D525MW with Mesa 5i25/7i76 suitable for Debian Stretch LinuxCNC Uspace? <solved>
11 May 2019 16:22 #133455 by JustPlaneSweet
I could use a little help. I upgraded my D525MW with 8Gb ram and a 250Gb SSD. I tried the instructions at gnipsel.com/linuxcnc/uspace/index.html for both Linux Mint 19.1 RT and Debian 9 RT and can not get the system to use the Mesa card. My last attempt, currently installed, is the Live/Install for Debian Stretch, RT-PREEMPT, LinuxCNC 2.7.x located here. I chose the linuxcnc-stretch-uspace-amd64.iso image and installed from a bootable usb drive.
I ran PNCconf and and configured the system the same as before the upgrade. When I started LinuxCNC I received the following error:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
Machine configuration directory is '/home/stan/linuxcnc/configs/Mesa'
Machine configuration file is 'Mesa.ini'
INIFILE=/home/stan/linuxcnc/configs/Mesa/Mesa.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Mesa.hal
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:05:00.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 38
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0:     IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 010 (P3-07): IOPort
hm2/hm2_5i25.0:     IO Pin 011 (P3-08): IOPort
hm2/hm2_5i25.0:     IO Pin 012 (P3-09): IOPort
hm2/hm2_5i25.0:     IO Pin 013 (P3-10): IOPort
hm2/hm2_5i25.0:     IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
hm2/hm2_5i25.0:     IO Pin 015 (P3-12): Encoder #0, pin B (Input)
hm2/hm2_5i25.0:     IO Pin 016 (P3-13): Encoder #0, pin A (Input)
hm2/hm2_5i25.0:     IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0:     IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0:     IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0:     IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0:     IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0:     IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0:     IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0:     IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0:     IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0:     IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0:     IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0:     IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0:     IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0:     IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0:     IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0:     IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0:     IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
Running HAL shutdown script
Killing task linuxcncsvr, PID=904
hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
hm2/hm2_5i25.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./Mesa.hal:25: Pin 'hm2_5i25.0.7i76.0.0.output-00' does not exist
904
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7f33d68ff000
Kernel message information:
[    0.000000] Linux version 4.9.0-8-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08)
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-4.9.0-8-rt-amd64 root=/dev/mapper/CNC--vg-root ro quiet
[    0.000000] x86/fpu: Legacy x87 FPU detected.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000008efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000008f000-0x000000000008ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000090000-0x000000000009ebff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009ec00-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000cee97fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000cee98000-0x00000000ceebefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ceebf000-0x00000000cef46fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000cef47000-0x00000000cefbefff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000cefbf000-0x00000000ceff0fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000ceff1000-0x00000000ceffefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000cefff000-0x00000000ceffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000cf000000-0x00000000cfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fff00000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000022fffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.5 present.
[    0.000000] DMI:  /D525MW, BIOS MWPNT10N.86A.0083.2011.0524.1600 05/24/2011
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x230000 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-DFFFF write-protect
[    0.000000]   E0000-FFFFF uncachable
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask F80000000 write-back
[    0.000000]   1 base 080000000 mask FC0000000 write-back
[    0.000000]   2 base 0C0000000 mask FF0000000 write-back
[    0.000000]   3 base 0CF000000 mask FFF000000 uncachable
[    0.000000]   4 base 100000000 mask F00000000 write-back
[    0.000000]   5 base 200000000 mask F00000000 write-back
[    0.000000]   6 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] e820: update [mem 0xcf000000-0xffffffff] usable ==> reserved
[    0.000000] e820: last_pfn = 0xcf000 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fbe50-0x000fbe5f] mapped at [ffff8c52400fbe50]
[    0.000000] Base memory trampoline at [ffff8c5240098000] 98000 size 24576
[    0.000000] BRK [0x20d9c0000, 0x20d9c0fff] PGTABLE
[    0.000000] BRK [0x20d9c1000, 0x20d9c1fff] PGTABLE
[    0.000000] BRK [0x20d9c2000, 0x20d9c2fff] PGTABLE
[    0.000000] BRK [0x20d9c3000, 0x20d9c3fff] PGTABLE
[    0.000000] BRK [0x20d9c4000, 0x20d9c4fff] PGTABLE
[    0.000000] BRK [0x20d9c5000, 0x20d9c5fff] PGTABLE
[    0.000000] BRK [0x20d9c6000, 0x20d9c6fff] PGTABLE
[    0.000000] BRK [0x20d9c7000, 0x20d9c7fff] PGTABLE
[    0.000000] BRK [0x20d9c8000, 0x20d9c8fff] PGTABLE
[    0.000000] BRK [0x20d9c9000, 0x20d9c9fff] PGTABLE
[    0.000000] BRK [0x20d9ca000, 0x20d9cafff] PGTABLE
[    0.000000] BRK [0x20d9cb000, 0x20d9cbfff] PGTABLE
[    0.000000] RAMDISK: [mem 0x34fd7000-0x367e2fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000F2060 000024 (v02 INTEL )
[    0.000000] ACPI: XSDT 0x00000000CEFFE120 00004C (v01 INTEL  D525MW   00000053      01000013)
[    0.000000] ACPI: FACP 0x00000000CEFFD000 0000F4 (v03 INTEL  D525MW   00000053 MSFT 0100000D)
[    0.000000] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Pm1aEventBlock: 32/16 (20160831/tbfadt-603)
[    0.000000] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/PmTimerBlock: 32/24 (20160831/tbfadt-603)
[    0.000000] ACPI BIOS Warning (bug): Invalid length for FADT/Pm1aEventBlock: 16, using default 32 (20160831/tbfadt-708)
[    0.000000] ACPI BIOS Warning (bug): Invalid length for FADT/PmTimerBlock: 24, using default 32 (20160831/tbfadt-708)
[    0.000000] ACPI: DSDT 0x00000000CEFF9000 003796 (v01 INTEL  D525MW   00000053 MSFT 0100000D)
[    0.000000] ACPI: FACS 0x00000000CEF87000 000040
[    0.000000] ACPI: APIC 0x00000000CEFF8000 000084 (v02 INTEL  D525MW   00000053 MSFT 0100000D)
[    0.000000] ACPI: MCFG 0x00000000CEFF7000 00003C (v01 INTEL  D525MW   00000053 MSFT 0100000D)
[    0.000000] ACPI: HPET 0x00000000CEFF6000 000038 (v01 INTEL  D525MW   00000053 MSFT 0100000D)
[    0.000000] ACPI: SSDT 0x00000000CEFF2000 00377C (v01 INTEL  D525MW   00000053 MSFT 0100000D)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000022fffffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x22fffa000-0x22fffefff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000022fffffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000008efff]
[    0.000000]   node   0: [mem 0x0000000000090000-0x000000000009dfff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x00000000cee97fff]
[    0.000000]   node   0: [mem 0x00000000ceebf000-0x00000000cef46fff]
[    0.000000]   node   0: [mem 0x00000000cefbf000-0x00000000ceff0fff]
[    0.000000]   node   0: [mem 0x00000000cefff000-0x00000000ceffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000022fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000022fffffff]
[    0.000000] On node 0 totalpages: 2092783
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3996 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 13182 pages used for memmap
[    0.000000]   DMA32 zone: 843603 pages, LIFO batch:31
[    0.000000]   Normal zone: 19456 pages used for memmap
[    0.000000]   Normal zone: 1245184 pages, LIFO batch:31
[    0.000000] Reserving Intel graphics memory at 0x00000000cf800000-0x00000000cfffffff
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high level lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high level lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.000000] smpboot: Allowing 4 CPUs, 2 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0008f000-0x0008ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xcee98000-0xceebefff]
[    0.000000] PM: Registered nosave memory: [mem 0xcef47000-0xcefbefff]
[    0.000000] PM: Registered nosave memory: [mem 0xceff1000-0xceffefff]
[    0.000000] PM: Registered nosave memory: [mem 0xcf000000-0xcfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xd0000000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xffefffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfff00000-0xffffffff]
[    0.000000] e820: [mem 0xd0000000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] percpu: Embedded 116 pages/cpu @ffff8c546fc00000 s437952 r8192 d28992 u524288
[    0.000000] pcpu-alloc: s437952 r8192 d28992 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 2060060
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-4.9.0-8-rt-amd64 root=/dev/mapper/CNC--vg-root ro quiet
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 8131280K/8371132K available (6391K kernel code, 1152K rwdata, 2912K rodata, 1680K init, 968K bss, 239852K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Kernel/User page tables isolation: enabled
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000] 	RCU kthread priority: 1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS:33024 nr_irqs:456 16
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 1800.003 MHz processor
[    0.004009] Calibrating delay loop (skipped), value calculated using timer frequency.. 3600.00 BogoMIPS (lpj=7200012)
[    0.004013] pid_max: default: 32768 minimum: 301
[    0.004051] ACPI: Core revision 20160831
[    0.018397] ACPI: 2 ACPI AML tables successfully acquired and loaded
[    0.018494] Security Framework initialized
[    0.018497] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.018508] AppArmor: AppArmor disabled by boot time parameter
[    0.022695] Dentry cache hash table entries: 1048576 (order: 12, 16777216 bytes)
[    0.033215] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.036377] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.036419] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.037299] mce: CPU supports 5 MCE banks
[    0.037310] CPU0: Thermal monitoring enabled (TM1)
[    0.037318] process: using mwait in idle threads
[    0.037325] Last level iTLB entries: 4KB 32, 2MB 0, 4MB 0
[    0.037328] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 8, 1GB 0
[    0.037908] Freeing SMP alternatives memory: 24K
[    0.040023] ftrace: allocating 25230 entries in 99 pages
[    0.060269] smpboot: Max logical packages: 2
[    0.060793] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.104000] smpboot: CPU0: Intel(R) Atom(TM) CPU D525   @ 1.80GHz (family: 0x6, model: 0x1c, stepping: 0xa)
[    0.104000] Performance Events: PEBS fmt0+, Atom events, 8-deep LBR, Intel PMU driver.
[    0.104000] ... version:                3
[    0.104000] ... bit width:              40
[    0.104000] ... generic registers:      2
[    0.104000] ... value mask:             000000ffffffffff
[    0.104000] ... max period:             000000007fffffff
[    0.104000] ... fixed-purpose events:   3
[    0.104000] ... event mask:             0000000700000003
[    0.156345] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.208063] x86: Booting SMP configuration:
[    0.208067] .... node  #0, CPUs:      #1
[    0.210196] TSC synchronization [CPU#0 -> CPU#1]:
[    0.210198] Measured 54 cycles TSC warp between CPUs, turning off TSC clock.
[    0.210208] tsc: Marking TSC unstable due to check_tsc_sync_source failed
[    0.210331] x86: Booted up 1 node, 2 CPUs
[    0.210331] smpboot: Total of 2 processors activated (7200.01 BogoMIPS)
[    0.212688] devtmpfs: initialized
[    0.212688] x86/mm: Memory block size: 128MB
[    0.223726] PM: Registering ACPI NVS region [mem 0xcef47000-0xcefbefff] (491520 bytes)
[    0.223960] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.224061] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.224237] pinctrl core: initialized pinctrl subsystem
[    0.224691] NET: Registered protocol family 16
[    0.225467] cpuidle: using governor ladder
[    0.225487] cpuidle: using governor menu
[    0.225564] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.225569] ACPI: bus type PCI registered
[    0.225573] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.225818] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.225825] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.225845] PCI: Using configuration type 1 for base access
[    0.229582] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.229582] ACPI: Added _OSI(Module Device)
[    0.229582] ACPI: Added _OSI(Processor Device)
[    0.229582] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.229582] ACPI: Added _OSI(Processor Aggregator Device)
[    0.241023] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.242878] ACPI: Interpreter enabled
[    0.242934] ACPI: (supports S0 S1 S3 S4 S5)
[    0.242938] ACPI: Using IOAPIC for interrupt routing
[    0.243013] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.256282] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3f])
[    0.256298] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.256313] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[    0.257079] PCI host bridge to bus 0000:00
[    0.257086] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.257091] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.257096] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.257100] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xf7ffffff window]
[    0.257105] pci_bus 0000:00: root bus resource [bus 00-3f]
[    0.257124] pci 0000:00:00.0: [8086:a000] type 00 class 0x060000
[    0.257396] pci 0000:00:02.0: [8086:a001] type 00 class 0x030000
[    0.257413] pci 0000:00:02.0: reg 0x10: [mem 0xe0300000-0xe037ffff]
[    0.257421] pci 0000:00:02.0: reg 0x14: [io  0x20c0-0x20c7]
[    0.257430] pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff pref]
[    0.257439] pci 0000:00:02.0: reg 0x1c: [mem 0xe0200000-0xe02fffff]
[    0.257773] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[    0.257804] pci 0000:00:1b.0: reg 0x10: [mem 0xe0380000-0xe0383fff 64bit]
[    0.257927] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.258132] pci 0000:00:1b.0: System wakeup disabled by ACPI
[    0.258283] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[    0.258414] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.258560] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.258702] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400
[    0.258824] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    0.258970] pci 0000:00:1c.1: System wakeup disabled by ACPI
[    0.259117] pci 0000:00:1c.2: [8086:27d4] type 01 class 0x060400
[    0.259233] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.259378] pci 0000:00:1c.2: System wakeup disabled by ACPI
[    0.259525] pci 0000:00:1c.3: [8086:27d6] type 01 class 0x060400
[    0.259646] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.259792] pci 0000:00:1c.3: System wakeup disabled by ACPI
[    0.259936] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[    0.260061] pci 0000:00:1d.0: reg 0x20: [io  0x2080-0x209f]
[    0.260323] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.260465] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[    0.260538] pci 0000:00:1d.1: reg 0x20: [io  0x2060-0x207f]
[    0.260779] pci 0000:00:1d.1: System wakeup disabled by ACPI
[    0.260925] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[    0.260995] pci 0000:00:1d.2: reg 0x20: [io  0x2040-0x205f]
[    0.261225] pci 0000:00:1d.2: System wakeup disabled by ACPI
[    0.261363] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[    0.261439] pci 0000:00:1d.3: reg 0x20: [io  0x2020-0x203f]
[    0.261671] pci 0000:00:1d.3: System wakeup disabled by ACPI
[    0.261824] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[    0.261853] pci 0000:00:1d.7: reg 0x10: [mem 0xe0384400-0xe03847ff]
[    0.261981] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.262168] pci 0000:00:1d.7: System wakeup disabled by ACPI
[    0.262316] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
[    0.262532] pci 0000:00:1e.0: System wakeup disabled by ACPI
[    0.262680] pci 0000:00:1f.0: [8086:27bc] type 00 class 0x060100
[    0.262790] pci 0000:00:1f.0: [Firmware Bug]: TigerPoint LPC.BM_STS cleared
[    0.263065] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f
[    0.263089] pci 0000:00:1f.2: reg 0x10: [io  0x20b8-0x20bf]
[    0.263104] pci 0000:00:1f.2: reg 0x14: [io  0x20cc-0x20cf]
[    0.263117] pci 0000:00:1f.2: reg 0x18: [io  0x20b0-0x20b7]
[    0.263131] pci 0000:00:1f.2: reg 0x1c: [io  0x20c8-0x20cb]
[    0.263145] pci 0000:00:1f.2: reg 0x20: [io  0x20a0-0x20af]
[    0.263160] pci 0000:00:1f.2: reg 0x24: [mem 0xe0384000-0xe03843ff]
[    0.263220] pci 0000:00:1f.2: PME# supported from D3hot
[    0.263472] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[    0.263545] pci 0000:00:1f.3: reg 0x20: [io  0x2000-0x201f]
[    0.263954] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[    0.263987] pci 0000:01:00.0: reg 0x10: [io  0x1000-0x10ff]
[    0.264074] pci 0000:01:00.0: reg 0x18: [mem 0xe0004000-0xe0004fff 64bit pref]
[    0.264102] pci 0000:01:00.0: reg 0x20: [mem 0xe0000000-0xe0003fff 64bit pref]
[    0.264250] pci 0000:01:00.0: supports D1 D2
[    0.264254] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.276057] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.276065] pci 0000:00:1c.0:   bridge window [io  0x1000-0x1fff]
[    0.276079] pci 0000:00:1c.0:   bridge window [mem 0xe0000000-0xe00fffff 64bit pref]
[    0.276223] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.276349] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.276482] pci 0000:00:1c.3: PCI bridge to [bus 04]
[    0.276599] pci 0000:05:00.0: [2718:5125] type 00 class 0x110000
[    0.276623] pci 0000:05:00.0: reg 0x10: [mem 0xe0100000-0xe010ffff]
[    0.276892] pci 0000:00:1e.0: PCI bridge to [bus 05] (subtractive decode)
[    0.276903] pci 0000:00:1e.0:   bridge window [mem 0xe0100000-0xe01fffff]
[    0.276915] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.276919] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.276924] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.276928] pci 0000:00:1e.0:   bridge window [mem 0xd0000000-0xf7ffffff window] (subtractive decode)
[    0.277220] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12)
[    0.277430] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[    0.277639] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 *9 10 11 12)
[    0.277849] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12)
[    0.278067] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 *10 11 12)
[    0.278272] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[    0.278480] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 *9 10 11 12)
[    0.278687] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 *10 11 12)
[    0.280242] ACPI: Enabled 2 GPEs in block 00 to 1F
[    0.280568] vgaarb: setting as boot device: PCI:0000:00:02.0
[    0.280568] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.280568] vgaarb: loaded
[    0.280568] vgaarb: bridge control possible 0000:00:02.0
[    0.280568] PCI: Using ACPI for IRQ routing
[    0.281908] PCI: pci_cache_line_size set to 64 bytes
[    0.282005] e820: reserve RAM buffer [mem 0x0008f000-0x0008ffff]
[    0.282010] e820: reserve RAM buffer [mem 0x0009ec00-0x0009ffff]
[    0.282014] e820: reserve RAM buffer [mem 0xcee98000-0xcfffffff]
[    0.282017] e820: reserve RAM buffer [mem 0xcef47000-0xcfffffff]
[    0.282021] e820: reserve RAM buffer [mem 0xceff1000-0xcfffffff]
[    0.282024] e820: reserve RAM buffer [mem 0xcf000000-0xcfffffff]
[    0.282633] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[    0.282643] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.282653] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[    0.288061] clocksource: Switched to clocksource hpet
[    0.329050] VFS: Disk quotas dquot_6.6.0
[    0.329130] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.329456] pnp: PnP ACPI init
[    0.329773] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.329781] system 00:00: [mem 0xfed14000-0xfed17fff] has been reserved
[    0.329787] system 00:00: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.329792] system 00:00: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.329798] system 00:00: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.329805] system 00:00: [mem 0x000c0000-0x000dffff] could not be reserved
[    0.329811] system 00:00: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.329816] system 00:00: [mem 0xfff00000-0xffffffff] has been reserved
[    0.329828] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.330293] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.330482] system 00:02: [io  0x0500-0x053f] has been reserved
[    0.330489] system 00:02: [io  0x0400-0x047f] has been reserved
[    0.330494] system 00:02: [io  0x0680-0x06ff] has been reserved
[    0.330500] system 00:02: [io  0x0295-0x0296] has been reserved
[    0.330510] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.330758] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[    0.331329] pnp 00:04: Plug and Play ACPI device, IDs PNP0400 (active)
[    0.331814] pnp: PnP ACPI: found 5 devices
[    0.344800] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.344846] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 400000 add_align 100000
[    0.344862] pci 0000:00:1c.1: bridge window [io  0x1000-0x0fff] to [bus 02] add_size 1000
[    0.344868] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[    0.344874] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff] to [bus 02] add_size 200000 add_align 100000
[    0.344889] pci 0000:00:1c.2: bridge window [io  0x1000-0x0fff] to [bus 03] add_size 1000
[    0.344895] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[    0.344900] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff] to [bus 03] add_size 200000 add_align 100000
[    0.344914] pci 0000:00:1c.3: bridge window [io  0x1000-0x0fff] to [bus 04] add_size 1000
[    0.344919] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 04] add_size 200000 add_align 100000
[    0.344925] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff] to [bus 04] add_size 200000 add_align 100000
[    0.344965] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 400000 min_align 100000
[    0.344971] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x004fffff] res_to_dev_res add_size 400000 min_align 100000
[    0.344976] pci 0000:00:1c.1: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.344981] pci 0000:00:1c.1: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.344986] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.344992] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.344997] pci 0000:00:1c.2: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.345002] pci 0000:00:1c.2: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.345007] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.345012] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.345017] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.345022] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.345027] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.345033] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.345038] pci 0000:00:1c.1: res[13]=[io  0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[    0.345042] pci 0000:00:1c.1: res[13]=[io  0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[    0.345047] pci 0000:00:1c.2: res[13]=[io  0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[    0.345052] pci 0000:00:1c.2: res[13]=[io  0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[    0.345057] pci 0000:00:1c.3: res[13]=[io  0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[    0.345062] pci 0000:00:1c.3: res[13]=[io  0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[    0.345074] pci 0000:00:1c.0: BAR 14: assigned [mem 0xe0400000-0xe07fffff]
[    0.345081] pci 0000:00:1c.1: BAR 14: assigned [mem 0xe0800000-0xe09fffff]
[    0.345091] pci 0000:00:1c.1: BAR 15: assigned [mem 0xe0a00000-0xe0bfffff 64bit pref]
[    0.345098] pci 0000:00:1c.2: BAR 14: assigned [mem 0xe0c00000-0xe0dfffff]
[    0.345108] pci 0000:00:1c.2: BAR 15: assigned [mem 0xe0e00000-0xe0ffffff 64bit pref]
[    0.345114] pci 0000:00:1c.3: BAR 14: assigned [mem 0xe1000000-0xe11fffff]
[    0.345124] pci 0000:00:1c.3: BAR 15: assigned [mem 0xe1200000-0xe13fffff 64bit pref]
[    0.345132] pci 0000:00:1c.1: BAR 13: assigned [io  0x3000-0x3fff]
[    0.345138] pci 0000:00:1c.2: BAR 13: assigned [io  0x4000-0x4fff]
[    0.345145] pci 0000:00:1c.3: BAR 13: assigned [io  0x5000-0x5fff]
[    0.345157] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.345163] pci 0000:00:1c.0:   bridge window [io  0x1000-0x1fff]
[    0.345172] pci 0000:00:1c.0:   bridge window [mem 0xe0400000-0xe07fffff]
[    0.345178] pci 0000:00:1c.0:   bridge window [mem 0xe0000000-0xe00fffff 64bit pref]
[    0.345188] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.345193] pci 0000:00:1c.1:   bridge window [io  0x3000-0x3fff]
[    0.345201] pci 0000:00:1c.1:   bridge window [mem 0xe0800000-0xe09fffff]
[    0.345208] pci 0000:00:1c.1:   bridge window [mem 0xe0a00000-0xe0bfffff 64bit pref]
[    0.345217] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.345223] pci 0000:00:1c.2:   bridge window [io  0x4000-0x4fff]
[    0.345231] pci 0000:00:1c.2:   bridge window [mem 0xe0c00000-0xe0dfffff]
[    0.345238] pci 0000:00:1c.2:   bridge window [mem 0xe0e00000-0xe0ffffff 64bit pref]
[    0.345248] pci 0000:00:1c.3: PCI bridge to [bus 04]
[    0.345253] pci 0000:00:1c.3:   bridge window [io  0x5000-0x5fff]
[    0.345261] pci 0000:00:1c.3:   bridge window [mem 0xe1000000-0xe11fffff]
[    0.345268] pci 0000:00:1c.3:   bridge window [mem 0xe1200000-0xe13fffff 64bit pref]
[    0.345280] pci 0000:00:1e.0: PCI bridge to [bus 05]
[    0.345288] pci 0000:00:1e.0:   bridge window [mem 0xe0100000-0xe01fffff]
[    0.345302] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.345306] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.345311] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.345315] pci_bus 0000:00: resource 7 [mem 0xd0000000-0xf7ffffff window]
[    0.345320] pci_bus 0000:01: resource 0 [io  0x1000-0x1fff]
[    0.345324] pci_bus 0000:01: resource 1 [mem 0xe0400000-0xe07fffff]
[    0.345328] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xe00fffff 64bit pref]
[    0.345333] pci_bus 0000:02: resource 0 [io  0x3000-0x3fff]
[    0.345337] pci_bus 0000:02: resource 1 [mem 0xe0800000-0xe09fffff]
[    0.345341] pci_bus 0000:02: resource 2 [mem 0xe0a00000-0xe0bfffff 64bit pref]
[    0.345346] pci_bus 0000:03: resource 0 [io  0x4000-0x4fff]
[    0.345350] pci_bus 0000:03: resource 1 [mem 0xe0c00000-0xe0dfffff]
[    0.345354] pci_bus 0000:03: resource 2 [mem 0xe0e00000-0xe0ffffff 64bit pref]
[    0.345359] pci_bus 0000:04: resource 0 [io  0x5000-0x5fff]
[    0.345363] pci_bus 0000:04: resource 1 [mem 0xe1000000-0xe11fffff]
[    0.345367] pci_bus 0000:04: resource 2 [mem 0xe1200000-0xe13fffff 64bit pref]
[    0.345372] pci_bus 0000:05: resource 1 [mem 0xe0100000-0xe01fffff]
[    0.345376] pci_bus 0000:05: resource 4 [io  0x0000-0x0cf7 window]
[    0.345380] pci_bus 0000:05: resource 5 [io  0x0d00-0xffff window]
[    0.345385] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.345389] pci_bus 0000:05: resource 7 [mem 0xd0000000-0xf7ffffff window]
[    0.345631] NET: Registered protocol family 2
[    0.346324] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.348006] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[    0.350525] TCP: Hash tables configured (established 65536 bind 65536)
[    0.350864] UDP hash table entries: 4096 (order: 7, 524288 bytes)
[    0.351362] UDP-Lite hash table entries: 4096 (order: 7, 524288 bytes)
[    0.351895] NET: Registered protocol family 1
[    0.351943] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.376365] PCI: CLS 64 bytes, default 64
[    0.376580] Unpacking initramfs...
[    1.441770] Freeing initrd memory: 24624K
[    1.441780] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.441786] software IO TLB [mem 0xcae98000-0xcee98000] (64MB) mapped at [ffff8c530ae98000-ffff8c530ee97fff]
[    1.441922] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x19f22c73312, max_idle_ns: 440795259572 ns
[    1.443109] audit: initializing netlink subsys (disabled)
[    1.443170] audit: type=2000 audit(1557585132.440:1): initialized
[    1.444774] workingset: timestamp_bits=40 max_order=21 bucket_order=0
[    1.452075] zbud: loaded
[    1.455085] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.459223] io scheduler noop registered
[    1.459227] io scheduler deadline registered
[    1.459364] io scheduler cfq registered (default)
[    1.460305] pcieport 0000:00:1c.1: enabling device (0000 -> 0003)
[    1.460821] pcieport 0000:00:1c.2: enabling device (0000 -> 0003)
[    1.461303] pcieport 0000:00:1c.3: enabling device (0000 -> 0003)
[    1.461867] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.461889] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.461943] intel_idle: MWAIT substates: 0x10
[    1.461946] intel_idle: v0.4.1 model 0x1C
[    1.462077] intel_idle: lapic_timer_reliable_states 0x2
[    1.462915] GHES: HEST is not enabled!
[    1.463133] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.464512] Linux agpgart interface v0.103
[    1.464979] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.464982] AMD IOMMUv2 functionality not available on this system
[    1.465576] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    1.465579] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.466422] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.466855] mousedev: PS/2 mouse device common for all mice
[    1.466991] rtc_cmos 00:01: RTC can wake from S4
[    1.467266] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    1.467400] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    1.468634] NET: Registered protocol family 10
[    1.469356] mip6: Mobile IPv6
[    1.469364] NET: Registered protocol family 17
[    1.469374] mpls_gso: MPLS GSO support
[    1.469942] microcode: sig=0x106ca, pf=0x8, revision=0x107
[    1.470083] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.470603] registered taskstats version 1
[    1.470680] zswap: loaded using pool lzo/zbud
[    1.470869] ima: No TPM chip found, activating TPM-bypass!
[    1.470875] ima: Allocated hash algorithm: sha256
[    1.471579] rtc_cmos 00:01: setting system clock to 2019-05-11 14:32:12 UTC (1557585132)
[    1.471777] PM: Hibernation image not present or could not be loaded.
[    1.476482] Freeing unused kernel memory: 1680K
[    1.476487] Write protecting the kernel read-only data: 12288k
[    1.479384] Freeing unused kernel memory: 1784K
[    1.488114] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.489203] Freeing unused kernel memory: 1184K
[    1.504074] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.564736] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.565094] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.565142] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.779247] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    1.779268] r8169 0000:01:00.0: can't disable ASPM; OS doesn't have ASPM control
[    1.783545] r8169 0000:01:00.0 eth0: RTL8168e/8111e at 0xffffad9f81469000, 4c:72:b9:7c:a0:b8, XID 0c200000 IRQ 28
[    1.783552] r8169 0000:01:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    1.785842] ACPI: bus type USB registered
[    1.785926] usbcore: registered new interface driver usbfs
[    1.785967] usbcore: registered new interface driver hub
[    1.786059] usbcore: registered new device driver usb
[    1.798515] SCSI subsystem initialized
[    1.820524] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    1.821923] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.828639] ehci-pci: EHCI PCI platform driver
[    1.834120] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    1.834143] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[    1.834171] ehci-pci 0000:00:1d.7: debug port 1
[    1.834422] uhci_hcd: USB Universal Host Controller Interface driver
[    1.840792] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[    1.848802] libata version 3.00 loaded.
[    1.851068] ehci-pci 0000:00:1d.7: irq 23, io mem 0xe0384400
[    1.864140] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    1.865816] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.865823] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.865827] usb usb1: Product: EHCI Host Controller
[    1.865831] usb usb1: Manufacturer: Linux 4.9.0-8-rt-amd64 ehci_hcd
[    1.865835] usb usb1: SerialNumber: 0000:00:1d.7
[    1.887971] hub 1-0:1.0: USB hub found
[    1.888083] hub 1-0:1.0: 8 ports detected
[    1.889327] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    1.889356] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    1.889373] uhci_hcd 0000:00:1d.0: detected 2 ports
[    1.892824] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00002080
[    1.893088] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.893093] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.893097] usb usb2: Product: UHCI Host Controller
[    1.893101] usb usb2: Manufacturer: Linux 4.9.0-8-rt-amd64 uhci_hcd
[    1.893105] usb usb2: SerialNumber: 0000:00:1d.0
[    1.893618] hub 2-0:1.0: USB hub found
[    1.893652] hub 2-0:1.0: 2 ports detected
[    1.894772] ata_piix 0000:00:1f.2: version 2.13
[    1.895098] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[    2.059368] scsi host0: ata_piix
[    2.060271] scsi host1: ata_piix
[    2.060487] ata1: SATA max UDMA/133 cmd 0x20b8 ctl 0x20cc bmdma 0x20a0 irq 18
[    2.060492] ata2: SATA max UDMA/133 cmd 0x20b0 ctl 0x20c8 bmdma 0x20a8 irq 18
[    2.060933] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    2.060954] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[    2.060983] uhci_hcd 0000:00:1d.1: detected 2 ports
[    2.061159] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00002060
[    2.061930] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    2.061936] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.061940] usb usb3: Product: UHCI Host Controller
[    2.061944] usb usb3: Manufacturer: Linux 4.9.0-8-rt-amd64 uhci_hcd
[    2.061947] usb usb3: SerialNumber: 0000:00:1d.1
[    2.062461] hub 3-0:1.0: USB hub found
[    2.062494] hub 3-0:1.0: 2 ports detected
[    2.063222] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    2.063241] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[    2.063255] uhci_hcd 0000:00:1d.2: detected 2 ports
[    2.063424] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00002040
[    2.063667] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    2.063672] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.063676] usb usb4: Product: UHCI Host Controller
[    2.063680] usb usb4: Manufacturer: Linux 4.9.0-8-rt-amd64 uhci_hcd
[    2.063683] usb usb4: SerialNumber: 0000:00:1d.2
[    2.064261] hub 4-0:1.0: USB hub found
[    2.064297] hub 4-0:1.0: 2 ports detected
[    2.065057] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[    2.065077] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[    2.065341] uhci_hcd 0000:00:1d.3: detected 2 ports
[    2.065599] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00002020
[    2.065809] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    2.065814] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.065818] usb usb5: Product: UHCI Host Controller
[    2.065822] usb usb5: Manufacturer: Linux 4.9.0-8-rt-amd64 uhci_hcd
[    2.065826] usb usb5: SerialNumber: 0000:00:1d.3
[    2.066353] hub 5-0:1.0: USB hub found
[    2.066383] hub 5-0:1.0: 2 ports detected
[    2.237993] ata1.00: supports DRM functions and may not be fully accessible
[    2.238001] ata1.00: ATA-11: Samsung SSD 860 EVO 250GB, RVT02B6Q, max UDMA/133
[    2.238005] ata1.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 0/32)
[    2.241416] ata1.00: supports DRM functions and may not be fully accessible
[    2.242055] ata1.00: configured for UDMA/133
[    2.242571] scsi 0:0:0:0: Direct-Access     ATA      Samsung SSD 860  2B6Q PQ: 0 ANSI: 5
[    2.297431] ata1.00: Enabling discard_zeroes_data
[    2.297481] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[    2.297783] sd 0:0:0:0: [sda] Write Protect is off
[    2.297789] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.297881] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.298347] ata1.00: Enabling discard_zeroes_data
[    2.299534]  sda: sda1 sda2 < sda5 >
[    2.301546] ata1.00: Enabling discard_zeroes_data
[    2.302122] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.388154] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[    2.416123] device-mapper: uevent: version 1.0.3
[    2.416479] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    2.486256] random: fast init done
[    2.576343] usb 3-1: New USB device found, idVendor=046d, idProduct=c03d
[    2.576350] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.576355] usb 3-1: Product: USB-PS/2 Optical Mouse
[    2.576359] usb 3-1: Manufacturer: Logitech
[    2.593059] hidraw: raw HID events driver (C) Jiri Kosina
[    2.611833] usbcore: registered new interface driver usbhid
[    2.611838] usbhid: USB HID core driver
[    2.614487] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/0003:046D:C03D.0001/input/input1
[    2.615189] hid-generic 0003:046D:C03D.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1d.1-1/input0
[    2.725100] PM: Starting manual resume from disk
[    2.725109] PM: Hibernation image partition 254:2 present
[    2.725111] PM: Looking for hibernation image.
[    2.725523] PM: Image not found (code -22)
[    2.725527] PM: Hibernation image not present or could not be loaded.
[    2.960593] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[    3.310454] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.323474] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    3.323976] systemd[1]: Detected architecture x86-64.
[    3.324632] systemd[1]: Set hostname to <CNC>.
[    3.571451] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[    3.571610] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[    3.574609] systemd[1]: Listening on udev Kernel Socket.
[    3.575599] systemd[1]: Created slice System Slice.
[    3.578372] systemd[1]: Mounting POSIX Message Queue File System...
[    3.579588] systemd[1]: Created slice system-getty.slice.
[    3.580178] systemd[1]: Listening on Journal Socket.
[    3.688394] lp: driver loaded but no devices found
[    3.708152] ppdev: user-space parallel port driver
[    3.710344] parport_pc 00:04: reported by Plug and Play ACPI
[    3.710502] parport0: PC-style at 0x378, irq 7 [PCSPP]
[    3.764468] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
[    3.816486] lp0: using parport0 (interrupt-driven).
[    4.822099] ACPI Exception: AE_NOT_FOUND, Evaluating _PSS (20160831/processor_perflib-334)
[    4.822315] ACPI Exception: AE_NOT_FOUND, Evaluating _PSS (20160831/processor_perflib-334)
[    4.879937] ACPI Exception: AE_NOT_FOUND, Evaluating _PSS (20160831/processor_perflib-334)
[    4.885625] ACPI Exception: AE_NOT_FOUND, Evaluating _PSS (20160831/processor_perflib-334)
[    4.886059] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[    4.886071] ACPI: Sleep Button [SLPB]
[    4.899578] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    4.899591] ACPI: Power Button [PWRF]
[    5.150449] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    5.306687] [drm] Initialized
[    5.433383] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000428-0x0000000000000429 (\GPE0) (20160831/utaddress-247)
[    5.433405] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    5.433412] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000518-0x000000000000051B (\BGPO) (20160831/utaddress-247)
[    5.433424] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x000000000000050C-0x000000000000050F (\IGPO) (20160831/utaddress-247)
[    5.433435] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    5.440376] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    5.606448] pci 0000:00:00.0: Intel GMA3150 Chipset
[    5.606600] pci 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[    5.606692] pci 0000:00:00.0: detected 8192K stolen memory
[    5.606781] [drm] Memory usable by graphics device = 512M
[    5.606791] [drm] Replacing VGA console driver
[    5.616738] Console: switching to colour dummy device 80x25
[    5.631376] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    5.631381] [drm] Driver supports precise vblank timestamp query.
[    5.690030] input: PC Speaker as /devices/platform/pcspkr/input/input4
[    5.718823] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    5.719142] [drm] Skipping LVDS initialization for Intel D525MW
[    5.722490] [drm] RC6 disabled, disabling runtime PM support
[    5.722515] [drm] initialized overlay support
[    5.726037] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    5.766396] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[    5.856654] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC662 rev1: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    5.856662] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    5.856667] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    5.856671] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    5.856674] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x1e/0x0
[    5.856678] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    5.856683] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    5.856687] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    5.856691] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    5.873749] fbcon: inteldrmfb (fb0) is primary device
[    5.979875] intel_powerclamp: No package C-state available
[    5.979880] Console: switching to colour frame buffer device 170x48
[    5.992885] intel_powerclamp: No package C-state available
[    5.992885] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[    6.002439] ACPI Exception: AE_NOT_FOUND, Evaluating _PSS (20160831/processor_perflib-334)
[    6.009956] ACPI Exception: AE_NOT_FOUND, Evaluating _PSS (20160831/processor_perflib-334)
[    6.016187] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[    6.019292] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    6.045416] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[    6.069460] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[    6.097642] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[    7.014877] iTCO_vendor_support: vendor-support=0
[    7.043552] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    7.045976] iTCO_wdt: Found a NM10 TCO device (Version=2, TCOBASE=0x0460)
[    7.081912] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    7.394387] Adding 8368124k swap on /dev/mapper/CNC--vg-swap_1.  Priority:-1 extents:1 across:8368124k SSFS
[    7.987941] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Opts: (null)
[    8.070947] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Opts: (null)
[    8.083169] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem
[    8.092837] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[    8.094143] EXT4-fs (sda1): mounted filesystem without journal. Opts: (null)
[    8.167627] systemd-journald[237]: Received request to flush runtime journal from PID 1
[    8.588102] r8169 0000:01:00.0: firmware: direct-loading firmware rtl_nic/rtl8168e-2.fw
[    9.059067] r8169 0000:01:00.0 eth0: link down
[    9.059157] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.585745] r8169 0000:01:00.0 eth0: link up
[   10.585765] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   25.806547] random: crng init done
[   25.806553] random: 7 urandom warning(s) missed due to ratelimiting
I've been down too many rabbit holes trying to make things work to know what to do next. What do you suggest?
Thanks,
Stan
11 May 2019 16:45 #133456 by PCW
Do you have 5V power and field power on the 7I76? (both Yellow lights on)
11 May 2019 17:28 #133459 by JustPlaneSweet
Yes. Both yellow lights are on. I also should clarify that I have the 5i25 not the 5i25e.
Stan
11 May 2019 18:01 - 11 May 2019 18:05 #133461 by PCW
For whatever reason, the 7I76 I/O section is not being found
This is not likely to be a OS/version related issue
Common causes would be
1. No or low 5V on 7I76 logic section (verify +5V +-10% on 7I76 TB3 pins 21(5V) to 23 (GND))
2. No or low VIN+ field voltage (verify > 8V on TB1 pins 1 and 5 relative to TB1 pin 8)
3. 7I76 jumpered for setup mode (make sure 7I76 W3 is in left hand position)
4. 5I25/7I76 cable power jumpers mis-match
if using cable power (suggested) 5I25 W2 up, 7I76 W2 LEFT
If using external 5V power 5I25 W2 DOWN, 7I76 W2 RIGHT 5V supplied externally to 7I76TB3
5. incorrect firmware (though this looks correct in you case)
6. loose/bad/incorrect cable between 5I25/7I76
Last edit: 11 May 2019 18:05 by PCW.
11 May 2019 18:36 - 11 May 2019 18:45 #133467 by JustPlaneSweet
Boy I feel stupid. When I opened the case to check the 5i25 jumpers I discovered I had the 7i76 cable plugged into the regular parallel port instead of the 5i25.
Thanks for your quick response.
LinuxCNC runs now. It complains that the 7i76 has outdated firmware. No problem.
Stan
Last edit: 11 May 2019 18:45 by JustPlaneSweet. Reason: wrong card identification
11 May 2019 21:19 #133484 by Clive S
Stan
I am not sure if the 7i76 has firmware. So it would be useful if you gave the exact error message
12 May 2019 07:35 #133520 by pl7i92
it is best to also terminate the regular parport it may confuse
:woohoo:
18 May 2019 11:35 #134170 by andypugh
It does. As well as being a breakout it contains a smart-serial device to handle the IO.
Updating remote daughter board firmware is not something that Mesaflash does (AFAIK), you use a slightly kludgy HAL component.
linuxcnc.org/docs/2.7/html/man/man9/setsserial.9.html
There are scripts to automate the process (utils/linuxcnc) in the software package from Mese:
www.mesanet.com/software/parallel/sserial.zip
24 May 2019 13:47 #134809 by paulctan
Let me know how you like the D525MW. I got rid of my D525 Atom based motherboards and went with a i5 motherboard because of performance issues with the OpenGL display (rendering the 3D cut path often lagged the actual machine). I've had no problems since I've been using an i5 instead of an Atom, but I also upgraded from parallel port to 5i25/7i76 at the same time.
28 May 2019 17:25 #135183 by JustPlaneSweet
The D525MW was a good choice back in 2012. I'm giving the board a second wind with more memory and a larger SSD. I would not recommend it for today's software.
Time to create page: 0.121 seconds
