Problem parralel Port is not reconized in stretch configuration
- Philippe
28 May 2019 06:04 #135125
by Philippe
Problem parralel Port is not reconized in stretch configuration was created by Philippe
Hello all,
i make the migration wheezy to stretch and I dont have the parralel port.
i test with the 32 and 64 bits solution and is the same , no parralel port.
thanx for your repplies
Philippe
Philippe
- pl7i92
- Thank you received: 358
28 May 2019 06:22 #135126
by pl7i92
Replied by pl7i92 on topic Problem parralel Port is not reconized in stretch configuration
Please check the Bios
after you maybe deletet the partition and reinstalled the system
what does
dmesg | grep parpo*
output
what does
dmesg | grep parpo*
output
- Philippe
28 May 2019 06:36 #135129
by Philippe
Replied by Philippe on topic Problem parralel Port is not reconized in stretch configuration
For me the parralel card is ok on the bios because I've dual boot on my PC and the parallel port work well with Mach3, so no problem on Hardware
Philippe
Philippe
- pl7i92
28 May 2019 08:23 #135135
by pl7i92
what does the Terminal info provide
PLEASE Check
dmesg | grep parpo*
[ 8.534950] parport_pc 00:01: reported by Plug and Play ACPI
[ 8.535023] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 8.636217] lp0: using parport0 (interrupt-driven).
PLEASE Check
dmesg | grep parpo*
- Philippe
28 May 2019 11:27 #135156
by Philippe
I'm sorry but i don't understand what do you say.
how i check your request, i'm not an informatician.
philippe
philippe
- Thank you received: 1479
28 May 2019 11:28 #135157
Replied by Todd Zuercher on topic Problem parralel Port is not reconized in stretch configuration
What kind of parallel port do you have? Is it an add in card, PCI, PCIe, something else?
- bevins
- Thank you received: 338
28 May 2019 14:12 #135169
by bevins
He means open a terminal and type: dmesg | grep parpo*
Paste the results here.
Replied by bevins on topic Problem parralel Port is not reconized in stretch configuration
philippe
- Philippe
28 May 2019 16:09 #135177
by Philippe
yes is an add card in PCI port
- Thank you received: 5330
28 May 2019 16:28 #135179
Replied by PCW on topic Problem parralel Port is not reconized in stretch configuration
If its an add-in card, what did you use for the parallel port address in your hal or ini file?
- Philippe
29 May 2019 17:02 #135299
by Philippe
When i put dmesg | grep parpo* in the terminal noting appends
Time to create page: 0.145 seconds
