Not a bug report
- grump
- Thank you received: 10
27 Dec 2018 12:14 #122952
by grump
Not a bug report was created by grump
Hi guys, and seasons greetings. I haven't been on the forum much lately as I haven't had any issues or been able to assist in any way.
Until now that is???
I have been using, testing, playing with www.linuxcnc.org/testing-stretch-rtpreempt/ from pretty much day one of it being there and always kept up with the latest version.
I think it currently dishes out version 2.7.14 but I could be wrong, whatever, it works flawlessly for me and I love it.
Recently, in fact, yesterday I did an apt-get upgrade for another reason and it pulled down version 2.8.0-pre1-4081-g48726d6ea.
Fine I thought, I have used the testing 2.8 versions before and known no difference, all worked well.
Unfortunately for me, this version plays havoc with my A axis, "joint3 following error" is the warning but no specific error is given.
I have attached a pic of the line it stalls on and I have to skip a line to resume.
I have also added sample files if anyone wants to replicate the issue. File 1.ngc works perfectly but when wrapped for rotary as in 1_wrap.ngc it gives muchly grief.
And this is an issue through all my wrap files which work perfectly well in all previous versions.
Any thoughts other than going back to the install version which of course I have done?
- Thank you received: 5330
27 Dec 2018 17:41 #122963
Replied by PCW on topic Not a bug report
It might be useful to plot the following error with halscope to get a handle on whats going wrong here.
- grump
28 Dec 2018 11:57 #123007
by grump
Replied by grump on topic Not a bug report
Like I said the message points to no specific error for tracing.
I am not looking to fault find but having found one, bringing it to attention without knowing where to file a bug report and supplying the means to replicate the error for anyone who does wish to trace it.
Sorry if that comes across as impertinent, it's not intended to be.
28 Dec 2018 12:17 - 28 Dec 2018 12:20 #123009
A following error _is_ a specific plottable error
That is you can trigger halscope on the following error to get
some idea of whats going wrong.
If you "halscope" joint.3.f-error and trigger on joint.3.f-errored
you should get a lot more information than just the fault popup.
Its probably useful to plot joint.3.vel-cmd at the same time
Last edit: 28 Dec 2018 12:20 by PCW.
- grump
28 Dec 2018 12:43 #123011
by grump
Thank you for that information. I won't take the trouble to trace errors It's easier to use the stable version which works just fine.
Whatever the issue is, it's intentional as today's upgrade also has it.
28 Dec 2018 13:50 #123017
OK I'm a bit confused here, Your hal and ini files are LinuxCNC 2.7 version files (using Axis not joints)
- grump
28 Dec 2018 18:25 #123025
by grump
Oops, a senior moment between machines.
Of course, the upgrade overwrites them, here are the new ones.
- newbynobi
- Thank you received: 394
28 Dec 2018 22:28 #123039
by newbynobi
Replied by newbynobi on topic Not a bug report
Your old 2.7 config has a MinFerror of 0.25 for A
The new 2.8 config has a MinFerror of 0.10 for A
If you change the value, you will have the same behavior in both configs!
Norbert
Norbert
- grump
29 Dec 2018 10:16 #123062
by grump
Thanks but actually it made no difference whatsoever that was only where I had previously been changing due to reading false information about the error.
The behavior remains the same regardless of those values but from the little research I had done the advice was to change them.
- pl7i92
- Thank you received: 358
30 Dec 2018 15:26 #123154
by pl7i92
Replied by pl7i92 on topic Not a bug report
upgreating to 2.8 is not recomended is this a real Gantry so a need for double axis homing
why dident you stay with 2.7.14
Time to create page: 0.151 seconds
