- LinuxCNC
- Installing LinuxCNC
- Struggling to install 2.7 onto my ancient Dell Dimension 8200. Any suggestions?
- berntd
26 Aug 2018 04:28 #116593
by berntd
Struggling to install 2.7 onto my ancient Dell Dimension 8200. Any suggestions? was created by berntd
That old Dell machine It is running 2.5 but is full of issues.
So I downloaded the latest ISO file and burned it to a DVD.. Only to find the Dell only has a CD drive not DVD.
The image is too big to fit onto a CD!!
Next burned the ISO onto a USB stick. It took over an hour with dd under Cygwin...
Only to find that the Dell cannot boot from USB.
I am not an expert. I must have installed 2.5 years ago from a CD. I can't remember.
What can I do now to get 2.7 on there?
It still boots into Ubuntu 2.5 if that is of any use.
Any suggestions are greatly appreciated as I want to keep using that machine.
- Thank you received: 7490
26 Aug 2018 06:27 #116594
Replied by tommylight on topic Struggling to install 2.7 onto my ancient Dell Dimension 8200. Any suggestions?
There are several boot managers on the net to help boot a usb on computers that can not do that, just search for it, like plop boot manager and some others, i can not recall the naming, it has been quite some time.
- berntd
26 Aug 2018 06:41 - 26 Aug 2018 06:43 #116596
by berntd
Replied by berntd on topic Struggling to install 2.7 onto my ancient Dell Dimension 8200. Any suggestions?
I have since created a a new bootable partition on the spare part of the hard drive and then installed the iso image into it with dd...
I now wonder if / how I can swap to boot from that new partition at all?
And will I then be able to install into the old partition?
This thing dowes not have grub2 and not even grub.
I can't get it connected to the internet either to install stuff.
Regards
Bernt
Regards
Bernt
Last edit: 26 Aug 2018 06:43 by berntd.
- Thank you received: 1480
26 Aug 2018 22:50 - 26 Aug 2018 22:56 #116625
The images that were used with 2.5 were Ubuntu 10.04 and fit on a CD. It is possible to update that to Linuxcnc 2.7 using apt-get or Synaptic. I still have one machine running that OS version with the current release of Linuxcnc. It has been updated several times and started with 2.4.
Replied by Todd Zuercher on topic Struggling to install 2.7 onto my ancient Dell Dimension 8200. Any suggestions?
Last edit: 26 Aug 2018 22:56 by Todd Zuercher.
29 Aug 2018 16:05 #116779
You should be able to just upgrade.
linuxcnc.org/docs/2.7/html/getting-start...dating-linuxcnc.html
Replied by andypugh on topic Struggling to install 2.7 onto my ancient Dell Dimension 8200. Any suggestions?
- LinuxCNC
Time to create page: 0.101 seconds
