Problems with recent upgrade to Debian Stretch
- aaron
19 May 2019 07:07 #134244
by aaron
Replied by aaron on topic Problems with recent upgrade to Debian Stretch
This HP Elite 8300 SFF does not seem to have a parallel port. Is it simply a question of plugging a new one into the pci? slot?
- Thank you received: 5334
19 May 2019 12:19 #134266
Replied by PCW on topic Problems with recent upgrade to Debian Stretch
It has a 26 pin header on the Motherboard (which needs an adapter/bracket to get to DB25F)
19 May 2019 23:46 #134304
It might be worth a try, 1500nS is pretty short. Try 5000 and see if things seem better, or the same.
Replied by andypugh on topic Problems with recent upgrade to Debian Stretch
setp parport.0.reset-time 1500
So by the ini file the steplength would be 1500ns
And step the min stepspace would be determined by the base thread ?
Would increasing the reset time be of any value (thereby increasing step length?) ?.
- aaron
21 May 2019 14:38 #134483
by aaron
So, I have given up trying to get stretch to work. I could not see how to turn off sound in the bios, The only thing I thuoght might make a difference was turning off the multiple CPU core, but that made it worse. I am back on wheezy and at least the machine works but I am unable to load software, particularly inkscape and libreCad which makes life difficult. Is there a way to add some kind of archive repository that has this stuff on?
In the mean time I await an HP Elite 8300 SFF and hope I have better luck installing stretch and the works on that.
Thanks for all your help
Cheers
Cheers
22 May 2019 01:43 #134545
Yes:
forum.linuxcnc.org/10-advanced-configura...ring-whb04b-4#131331
(though I have just found out that wheezy/updates works better than wheezy-updates)
There is still a problem with an expired security certificate at Debian. Changing the system clock for a few minutes bypasses that.
We are in a bit of a bind with there not being a version of RTAI that works on a v4 Linux kernel.
Yes:
The following user(s) said Thank You: aaron
- aaron
22 May 2019 08:31 #134560
by aaron
Brilliant
Thank you for the repository list.
Very much
Aaron
Very much
Aaron
28 May 2019 18:55 - 28 May 2019 18:55 #135187
Or, better:
There is still a problem with an expired security certificate at Debian. Changing the system clock for a few minutes bypasses that. .
Or, better:
sudo apt-get update -o Acquire::Check-Valid-Until=false
Last edit: 28 May 2019 18:55 by andypugh.
Time to create page: 0.117 seconds
