ROLL BACK TO PREVIOUS 2.8 VERSION
- COlger81
- Thank you received: 6
16 Nov 2018 21:32 #120866
by COlger81
ROLL BACK TO PREVIOUS 2.8 VERSION was created by COlger81
Can someone provide a link to where i can download an older version of 2.8? pre1-4040 has many Gmoccapy issues. Seems like some drastic changes were pushed through in Gmoccapy the other day in a hurry.
- Thank you received: 1480
16 Nov 2018 22:17 #120868
Replied by Todd Zuercher on topic ROLL BACK TO PREVIOUS 2.8 VERSION
You can use Synaptic to force the version easily.
(I'm certain there are ways using apt-get and the command line, but I'd have to look them up.
- Thank you received: 2181
16 Nov 2018 22:45 #120871
Replied by cmorley on topic ROLL BACK TO PREVIOUS 2.8 VERSION
Since thee are no released versions of master(2.8), I'm pretty sure you would need to compile a particular version.
Chris M
Chris M
17 Nov 2018 02:51 - 17 Nov 2018 03:01 #120883
Buidbot.linux has back to 2.8pre1-3932 right now. So if that is back far enough for you, you won't have to build from source.
Last edit: 17 Nov 2018 03:01 by Todd Zuercher.
- COlger81
17 Nov 2018 03:13 #120886
by COlger81
Replied by COlger81 on topic ROLL BACK TO PREVIOUS 2.8 VERSION
Thank you, i rolled back to 3932 and it works without issue.
19 Nov 2018 15:46 #120997
Replied by andypugh on topic ROLL BACK TO PREVIOUS 2.8 VERSION
Are the issues that you found mentioned in the bug-tracker?
- COlger81
19 Nov 2018 15:48 #120998
by COlger81
Norbert has already made the necessary fixes to code. It was a merge issue.
- COlger81
19 Nov 2018 16:13 #121004
by COlger81
Also posted a question on this link.
forum.linuxcnc.org/10-advanced-configura...indle-gearing-config
Time to create page: 0.175 seconds
