Install on new hard drive or one with windows on it?
- i_r_machinist
10 Nov 2018 15:58 #120397
by i_r_machinist
Install on new hard drive or one with windows on it? was created by i_r_machinist
I have a computer with windows os on it. Will Linux cnc write over it? Do I need to wipe the hard drive somehow? Would it be better to buy a new hard drive with nothing on it?
As the username implies, i_r_machinist, not computer guy.
thanks in advance
i_r_
thanks in advance
i_r_
- Thank you received: 7490
10 Nov 2018 16:18 #120399
Replied by tommylight on topic Install on new hard drive or one with windows on it?
It should not write over it if you DO NOT choose the "use entire disk" option.
Usually the default choice on the Linux installers is to install side by side with windows.
Or you can use the live boot till you get more comfortable with Linuxcnc or till you get another drive.
The following user(s) said Thank You: i_r_machinist
- Thank you received: 1480
10 Nov 2018 18:20 #120410
Replied by Todd Zuercher on topic Install on new hard drive or one with windows on it?
It usually can if you want it to. The exception is if the computer is set up to not allow it.
If you don't want to overwrite Windows usually you will need to resize the windows partition to make room.
- i_r_machinist
11 Nov 2018 14:10 #120442
by i_r_machinist
Replied by i_r_machinist on topic Install on new hard drive or one with windows on it?
I chose to "use entire disc" on installation. Everthing seems fine. I have a machine format up now and watching youtube to step my way through.
Thanks for the help!
i_r_
i_r_
11 Nov 2018 19:47 #120456
That will erase everything on that disk !!!
