Pncconf on Linux Mint 19
7 years 5 months ago #132517 by HueyHQ
Replied by HueyHQ on topic LinuxCNC on Linux Mint 19
I think I manage to solve this. I can now use the PNCConf Wizard without an error.
Being a Linux noob, I tried a very Windows solution, by copying the hm2 folder from an installation of stretch from another computer on to a USB (might work for a live CD), then copy to the /lib/firmware folder on the Mint install.
For those also not familiar with Linux (like me), use the command
sudo mv /media/src /lib/firmware
(I'm not 100% sure about the source and destination parameters.)
Hope it helps.
7 years 5 months ago #132519 by pl7i92
Replied by pl7i92 on topic LinuxCNC on Linux Mint 19
the 7i77 needs to be powerd so the 5i25 and the pnconf can detact it to be configurated
there is a simple ZIP file that makes all setup of the 5i25 to pncconf
or better follow the instructions in the 5i25 file folder from mesa download
NO NEED to Copy things around
or even move from SCR
7 years 5 months ago #132707 by HueyHQ
OK, cool, thanks!
pl7i92 wrote: the 7i77 needs to be powerd so the 5i25 and the pnconf can detact it to be configurated
I read somewhere on here, and have tried it myself, that you can run and configure PNCConf without the 7i77 attached - maybe even the 5i25. But you certainly can't access the I/O without them!
For noobs like me:
Yep, as pl7i92 says, there is a ZIP file at store.mesanet.com .
Navigate to Anything I/O Cards -> Anything I/O FPGA Cards -> 5I25 Superport FPGA based PCI Anything I/O card.
Scroll down a little, and click on Specification, and click Download Support Software to grab the 5i25.zip file
In the terminal, change to the where the zip file is, e.g.:
cd ~/Downloads/
and unzip the firmware to /lib/firmware:
sudo unzip -d /lib/firmware/hm2 5i25.zip
This will put the files where they need to be, and create the hm2 folder if necessary.
There is also a sserial download on the 7i77 product page if you use it; I don't, but just follow the README in the zip file.
Please excuse me if I seem like I'm being a dick by spelling everything out, but it really helps when one is not familiar with Linux. I relish the learning experience to an extent, but it will certainly help me out as a reference for later, and maybe even help others!
6 years 8 months ago #158744 by Moronicsmurf
This might be resurrecting an old thread.
But it might be useful to someone.. So i installed linuxmint 19, compiled a 4.19 kernel and compiled 2.8 uspace lcnc and ran into the same "missing hm2 firmware" thing..
But just by creating the folder.
That error goes away and the pncconf utility will continue and you have the 5i25/6i25 option, the 7i92, 7i76e, 7i96, 7i80HD, 7i93 is also there. Which i would think is the most common options for most users.
This runs well on a Celeron J1900 with 8gb of ram.
  • BeagleBrainz
  • New Member
  • New Member
6 years 8 months ago #158745 by BeagleBrainz
Replied by BeagleBrainz on topic LinuxCNC on Linux Mint 19
Or you can download the firmware and mesaflash from here:
www.linuxcnc.org/dists/stretch/base/binary-amd64/
No need to download and install hostmot2-firmware-all and that is just a meta package that has all the others as dependencies.
And use gdebi to install the firmware packages and mesaflash.
6 years 8 months ago #158758 by Moronicsmurf
Problem is that those packages dont work running lcnc on mint in uspace you get an error stating
"LinuxCNCVersion: UNAVAILABLE" with a traceback error.
The following user(s) said Thank You: BeagleBrainz
Time to create page: 0.351 seconds
