(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
6 years 8 months ago #157156 by phillc54
tommylight wrote: WARNING:
Do not change the title of the topic when replying to it, please.
Had a shock when i saw a title i could not recognize started by me !!! :)
It would be nice if that could be prevented...
  • BeagleBrainz
  • New Member
  • New Member
6 years 8 months ago #157157 by BeagleBrainz
How the hell does that happen ?
I can see the subject box, but wow changing a title doesn't seem right.
6 years 8 months ago #157158 by tommylight
aaaaand it's back !!!
Now i have to edit the original post to set it back, again!
I agree that this should be prevented, it causes a mess for searching with the added load on the server when adding another copy of the same topic to the database.
6 years 8 months ago - 6 years 8 months ago #157162 by Clive S
Files now available, as usual tested in Vbox
md5: 86 bytes (86 bytes)
drive.google.com/open?id=1jcSdgUkSubGNo8oRt_acU_0sjqCFJZyN
iso: 2.3 GB (2340421632 bytes):
drive.google.com/open?id=17f4FhtF5hayFpumpNHrGFyJ0OQlRb9aT
Enjoy
Ok I have put the above on a stick using Win32DiskImager everything went to plan and just worked.
Q. What is the difference between the two iso's . ie the one above and the one from the 11th LinuxMint-19.2-LCNC-2.9-rt-4.16.12-kona-amd64
Thanks again for the hard work you are putting into this.
Last edit: 6 years 8 months ago by Clive S.
The following user(s) said Thank You: BeagleBrainz
6 years 8 months ago #157163 by tommylight
Clive S wrote: Q. What is the difference between the two iso's . ie the one above and the one from the 11th LinuxMint-19.2-LCNC-2.9-rt-4.16.12-kona-amd64
This one has working QTVCP already installed.
  • BeagleBrainz
  • New Member
  • New Member
6 years 8 months ago - 6 years 8 months ago #157166 by BeagleBrainz
I'll try to do a change log type post when I through up a new version.
Next one, hopefully, will be a RTAI version. Had some issues with Andy's test linuxcnc packages relating to qtvcp designer. Posted up on the thread to see if there's some I screwed up.
Am currently building Linuxcnc 2.9 rtai packages and will see how it goes.
Once again big thanks to all who have downloaded the images and given them a twirl. Very much appreciated.
Cheers
Rob
Last edit: 6 years 8 months ago by BeagleBrainz.
