LinuxCNC crashes
21 May 2019 17:24 #134507 by m.bofi
LinuxCNC crashes was created by m.bofi
Hi all, when i attempt to start Linuxcnc this error appears and the program ends
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14-112-gcf62082e0
Machine configuration directory is '/home/mechcnc/linuxcnc/configs/RM-501'
Machine configuration file is 'rm501.ini'
INIFILE=/home/mechcnc/linuxcnc/configs/RM-501/rm501.ini
PARAMETER_FILE=rm501.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./rm501.hal
Debug file information:
.halcmd: error while loading shared libraries: libreadline.so.5: cannot open shared object file: No such file or directory
1701
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-3linuxcnc) () (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Debian 3.4.55-3linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000009fff0000 (usable)
[ 0.000000] BIOS-e820: 000000009fff0000 - 000000009fff3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000009fff3000 - 00000000a0000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: /SiS-645, BIOS 6.00 PG 03/01/2002
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x9fff0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CBFFF write-protect
[ 0.000000] CC000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 080000000 mask FE0000000 write-back
[ 0.000000] 2 base 0E8000000 mask FFC000000 write-combining
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 363f6000 - 371f3000
[ 0.000000] ACPI: RSDP 000f70c0 00014 (v00 GBT )
[ 0.000000] ACPI: RSDT 9fff3000 00028 (v01 GBT AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 9fff3040 00074 (v01 GBT AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 9fff30c0 03BA4 (v01 GBT AWRDACPI 00001000 MSFT 0100000C)
[ 0.000000] ACPI: FACS 9fff0000 00040
[ 0.000000] 1671MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0009fff0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x000000a0
[ 0.000000] 0: 0x00000100 -> 0x0009fff0
[ 0.000000] On node 0 totalpages: 655232
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4ff6200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3952 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 3344 pages used for memmap
[ 0.000000] HighMem zone: 424674 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Found and enabled local APIC!
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at a0000000 (gap: a0000000:5ec00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77e0000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 650112
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=babf4d35-c063-4093-8f02-5c5a242324d9 ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 5242624 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0009fff0)
[ 0.000000] Memory: 2574220k/2621376k available (3495k kernel code, 46708k reserved, 1237k data, 416k init, 1712072k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369fca - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369fca (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:256 16
[ 0.000000] CPU 0 irqstacks, hard=f4808000 soft=f480a000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1616.079 MHz processor.
[ 0.008004] Calibrating delay loop (skipped), value calculated using timer frequency.. 3232.15 BogoMIPS (lpj=6464316)
[ 0.008016] pid_max: default: 32768 minimum: 301
[ 0.008133] Security Framework initialized
[ 0.008145] AppArmor: AppArmor disabled by boot time parameter
[ 0.008189] Mount-cache hash table entries: 512
[ 0.008680] Initializing cgroup subsys cpuacct
[ 0.008688] Initializing cgroup subsys memory
[ 0.008711] Initializing cgroup subsys devices
[ 0.008719] Initializing cgroup subsys freezer
[ 0.008725] Initializing cgroup subsys net_cls
[ 0.008731] Initializing cgroup subsys blkio
[ 0.008750] Initializing cgroup subsys perf_event
[ 0.008822] CPU0: Hyper-Threading is disabled
[ 0.008831] mce: CPU supports 4 MCE banks
[ 0.008850] CPU0: Thermal monitoring enabled (TM1)
[ 0.008977] SMP alternatives: switching to UP code
[ 0.017394] Freeing SMP alternatives: 16k freed
[ 0.017410] ACPI: Core revision 20120320
[ 0.022105] ACPI: setting ELCR to 0200 (from 1c20)
[ 0.024128] weird, boot CPU (#0) not listed by the BIOS.
[ 0.024134] SMP motherboard not detected.
[ 0.024146] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.028001] SMP disabled
[ 0.028001] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.028001] ... version: 0
[ 0.028001] ... bit width: 40
[ 0.028001] ... generic registers: 18
[ 0.028001] ... value mask: 000000ffffffffff
[ 0.028001] ... max period: 0000007fffffffff
[ 0.028001] ... fixed-purpose events: 0
[ 0.028001] ... event mask: 000000000003ffff
[ 0.036051] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.036140] Brought up 1 CPUs
[ 0.036147] Total of 1 processors activated (3232.15 BogoMIPS).
[ 0.036503] devtmpfs: initialized
[ 0.037112] PM: Registering ACPI NVS region [mem 0x9fff0000-0x9fff2fff] (12288 bytes)
[ 0.037350] dummy:
[ 0.037488] NET: Registered protocol family 16
[ 0.037796] ACPI: bus type pci registered
[ 0.051202] PCI: PCI BIOS revision 2.10 entry at 0xfb2f0, last bus=1
[ 0.051209] PCI: Using configuration type 1 for base access
[ 0.052845] bio: create slab <bio-0> at 0
[ 0.053070] ACPI: Added _OSI(Module Device)
[ 0.053078] ACPI: Added _OSI(Processor Device)
[ 0.053085] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.053093] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.055183] ACPI: EC: Look up EC in DSDT
[ 0.065202] ACPI: Interpreter enabled
[ 0.065223] ACPI: (supports S0 S1 S4 S5)
[ 0.065299] ACPI: Using PIC for interrupt routing
[ 0.076575] ACPI: No dock devices found.
[ 0.076595] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.076772] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.077027] pci_root PNP0A03:00: host bridge window [io 0x0000-0x047f] (ignored)
[ 0.077035] pci_root PNP0A03:00: host bridge window [io 0x0490-0x0cf7] (ignored)
[ 0.077042] pci_root PNP0A03:00: host bridge window [io 0x0d00-0x0fff] (ignored)
[ 0.077050] pci_root PNP0A03:00: host bridge window [io 0x1100-0xffff] (ignored)
[ 0.077057] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.077064] pci_root PNP0A03:00: host bridge window [mem 0xa0000000-0xffee0000] (ignored)
[ 0.077071] PCI: root bus 00: using default resources
[ 0.077169] PCI host bridge to bus 0000:00
[ 0.077178] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.077185] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.077226] pci 0000:00:00.0: [1039:0645] type 00 class 0x060000
[ 0.077250] pci 0000:00:00.0: reg 10: [mem 0xe8000000-0xebffffff]
[ 0.077378] pci 0000:00:01.0: [1039:0001] type 01 class 0x060400
[ 0.077464] pci 0000:00:02.0: [1039:0008] type 00 class 0x060100
[ 0.077591] pci 0000:00:02.0: Enabling SiS 96x SMBus
[ 0.077626] pci 0000:00:02.1: [1039:0016] type 00 class 0x0c0500
[ 0.077714] pci 0000:00:02.1: reg 20: [io 0x5c00-0x5c1f]
[ 0.077785] pci 0000:00:02.2: [1039:7001] type 00 class 0x0c0310
[ 0.077813] pci 0000:00:02.2: reg 10: [mem 0xef004000-0xef004fff]
[ 0.077934] pci 0000:00:02.3: [1039:7001] type 00 class 0x0c0310
[ 0.077962] pci 0000:00:02.3: reg 10: [mem 0xef000000-0xef000fff]
[ 0.078090] pci 0000:00:02.5: [1039:5513] type 00 class 0x010180
[ 0.078177] pci 0000:00:02.5: reg 20: [io 0x4000-0x400f]
[ 0.078278] pci 0000:00:0c.0: [9710:9865] type 00 class 0x070103
[ 0.078314] pci 0000:00:0c.0: reg 10: [io 0xe000-0xe007]
[ 0.078336] pci 0000:00:0c.0: reg 14: [io 0xe400-0xe407]
[ 0.078357] pci 0000:00:0c.0: reg 18: [mem 0xef001000-0xef001fff]
[ 0.078394] pci 0000:00:0c.0: reg 20: [mem 0xef002000-0xef002fff]
[ 0.078463] pci 0000:00:0c.0: PME# supported from D0 D3cold
[ 0.078509] pci 0000:00:0e.0: [10ec:8139] type 00 class 0x020000
[ 0.078547] pci 0000:00:0e.0: reg 10: [io 0xe800-0xe8ff]
[ 0.078569] pci 0000:00:0e.0: reg 14: [mem 0xef003000-0xef0030ff]
[ 0.078649] pci 0000:00:0e.0: reg 30: [mem 0x00000000-0x0000ffff pref]
[ 0.078687] pci 0000:00:0e.0: supports D1 D2
[ 0.078692] pci 0000:00:0e.0: PME# supported from D1 D2 D3hot D3cold
[ 0.078735] pci 0000:00:10.0: [1274:5880] type 00 class 0x040100
[ 0.078770] pci 0000:00:10.0: reg 10: [io 0xec00-0xec3f]
[ 0.078895] pci 0000:00:10.0: supports D1 D2
[ 0.079007] pci 0000:01:00.0: [10de:0110] type 00 class 0x030000
[ 0.079042] pci 0000:01:00.0: reg 10: [mem 0xec000000-0xecffffff]
[ 0.079062] pci 0000:01:00.0: reg 14: [mem 0xe0000000-0xe7ffffff pref]
[ 0.079130] pci 0000:01:00.0: reg 30: [mem 0x00000000-0x0000ffff pref]
[ 0.079238] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.079253] pci 0000:00:01.0: bridge window [mem 0xec000000-0xedffffff]
[ 0.079264] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe7ffffff pref]
[ 0.079284] pci_bus 0000:00: on NUMA node 0
[ 0.079295] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.080411] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0e)
[ 0.117384] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.117563] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.117743] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.117917] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.118095] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.118269] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.118447] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.118626] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 *12 14 15)
[ 0.118883] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.118891] vgaarb: loaded
[ 0.118896] vgaarb: bridge control possible 0000:01:00.0
[ 0.118978] PCI: Using ACPI for IRQ routing
[ 0.118987] PCI: pci_cache_line_size set to 64 bytes
[ 0.119086] reserve RAM buffer: 000000009fff0000 - 000000009fffffff
[ 0.119555] pnp: PnP ACPI init
[ 0.119591] ACPI: bus type pnp registered
[ 0.120131] pnp 00:00: [mem 0x000cfa00-0x000cffff]
[ 0.120141] pnp 00:00: [mem 0x000f0000-0x000f7fff]
[ 0.120148] pnp 00:00: [mem 0x000f8000-0x000fbfff]
[ 0.120155] pnp 00:00: [mem 0x000fc000-0x000fffff]
[ 0.120165] pnp 00:00: [mem 0x9fff0000-0x9fffffff]
[ 0.120171] pnp 00:00: [mem 0xffff0000-0xffffffff]
[ 0.120178] pnp 00:00: [mem 0x00000000-0x0009ffff]
[ 0.120184] pnp 00:00: [mem 0x00100000-0x9ffeffff]
[ 0.120191] pnp 00:00: [mem 0xffee0000-0xffefffff]
[ 0.120198] pnp 00:00: [mem 0xfffe0000-0xfffeffff]
[ 0.120204] pnp 00:00: [mem 0xfec00000-0xfec00fff]
[ 0.120211] pnp 00:00: [mem 0xfee00000-0xfeefffff]
[ 0.120319] system 00:00: [mem 0x000cfa00-0x000cffff] has been reserved
[ 0.120330] system 00:00: [mem 0x000f0000-0x000f7fff] could not be reserved
[ 0.120339] system 00:00: [mem 0x000f8000-0x000fbfff] could not be reserved
[ 0.120347] system 00:00: [mem 0x000fc000-0x000fffff] could not be reserved
[ 0.120356] system 00:00: [mem 0x9fff0000-0x9fffffff] could not be reserved
[ 0.120364] system 00:00: [mem 0xffff0000-0xffffffff] has been reserved
[ 0.120372] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.120381] system 00:00: [mem 0x00100000-0x9ffeffff] could not be reserved
[ 0.120389] system 00:00: [mem 0xffee0000-0xffefffff] has been reserved
[ 0.120397] system 00:00: [mem 0xfffe0000-0xfffeffff] has been reserved
[ 0.120405] system 00:00: [mem 0xfec00000-0xfec00fff] has been reserved
[ 0.120414] system 00:00: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.120424] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.120574] pnp 00:01: [bus 00-ff]
[ 0.120582] pnp 00:01: [io 0x0cf8-0x0cff]
[ 0.120589] pnp 00:01: [io 0x0000-0x047f window]
[ 0.120595] pnp 00:01: [io 0x0480-0x048f]
[ 0.120602] pnp 00:01: [io 0x0490-0x0cf7 window]
[ 0.120608] pnp 00:01: [io 0x0d00-0x0fff window]
[ 0.120615] pnp 00:01: [io 0x1000-0x107f]
[ 0.120621] pnp 00:01: [io 0x1080-0x10ff]
[ 0.120627] pnp 00:01: [io 0x5c00-0x5c7f]
[ 0.120634] pnp 00:01: [io 0x1100-0xffff window]
[ 0.120641] pnp 00:01: [mem 0x000a0000-0x000bffff window]
[ 0.120648] pnp 00:01: [mem 0xa0000000-0xffee0000 window]
[ 0.120746] pnp 00:01: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.121437] pnp 00:02: [io 0x0010-0x001f]
[ 0.121445] pnp 00:02: [io 0x0022-0x003f]
[ 0.121451] pnp 00:02: [io 0x0044-0x005f]
[ 0.121457] pnp 00:02: [io 0x0062-0x0063]
[ 0.121463] pnp 00:02: [io 0x0065-0x006f]
[ 0.121469] pnp 00:02: [io 0x0074-0x007f]
[ 0.121475] pnp 00:02: [io 0x0091-0x0093]
[ 0.121482] pnp 00:02: [io 0x00a2-0x00bf]
[ 0.121488] pnp 00:02: [io 0x00e0-0x00ef]
[ 0.121494] pnp 00:02: [io 0x04d0-0x04d1]
[ 0.121500] pnp 00:02: [io 0x0800-0x0805]
[ 0.121621] system 00:02: [io 0x04d0-0x04d1] has been reserved
[ 0.121630] system 00:02: [io 0x0800-0x0805] has been reserved
[ 0.121639] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.121684] pnp 00:03: [dma 4]
[ 0.121692] pnp 00:03: [io 0x0000-0x000f]
[ 0.121698] pnp 00:03: [io 0x0080-0x0090]
[ 0.121704] pnp 00:03: [io 0x0094-0x009f]
[ 0.121710] pnp 00:03: [io 0x00c0-0x00df]
[ 0.121794] pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.121833] pnp 00:04: [io 0x0070-0x0073]
[ 0.121845] pnp 00:04: [irq 8]
[ 0.121929] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.121964] pnp 00:05: [io 0x0061]
[ 0.122050] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.122083] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.122092] pnp 00:06: [irq 13]
[ 0.122182] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.122549] pnp 00:07: [io 0x03f0-0x03f5]
[ 0.122557] pnp 00:07: [io 0x03f7]
[ 0.122563] pnp 00:07: [irq 6]
[ 0.122569] pnp 00:07: [dma 2]
[ 0.122707] pnp 00:07: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.123189] pnp 00:08: [io 0x03f8-0x03ff]
[ 0.123197] pnp 00:08: [irq 4]
[ 0.123384] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.123908] pnp 00:09: [io 0x02f8-0x02ff]
[ 0.123916] pnp 00:09: [irq 3]
[ 0.124115] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.124848] pnp 00:0a: [io 0x0378-0x037f]
[ 0.124856] pnp 00:0a: [irq 7]
[ 0.125000] pnp 00:0a: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.125351] pnp 00:0b: [io 0x0060]
[ 0.125358] pnp 00:0b: [io 0x0064]
[ 0.125482] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.125858] pnp: PnP ACPI: found 12 devices
[ 0.125864] ACPI: ACPI bus type pnp unregistered
[ 0.125875] PnPBIOS: Disabled by ACPI PNP
[ 0.165044] Switching to clocksource acpi_pm
[ 0.165122] pci 0000:00:0e.0: BAR 6: assigned [mem 0xa0000000-0xa000ffff pref]
[ 0.165136] pci 0000:01:00.0: BAR 6: assigned [mem 0xed000000-0xed00ffff pref]
[ 0.165144] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.165157] pci 0000:00:01.0: bridge window [mem 0xec000000-0xedffffff]
[ 0.165169] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe7ffffff pref]
[ 0.165197] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.165205] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.165212] pci_bus 0000:01: resource 1 [mem 0xec000000-0xedffffff]
[ 0.165219] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xe7ffffff pref]
[ 0.165368] NET: Registered protocol family 2
[ 0.165509] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.165968] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.167160] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.167896] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.167906] TCP: reno registered
[ 0.167919] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.167951] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.167951] NET: Registered protocol family 1
[ 0.167951] ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 5
[ 0.167951] PCI: setting IRQ 5 as level-triggered
[ 0.167951] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 12
[ 0.167951] PCI: setting IRQ 12 as level-triggered
[ 0.167951] pci 0000:01:00.0: Boot video device
[ 0.167951] PCI: CLS 32 bytes, default 64
[ 0.168111] Unpacking initramfs...
[ 0.888400] Freeing initrd memory: 14324k freed
[ 0.907630] audit: initializing netlink socket (disabled)
[ 0.907668] type=2000 audit(1558423083.904:1): initialized
[ 0.929978] highmem bounce pool size: 64 pages
[ 0.929994] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.930315] VFS: Disk quotas dquot_6.5.2
[ 0.930374] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.930551] msgmni has been set to 1711
[ 0.930931] alg: No test for stdrng (krng)
[ 0.930999] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.931008] io scheduler noop registered
[ 0.931014] io scheduler deadline registered
[ 0.931046] io scheduler cfq registered (default)
[ 0.931235] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.931289] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.931296] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.932296] vesafb: mode is 1024x768x32, linelength=4096, pages=0
[ 0.932303] vesafb: scrolling: redraw
[ 0.932311] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.933251] vesafb: framebuffer at 0xe0000000, mapped to 0xf8080000, using 3072k, total 3072k
[ 0.973503] Console: switching to colour frame buffer device 128x48
[ 1.013468] fb0: VESA VGA frame buffer device
[ 1.013596] GHES: HEST is not enabled!
[ 1.013632] isapnp: Scanning for PnP cards...
[ 1.324579] isapnp: No Plug & Play device found
[ 1.324683] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.345198] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.365709] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.386667] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.407283] 00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.407599] Linux agpgart interface v0.103
[ 1.407815] agpgart-sis 0000:00:00.0: SiS chipset [1039/0645]
[ 1.412485] agpgart-sis 0000:00:00.0: AGP aperture is 64M @ 0xe8000000
[ 1.412778] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.664121] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.664362] mousedev: PS/2 mouse device common for all mice
[ 1.664467] rtc_cmos 00:04: RTC can wake from S4
[ 1.664693] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.664729] rtc0: alarms up to one year, 242 bytes nvram
[ 1.664996] TCP: cubic registered
[ 1.665093] NET: Registered protocol family 10
[ 1.665589] Mobile IPv6
[ 1.665599] NET: Registered protocol family 17
[ 1.665612] Registering the dns_resolver key type
[ 1.665731] Using IPI No-Shortcut mode
[ 1.665972] PM: Hibernation image not present or could not be loaded.
[ 1.666005] registered taskstats version 1
[ 1.666459] rtc_cmos 00:04: setting system clock to 2019-05-21 07:18:05 UTC (1558423085)
[ 1.666651] Freeing unused kernel memory: 416k freed
[ 1.667308] Write protecting the kernel text: 3496k
[ 1.667351] Write protecting the kernel read-only data: 984k
[ 1.684330] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.726968] udevd[50]: starting version 175
[ 1.862820] usbcore: registered new interface driver usbfs
[ 1.862890] usbcore: registered new interface driver hub
[ 1.916125] Refined TSC clocksource calibration: 1616.131 MHz.
[ 1.916144] Switching to clocksource tsc
[ 1.927925] Floppy drive(s): fd0 is 1.44M
[ 1.932178] usbcore: registered new device driver usb
[ 1.933109] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.933251] ohci_hcd 0000:00:02.2: OHCI Host Controller
[ 1.933321] ohci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 1
[ 1.933366] ohci_hcd 0000:00:02.2: irq 5, io mem 0xef004000
[ 1.976184] FDC 0 is a post-1991 82077
[ 1.990197] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.990209] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.990217] usb usb1: Product: OHCI Host Controller
[ 1.990223] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 1.990230] usb usb1: SerialNumber: 0000:00:02.2
[ 1.990551] hub 1-0:1.0: USB hub found
[ 1.990568] hub 1-0:1.0: 3 ports detected
[ 1.990837] ohci_hcd 0000:00:02.3: OHCI Host Controller
[ 1.990870] ohci_hcd 0000:00:02.3: new USB bus registered, assigned bus number 2
[ 1.990910] ohci_hcd 0000:00:02.3: irq 12, io mem 0xef000000
[ 1.995448] SCSI subsystem initialized
[ 1.999323] 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 2.040682] libata version 3.00 loaded.
[ 2.046206] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.046218] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.046226] usb usb2: Product: OHCI Host Controller
[ 2.046232] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 2.046238] usb usb2: SerialNumber: 0000:00:02.3
[ 2.046563] hub 2-0:1.0: USB hub found
[ 2.046580] hub 2-0:1.0: 3 ports detected
[ 2.046789] 8139cp 0000:00:0e.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
[ 2.048104] 8139too: 8139too Fast Ethernet driver 0.9.28
[ 2.048453] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 2.048461] PCI: setting IRQ 11 as level-triggered
[ 2.049324] 8139too 0000:00:0e.0: eth0: RealTek RTL8139 at 0xe800, 00:50:bf:d5:6d:e0, IRQ 11
[ 2.055538] pata_sis 0000:00:02.5: version 0.5.2
[ 2.059323] scsi0 : pata_sis
[ 2.062147] scsi1 : pata_sis
[ 2.070105] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x4000 irq 14
[ 2.070115] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x4008 irq 15
[ 2.248444] ata1.00: ATAPI: TSSTcorpDVD-ROM SH-D162C, TS00, max UDMA/33
[ 2.280290] ata1.00: configured for UDMA/33
[ 2.281319] scsi 0:0:0:0: CD-ROM TSSTcorp DVD-ROM SH-D162C TS00 PQ: 0 ANSI: 5
[ 2.364038] usb 1-1: new low-speed USB device number 2 using ohci_hcd
[ 2.452607] ata2.01: ATA-7: Maxtor 6E040L0, NAR61590, max UDMA/133
[ 2.452616] ata2.01: 80293248 sectors, multi 16: LBA
[ 2.452628] ata2.01: limited to UDMA/33 due to 40-wire cable
[ 2.468397] ata2.01: configured for UDMA/33
[ 2.468619] scsi 1:0:1:0: Direct-Access ATA Maxtor 6E040L0 NAR6 PQ: 0 ANSI: 5
[ 2.489057] sd 1:0:1:0: [sda] 80293248 512-byte logical blocks: (41.1 GB/38.2 GiB)
[ 2.489227] sd 1:0:1:0: [sda] Write Protect is off
[ 2.489236] sd 1:0:1:0: [sda] Mode Sense: 00 3a 00 00
[ 2.489307] sd 1:0:1:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.578061] usb 1-1: New USB device found, idVendor=045e, idProduct=00cb
[ 2.578071] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.578079] usb 1-1: Product: Microsoft Basic Optical Mouse v2.0
[ 2.578085] usb 1-1: Manufacturer: Microsoft
[ 3.210145] sda: sda1 sda2 < sda5 >
[ 3.210988] sd 1:0:1:0: [sda] Attached SCSI disk
[ 3.217032] sr0: scsi3-mmc drive: 4x/48x cd/rw xa/form2 cdda tray
[ 3.217045] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.218077] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 3.237408] input: Microsoft Microsoft Basic Optical Mouse v2.0 as /devices/pci0000:00/0000:00:02.2/usb1/1-1/1-1:1.0/input/input1
[ 3.237799] generic-usb 0003:045E:00CB.0001: input,hidraw0: USB HID v1.11 Mouse [Microsoft Microsoft Basic Optical Mouse v2.0 ] on usb-0000:00:02.2-1/input0
[ 3.238318] usbcore: registered new interface driver usbhid
[ 3.238328] usbhid: USB HID core driver
[ 3.622846] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.343031] init: ureadahead main process (184) terminated with status 5
[ 6.670200] Adding 2618364k swap on /dev/sda5. Priority:-1 extents:1 across:2618364k
[ 6.905516] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 8.745970] udevd[312]: starting version 175
[ 9.683695] lp: driver loaded but no devices found
[ 11.338685] parport_pc 00:0a: reported by Plug and Play ACPI
[ 11.338749] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 11.345925] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 11.345943] ACPI: Power Button [PWRB]
[ 11.346181] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3
[ 11.346195] ACPI: Sleep Button [FUTS]
[ 11.346443] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 11.346455] ACPI: Power Button [PWRF]
[ 11.444487] lp0: using parport0 (interrupt-driven).
[ 11.448166] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 10
[ 11.448176] PCI: setting IRQ 10 as level-triggered
[ 11.448189] PCI parallel port detected: 14f2:0121, I/O at 0xe000(0x0), IRQ 10
[ 11.448220] parport1: PC-style at 0xe000, irq 10 [PCSPP,TRISTATE,EPP]
[ 11.544389] lp1: using parport1 (interrupt-driven).
[ 11.628803] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 11.665064] sis96x_smbus 0000:00:02.1: SiS96x SMBus base address: 0x5c00
[ 11.853513] wmi: Mapper loaded
[ 12.019753] ppdev: user-space parallel port driver
[ 13.241302] [drm] Initialized drm 1.1.0 20060810
[ 13.533019] microcode: CPU0 sig=0xf24, pf=0x4, revision=0x7
[ 13.747433] [drm] nouveau 0000:01:00.0: Detected an NV10 generation card (0x011000b2)
[ 13.750148] checking generic (e0000000 300000) vs hw (e0000000 8000000)
[ 13.750157] fb: conflicting fb hw usage nouveaufb vs VESA VGA - removing generic driver
[ 13.750285] Console: switching to colour dummy device 80x25
[ 13.755437] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS
[ 13.792866] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 13.792876] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN
[ 13.793032] [drm] nouveau 0000:01:00.0: BMP BIOS found
[ 13.793038] [drm] nouveau 0000:01:00.0: BMP version 5.20
[ 13.793047] [drm] nouveau 0000:01:00.0: Bios version 03.11.01.30
[ 13.793054] [drm] nouveau 0000:01:00.0: No useful DCB data in VBIOS
[ 13.793651] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do
[ 13.794591] [drm] nouveau 0000:01:00.0: Detected TV encoder: ch7006
[ 13.794734] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xAB96
[ 13.794756] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xB284
[ 13.794767] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xABB1
[ 13.794791] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xB22B
[ 13.794805] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xAC44
[ 13.794813] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 5 at offset 0xAD98
[ 13.794838] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 6 at offset 0xAC69
[ 13.865016] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 7 at offset 0xAD33
[ 13.865325] [TTM] Zone kernel: Available graphics memory: 438452 kiB
[ 13.865333] [TTM] Zone highmem: Available graphics memory: 1294488 kiB
[ 13.865339] [TTM] Initializing pool allocator
[ 13.865368] [drm] nouveau 0000:01:00.0: Detected 64MiB VRAM (SDRAM)
[ 13.865735] agpgart-sis 0000:00:00.0: AGP 2.0 bridge
[ 13.865776] agpgart-sis 0000:00:00.0: putting AGP V2 device into 4x mode
[ 13.865846] nouveau 0000:01:00.0: putting AGP V2 device into 4x mode
[ 13.865856] [drm] nouveau 0000:01:00.0: 64 MiB GART (aperture)
[ 13.867572] [drm] nouveau 0000:01:00.0: Detected TV encoder: ch7006
[ 14.075403] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 14.322343] i2c-core: driver [ch7006] using legacy suspend method
[ 14.322353] i2c-core: driver [ch7006] using legacy resume method
[ 14.329935] ch7006 2-0075: Detected version ID: 50
[ 14.362302] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 14.362314] [drm] No driver support for vblank timestamp query.
[ 14.362468] [drm] nouveau 0000:01:00.0: 0 available performance level(s)
[ 14.362478] [drm] nouveau 0000:01:00.0: c: core 199MHz memory 334MHz
[ 14.432406] Bluetooth: Core ver 2.16
[ 14.432517] NET: Registered protocol family 31
[ 14.432525] Bluetooth: HCI device and connection manager initialized
[ 14.432533] Bluetooth: HCI socket layer initialized
[ 14.432538] Bluetooth: L2CAP socket layer initialized
[ 14.432553] Bluetooth: SCO socket layer initialized
[ 14.459014] [drm] nouveau 0000:01:00.0: allocated 1024x768 fb: 0x48000, bo f6e8d400
[ 14.459492] fbcon: nouveaufb (fb0) is primary device
[ 14.526565] Console: switching to colour frame buffer device 128x48
[ 14.527884] fb0: nouveaufb frame buffer device
[ 14.527891] drm: registered panic notifier
[ 14.527906] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0
[ 14.542211] NET: Registered protocol family 4
[ 14.635503] NET: Registered protocol family 5
[ 15.449308] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.449318] Bluetooth: BNEP filters: protocol multicast
[ 17.502120] init: failsafe main process (627) killed by TERM signal
[ 21.297719] 8139too 0000:00:0e.0: eth0: link down
[ 21.297985] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 34.856911] fuse init (API version 7.18)
[ 59.274071] I-pipe: head domain RTAI registered.
[ 59.274090] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 59.274106] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 59.274115] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6312975, CLK_FREQ 1616079000, CPU_FREQ 1616079000
[ 59.274123] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 59.274131] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6312975, 6312975, 6252000
[ 59.372637] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 59.372718] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 59.372731] RTAI[sched]: hard timer type/freq = APIC/6312975(Hz); default timing: oneshot; linear timed lists.
[ 59.372740] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1616079000 hz.
[ 59.372746] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 59.426864] RTAI[math]: loaded.
[ 62.700325] RTAI[math]: unloaded.
[ 62.707188] SCHED releases registered named ALIEN PEDV$D
[ 62.730620] RTAI[malloc]: unloaded.
[ 62.828138] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 62.841218] I-pipe: head domain RTAI unregistered.
[ 62.841243] RTAI[hal]: unmounted.
[ 182.617234] I-pipe: head domain RTAI registered.
[ 182.617252] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 182.617269] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 182.617278] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6312975, CLK_FREQ 1616079000, CPU_FREQ 1616079000
[ 182.617285] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 182.617293] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6312975, 6312975, 6256750
[ 182.648215] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 182.648308] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 182.648321] RTAI[sched]: hard timer type/freq = APIC/6312975(Hz); default timing: oneshot; linear timed lists.
[ 182.648330] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1616079000 hz.
[ 182.648336] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 182.687266] RTAI[math]: loaded.
[ 185.710980] RTAI[math]: unloaded.
[ 185.717964] SCHED releases registered named ALIEN PEDV$D
[ 185.743089] RTAI[malloc]: unloaded.
[ 185.840050] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 185.847091] I-pipe: head domain RTAI unregistered.
[ 185.847117] RTAI[hal]: unmounted.
Its a configuration meant to drive a 5 dof robot (5 servo motors). The only difference since last Friday that it was functional was that yesterday i tried to copy the linuxcnc file (with all its contents) under my home directory to usb drive in order to move the configuration to a new pc (if you know how to do this, your help is much appreciated) from terminal with command cp -r etc. Thanks in advance.
23 May 2019 01:39 #134639 by tommylight
Replied by tommylight on topic LinuxCNC crashes
There is something missing in the shared libraries, try to google where those libraries should reside and try to copy the missing ones.
The following user(s) said Thank You: m.bofi
23 May 2019 03:19 #134654 by rodw
Replied by rodw on topic LinuxCNC crashes
When this happens to me its becasue I forgot to compile a custom component
That does not sound like a standard library
23 May 2019 08:05 #134670 by Hakan
Replied by Hakan on topic LinuxCNC crashes
apt-get install libreadline5
Something seems to be quite old, a module or linuxcnc is compiled on an other computer perhaps.
The above should fix it.
23 May 2019 10:01 - 23 May 2019 10:02 #134681 by m.bofi
Replied by m.bofi on topic LinuxCNC crashes
As until a few minutes ago the pc didnt have access to the internet as it was in the lab of my university. The course of action i took was to find the libreadline.so.5 in the pc but that failed. What i discoverd was that in ../usr/lib/i386-linux-gnu/ existed libreadline.so.6 and libreadline.so library file what i did was create libreadline.so.5 as a mirror image of existing libreadline.so (basically cd to the folder mentioned and sudo cp libreadline.so libreadline.so.5). I know my solution is a bit childish but it worked and nothing else seems affected. I still cant understand what caused the problem though. Anyway, thanks everyone for your answers!
Last edit: 23 May 2019 10:02 by m.bofi.
Time to create page: 0.370 seconds
