 0000:00: resource 13 [mem 0xfed20000-0xfed9ffff]
[ 2.423041] pci_bus 0000:00: resource 14 [mem 0xfeda7000-0xfeda7fff]
[ 2.423044] pci_bus 0000:01: resource 1 [mem 0xfe500000-0xfe5fffff]
[ 2.423046] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 2.423048] pci_bus 0000:02: resource 1 [mem 0xfe400000-0xfe4fffff]
[ 2.423050] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf01fffff 64bit pref]
[ 2.423053] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 2.423055] pci_bus 0000:03: resource 1 [mem 0xfe300000-0xfe3fffff]
[ 2.423057] pci_bus 0000:03: resource 2 [mem 0xf0200000-0xf03fffff 64bit pref]
[ 2.423059] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7]
[ 2.423061] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff]
[ 2.423063] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff]
[ 2.423065] pci_bus 0000:04: resource 7 [mem 0x000c0000-0x000effff]
[ 2.423068] pci_bus 0000:04: resource 8 [mem 0x000f0000-0x000fffff]
[ 2.423070] pci_bus 0000:04: resource 9 [mem 0xf0000000-0xfec00000]
[ 2.423072] pci_bus 0000:04: resource 10 [mem 0x80000000-0xdfffffff]
[ 2.423074] pci_bus 0000:04: resource 11 [mem 0xff980000-0xff980fff]
[ 2.423076] pci_bus 0000:04: resource 12 [mem 0xff97c000-0xff97ffff]
[ 2.423078] pci_bus 0000:04: resource 13 [mem 0xfed20000-0xfed9ffff]
[ 2.423080] pci_bus 0000:04: resource 14 [mem 0xfeda7000-0xfeda7fff]
[ 2.423142] NET: Registered protocol family 2
[ 2.423204] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 2.423352] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 2.423624] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 2.423754] TCP: Hash tables configured (established 131072 bind 65536)
[ 2.423756] TCP: reno registered
[ 2.423759] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 2.423765] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 2.423842] NET: Registered protocol family 1
[ 2.423855] pci 0000:00:02.0: Boot video device
[ 2.424071] PCI: CLS 64 bytes, default 64
[ 2.424108] Unpacking initramfs...
[ 2.662165] Freeing initrd memory: 13700k freed
[ 2.667170] Simple Boot Flag at 0x7a set to 0x1
[ 2.667601] audit: initializing netlink socket (disabled)
[ 2.667616] type=2000 audit(1531627140.660:1): initialized
[ 2.677420] highmem bounce pool size: 64 pages
[ 2.677425] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 2.677578] VFS: Disk quotas dquot_6.5.2
[ 2.677602] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.677676] msgmni has been set to 1722
[ 2.677823] alg: No test for stdrng (krng)
[ 2.677847] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 2.677851] io scheduler noop registered
[ 2.677853] io scheduler deadline registered
[ 2.677868] io scheduler cfq registered (default)
[ 2.678086] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 2.678102] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 2.678104] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 2.678689] GHES: HEST is not enabled!
[ 2.678700] isapnp: Scanning for PnP cards...
[ 3.031480] isapnp: No Plug & Play device found
[ 3.031530] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 3.051878] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 3.072484] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 3.092668] 0000:00:03.3: ttyS1 at I/O 0xec98 (irq = 17) is a 16550A
[ 3.092999] Linux agpgart interface v0.103
[ 3.093113] agpgart-intel 0000:00:00.0: Intel Q45/Q43 Chipset
[ 3.093166] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[ 3.093988] agpgart-intel 0000:00:00.0: detected 32768K stolen memory
[ 3.094093] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 3.094211] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 3.097109] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 3.097136] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 3.097229] mousedev: PS/2 mouse device common for all mice
[ 3.097269] rtc_cmos 00:05: RTC can wake from S4
[ 3.097379] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 3.097402] rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
[ 3.097517] TCP: cubic registered
[ 3.097567] NET: Registered protocol family 10
[ 3.097767] Mobile IPv6
[ 3.097769] NET: Registered protocol family 17
[ 3.097773] Registering the dns_resolver key type
[ 3.097825] Using IPI No-Shortcut mode
[ 3.097912] PM: Hibernation image not present or could not be loaded.
[ 3.097923] registered taskstats version 1
[ 3.098283] rtc_cmos 00:05: setting system clock to 2018-07-15 03:59:01 UTC (1531627141)
[ 3.098369] Freeing unused kernel memory: 416k freed
[ 3.098509] Write protecting the kernel text: 3496k
[ 3.098529] Write protecting the kernel read-only data: 984k
[ 3.107691] udevd[49]: starting version 175
[ 3.122731] usbcore: registered new interface driver usbfs
[ 3.122757] usbcore: registered new interface driver hub
[ 3.130224] microcode: CPU0 sig=0x1067a, pf=0x1, revision=0xa07
[ 3.140114] usbcore: registered new device driver usb
[ 3.140543] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.140607] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 3.140611] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 3.140633] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 3.140659] ehci_hcd 0000:00:1a.7: debug port 1
[ 3.147124] SCSI subsystem initialized
[ 3.149619] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 3.149622] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 3.156338] uhci_hcd: USB Universal Host Controller Interface driver
[ 3.160166] libata version 3.00 loaded.
[ 3.164282] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[ 3.164308] ehci_hcd 0000:00:1a.7: irq 22, io mem 0xfe6da000
[ 3.176114] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 3.176142] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.176145] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.176147] usb usb1: Product: EHCI Host Controller
[ 3.176149] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 3.176151] usb usb1: SerialNumber: 0000:00:1a.7
[ 3.176251] hub 1-0:1.0: USB hub found
[ 3.176257] hub 1-0:1.0: 6 ports detected
[ 3.176373] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 3.176377] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 3.176386] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 3.176410] ehci_hcd 0000:00:1d.7: debug port 1
[ 3.180310] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 3.180462] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xff980000
[ 3.188355] microcode: CPU0 updated to revision 0xa0b, date = 2010-09-28
[ 3.189362] microcode: CPU1 sig=0x1067a, pf=0x1, revision=0xa07
[ 3.195342] microcode: CPU1 updated to revision 0xa0b, date = 2010-09-28
[ 3.196152] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 3.196189] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.196192] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.196194] usb usb2: Product: EHCI Host Controller
[ 3.196196] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 3.196198] usb usb2: SerialNumber: 0000:00:1d.7
[ 3.196311] hub 2-0:1.0: USB hub found
[ 3.196315] hub 2-0:1.0: 6 ports detected
[ 3.196766] e1000e 0000:00:19.0: setting latency timer to 64
[ 3.196820] e1000e 0000:00:19.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 3.197113] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 3.388089] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) 00:21:9b:1a:d3:a7
[ 3.388092] e1000e 0000:00:19.0: eth0: Intel(R) PRO/1000 Network Connection
[ 3.388123] e1000e 0000:00:19.0: eth0: MAC: 8, PHY: 8, PBA No: 8021FF-0FF
[ 3.388150] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 3.388153] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 3.388162] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 3.388195] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[ 3.388227] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.388229] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.388231] usb usb3: Product: UHCI Host Controller
[ 3.388233] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.388235] usb usb3: SerialNumber: 0000:00:1a.0
[ 3.388339] hub 3-0:1.0: USB hub found
[ 3.388343] hub 3-0:1.0: 2 ports detected
[ 3.388419] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 3.388423] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 3.388430] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 3.388460] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[ 3.388488] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.388490] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.388493] usb usb4: Product: UHCI Host Controller
[ 3.388494] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.388497] usb usb4: SerialNumber: 0000:00:1a.1
[ 3.388654] hub 4-0:1.0: USB hub found
[ 3.388658] hub 4-0:1.0: 2 ports detected
[ 3.388732] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[ 3.388735] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 3.388742] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[ 3.388763] uhci_hcd 0000:00:1a.2: irq 22, io base 0x0000fc00
[ 3.388792] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.388794] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.388796] usb usb5: Product: UHCI Host Controller
[ 3.388798] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.388800] usb usb5: SerialNumber: 0000:00:1a.2
[ 3.389155] hub 5-0:1.0: USB hub found
[ 3.389160] hub 5-0:1.0: 2 ports detected
[ 3.389241] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 3.389244] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 3.389252] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[ 3.389274] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[ 3.389303] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.389306] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.389308] usb usb6: Product: UHCI Host Controller
[ 3.389310] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.389312] usb usb6: SerialNumber: 0000:00:1d.0
[ 3.389526] hub 6-0:1.0: USB hub found
[ 3.389530] hub 6-0:1.0: 2 ports detected
[ 3.389603] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 3.389606] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 3.389613] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[ 3.389634] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[ 3.389663] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.389666] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.389668] usb usb7: Product: UHCI Host Controller
[ 3.389669] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.389672] usb usb7: SerialNumber: 0000:00:1d.1
[ 3.389767] hub 7-0:1.0: USB hub found
[ 3.389771] hub 7-0:1.0: 2 ports detected
[ 3.389843] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 3.389846] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 3.389853] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[ 3.389885] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 3.389914] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.389917] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.389919] usb usb8: Product: UHCI Host Controller
[ 3.389921] usb usb8: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.389923] usb usb8: SerialNumber: 0000:00:1d.2
[ 3.390024] hub 8-0:1.0: USB hub found
[ 3.390028] hub 8-0:1.0: 2 ports detected
[ 3.390258] ata_generic 0000:00:03.2: setting latency timer to 64
[ 3.391357] scsi0 : ata_generic
[ 3.392628] scsi1 : ata_generic
[ 3.392678] ata1: PATA max UDMA/100 cmd 0xfe80 ctl 0xfe90 bmdma 0xfef0 irq 18
[ 3.392681] ata2: PATA max UDMA/100 cmd 0xfea0 ctl 0xfeb0 bmdma 0xfef8 irq 18
[ 3.392723] ahci 0000:00:1f.2: version 3.0
[ 3.392814] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x23 impl SATA mode
[ 3.392817] ahci 0000:00:1f.2: flags: 64bit ncq sntf led clo pio ems sxs
[ 3.392822] ahci 0000:00:1f.2: setting latency timer to 64
[ 3.408793] scsi2 : ahci
[ 3.408877] scsi3 : ahci
[ 3.408950] scsi4 : ahci
[ 3.409018] scsi5 : ahci
[ 3.409086] scsi6 : ahci
[ 3.409151] scsi7 : ahci
[ 3.410732] ata3: SATA max UDMA/133 abar m2048@0xf0400000 port 0xf0400100 irq 18
[ 3.410735] ata4: SATA max UDMA/133 abar m2048@0xf0400000 port 0xf0400180 irq 18
[ 3.410737] ata5: DUMMY
[ 3.410739] ata6: DUMMY
[ 3.410740] ata7: DUMMY
[ 3.410742] ata8: SATA max UDMA/133 abar m2048@0xf0400000 port 0xf0400380 irq 18
[ 3.664019] Refined TSC clocksource calibration: 2792.999 MHz.
[ 3.664026] Switching to clocksource tsc
[ 3.700015] usb 6-1: new low-speed USB device number 2 using uhci_hcd
[ 3.728023] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 3.728043] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.729184] ata4.00: ATAPI: HL-DT-ST DVD+/-RW GT10N, A104, max UDMA/100
[ 3.731989] ata4.00: configured for UDMA/100
[ 3.732018] ata8: SATA link down (SStatus 0 SControl 300)
[ 3.768654] ata3.00: ATA-7: ST3160812AS, 3.AAE, max UDMA/133
[ 3.768658] ata3.00: 312581808 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 3.826957] ata3.00: configured for UDMA/133
[ 3.827107] scsi 2:0:0:0: Direct-Access ATA ST3160812AS 3.AA PQ: 0 ANSI: 5
[ 3.843366] scsi 3:0:0:0: CD-ROM HL-DT-ST DVD+-RW GT10N A104 PQ: 0 ANSI: 5
[ 3.848486] sd 2:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 3.848545] sd 2:0:0:0: [sda] Write Protect is off
[ 3.848548] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.848574] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.865484] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.865489] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.865742] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 3.886439] sda: sda1 sda2 < sda5 >
[ 3.886774] sd 2:0:0:0: [sda] Attached SCSI disk
[ 3.888328] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 3.888362] sr 3:0:0:0: Attached scsi generic sg1 type 5
[ 3.927315] usb 6-1: New USB device found, idVendor=0e8f, idProduct=00a8
[ 3.927321] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.927325] usb 6-1: Product: 2.4G RX
[ 3.927328] usb 6-1: Manufacturer: DaKai
[ 3.946823] input: DaKai 2.4G RX as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input0
[ 3.946869] generic-usb 0003:0E8F:00A8.0001: input,hidraw0: USB HID v1.10 Keyboard [DaKai 2.4G RX] on usb-0000:00:1d.0-1/input0
[ 3.979318] input: DaKai 2.4G RX as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.1/input/input1
[ 3.979423] generic-usb 0003:0E8F:00A8.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [DaKai 2.4G RX] on usb-0000:00:1d.0-1/input1
[ 3.979843] usbcore: registered new interface driver usbhid
[ 3.979846] usbhid: USB HID core driver
[ 9.153020] PM: Starting manual resume from disk
[ 9.153023] PM: Hibernation image partition 8:5 present
[ 9.153024] PM: Looking for hibernation image.
[ 9.153184] PM: Image not found (code -22)
[ 9.153187] PM: Hibernation image not present or could not be loaded.
[ 9.188810] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.141529] udevd[389]: starting version 175
[ 11.511824] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 11.511831] ACPI: Power Button [VBTN]
[ 11.511892] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 11.511895] ACPI: Power Button [PWRF]
[ 11.859491] wmi: Mapper loaded
[ 11.951897] input: Dell WMI hotkeys as /devices/virtual/input/input4
[ 12.151380] [drm] Initialized drm 1.1.0 20060810
[ 12.320116] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input5
[ 12.322229] i915 0000:00:02.0: setting latency timer to 64
[ 12.334487] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 12.334490] [drm] Driver supports precise vblank timestamp query.
[ 12.334529] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 12.351811] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 12.354179] iTCO_vendor_support: vendor-support=0
[ 12.358023] parport_pc 00:06: reported by Plug and Play ACPI
[ 12.358075] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 12.415288] fbcon: inteldrmfb (fb0) is primary device
[ 12.462428] Console: switching to colour frame buffer device 240x67
[ 12.463049] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 12.463139] iTCO_wdt: Found a ICH10D TCO device (Version=2, TCOBASE=0x0860)
[ 12.463283] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 12.468843] fb0: inteldrmfb frame buffer device
[ 12.468845] drm: registered panic notifier
[ 12.468879] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 13.959571] Adding 4051964k swap on /dev/sda5. Priority:-1 extents:1 across:4051964k
[ 13.970243] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 14.203607] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 14.290712] loop: module loaded
[ 15.446822] RPC: Registered named UNIX socket transport module.
[ 15.446825] RPC: Registered udp transport module.
[ 15.446827] RPC: Registered tcp transport module.
[ 15.446828] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 15.474175] FS-Cache: Loaded
[ 15.515431] NFS: Registering the id_resolver key type
[ 15.515446] FS-Cache: Netfs 'nfs' registered for caching
[ 15.520607] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 17.480658] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input6
[ 19.397141] Bluetooth: Core ver 2.16
[ 19.397158] NET: Registered protocol family 31
[ 19.397160] Bluetooth: HCI device and connection manager initialized
[ 19.397163] Bluetooth: HCI socket layer initialized
[ 19.397164] Bluetooth: L2CAP socket layer initialized
[ 19.397169] Bluetooth: SCO socket layer initialized
[ 19.420842] Bluetooth: RFCOMM TTY layer initialized
[ 19.420847] Bluetooth: RFCOMM socket layer initialized
[ 19.420849] Bluetooth: RFCOMM ver 1.11
[ 19.428107] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.428110] Bluetooth: BNEP filters: protocol multicast
[ 19.744759] lp0: using parport0 (interrupt-driven).
[ 19.846235] ppdev: user-space parallel port driver
[ 21.638479] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 24.487012] e1000e 0000:00:19.0: eth0: MAC Wakeup cause - Unicast Packet
[ 26.892911] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 26.893021] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 37.904013] eth0: no IPv6 routers present
[ 446.204165] I-pipe: head domain RTAI registered.
[ 446.204170] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 446.204194] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 446.204197] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2792835000, CPU_FREQ 2792835000
[ 446.204199] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 446.204202] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16603250
[ 446.246862] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 446.246888] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 446.246891] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 446.246894] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2792835000 hz.
[ 446.246896] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 446.268669] RTAI[math]: loaded.
[ 446.461196] config string '348h out'
[ 446.461207] PARPORT: ERROR: request_region(0xffff) failed
[ 448.840829] RTAI[math]: unloaded.
[ 448.842064] SCHED releases registered named ALIEN PEDV$D
[ 448.844080] RTAI[malloc]: unloaded.
[ 448.944018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 448.945444] I-pipe: head domain RTAI unregistered.
[ 448.945477] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
TASK=milltask
HALUI=
DISPLAY=axis
3649
[ 0.229571] dummy:
- Thank you received: 7490
15 Jul 2018 06:01 #114198
Replied by tommylight on topic LinuxCNC terminated with errors
You have the parallel port address set as 0x348, it should be set at ox378.
The following user(s) said Thank You: CNCKoala
- CNCKoala
15 Jul 2018 06:31 #114200
by CNCKoala
Replied by CNCKoala on topic LinuxCNC terminated with errors
Thank you tommylight. I had been putting the parallel address in as 378h( typo 348h) as reported by the bios.
modified this to just 378 and it now talks to everything correctly, well almost there is still an issue with 'Z' axis that I will work on later.
Time to create page: 0.171 seconds
