(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
7 years 4 months ago - 5 years 3 months ago #137159
(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation was created by tommylight
Please use the official release found here:
linuxcnc.org/downloads/
Use this tutorial only if you have issues with dirvers, be it WiFi or graphic or else, ..
EDIT: Updated for Buster repo since Strech is not built any more.
This is an easy way to have LinuxCNC running very quickly on Linux Mint 19.3, Mate and XFCE edition work, Cinnamon might not.
Download Mate version from here:
OR, not both
XFCE version form here:
-Install Linux Mint 19.3
-Copy and paste these lines in terminal, one by one:
-For Master version, unstable, still under development
-OR, not both.
-For 2.8 version, stable, to be current release
If the above keyserver does not work, try these:
OR
OR
Editing the GRUB menu
How to use:
itsfoss.com/grub-customizer-ubuntu/
It is for Ubuntu, same applies for Mint.
-For LinuxCNC dev, this package is also needed:
----Reboot, enjoy.
https://www.linuxmint.com/edition.php?id=276
https://www.linuxmint.com/edition.php?id=278
sudo apt update
wget http://ftp.us.debian.org/debian/pool/main/l/linux/linux-image-4.9.0-13-rt-amd64_4.9.228-1_amd64.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/g/gcc-10/gcc-10-base_10.3.0-1ubuntu1~20.04_amd64.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/g/gcc-10/libgcc-s1_10.3.0-1ubuntu1~20.04_amd64.deb
wget http://archive.ubuntu.com/ubuntu/pool/universe/b/boost1.67/libboost-python1.67.0_1.67.0-17ubuntu8_amd64.deb
wget http://archive.ubuntu.com/ubuntu/pool/universe/libm/libmodbus/libmodbus5_3.1.6-2_amd64.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/libu/libusb-1.0/libusb-1.0-0_1.0.23-2build1_amd64.deb
sudo gdebi linux-image-4.9.0-13-rt-amd64_4.9.228-1_amd64.deb
sudo gdebi gcc-10-base_10.3.0-1ubuntu1~20.04_amd64.deb
sudo gdebi libgcc-s1_10.3.0-1ubuntu1~20.04_amd64.deb
sudo gdebi libboost-python1.67.0_1.67.0-17ubuntu8_amd64.deb
sudo gdebi libmodbus5_3.1.6-2_amd64.deb
sudo gdebi libusb-1.0-0_1.0.23-2build1_amd64.deb
sudo apt-key adv --keyserver hkp://keys.gnupg.net:80 --recv-key EF1B07FEE0EE663E
sudo apt-add-repository 'deb http://buildbot.linuxcnc.org/ buster master-rtpreempt'
sudo apt-add-repository 'deb http://buildbot.linuxcnc.org/ buster 2.8-rtpreempt'
sudo apt-get update
sudo apt-get -y install linuxcnc-uspace
sudo apt-key adv --keyserver hkp://keys.openpgp.org --recv-key EF1B07FEE0EE663E
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com --recv-key EF1B07FEE0EE663E
sudo apt-key adv --keyserver hkp://pgpkeys.eu --recv-key EF1B07FEE0EE663E
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt-get update
sudo apt-get install grub-customizer
How to use:
wget http://ftp.br.debian.org/debian/pool/main/y/yapps2/python-yapps_2.2.1-3_all.deb
sudo gdebi python-yapps_2.2.1-3_all.deb
sudo apt install linuxcnc-uspace-dev
Last edit: 5 years 3 months ago by tommylight. Reason: updated to Buster repo, added dev
The following user(s) said Thank You: BigJohnT, bevins, akb1212, Clive S, tjmarch, tivoi, Nitram, ytiuqibu, JohnnyCNC, macsddau@linuxcnc and 8 other people also said thanks.
- pl7i92
- Thank you received: 358
7 years 4 months ago #137172
by pl7i92
Replied by pl7i92 on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
-Install Linux Mint 19.1
is this the standard dektop or only the low level minimum install you requirer
7 years 4 months ago #137185
Replied by tommylight on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Linux Mint 19.1 with mate desktop, normal version with everything included.
- pl7i92
7 years 4 months ago #137195
by pl7i92
Thank you there is the main link to the download
linuxmint.com/download.php
The following user(s) said Thank You: tommylight, macsddau@linuxcnc
7 years 1 month ago #145777
This also works with 19.2 Mate version of Linux Mint, tested last night.
Install Mint, install Linux image, install Linux headers, install Linuxcnc, reboot.
It is as simple as that, and yes you Can install everything and then reboot.
- pmconsulting
- Thank you received: 4
7 years 2 weeks ago - 7 years 2 weeks ago #148033
by pmconsulting
Replied by pmconsulting on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
This is really terrific! After days of bumbling with hopelessly complicated approaches & endless dead ends, I was able to install the kernel, linuxcnc, reboot & go.
One really dumb question, though: Where doe it install the linuxcnc configurations? I've backed up all of my old configurations from a prior, Debian system and want to restore them to the linuxcnc directory structure, but can't find it in my own home directory.
Where does this approach put the linuxcnc configurations?
Answered my own, dumb question: I launched Pncconf & made a config. It created the linuxcnc directory & substructure in my home directory. Bingo!
Again, after all I've struggled with & tried over & over again, this is an amazingly simple approach that worked in a few clicks.
Last edit: 7 years 2 weeks ago by pmconsulting.
7 years 2 weeks ago #148034
Start Linuxcnc from the meny and choose whatever config, it will ask to save it so say yes, it makes the Linuxcnc folder in the home directory, inside there should be the config folder so copy your config there.
The following user(s) said Thank You: pmconsulting
- Samuelx
7 years 1 week ago - 7 years 1 week ago #148921
by Samuelx
Replied by Samuelx on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Sorry, got it work, my mistake
clicked wrong packets
/linuxcnc-uspace-dev_2.9.0~pre0.768.ga8fe34c55_amd64.deb
Last edit: 7 years 1 week ago by Samuelx.
7 years 1 week ago #148929
Nice!Samuelx wrote: Sorry, got it work, my mistake
- Nitram
- Thank you received: 15
7 years 4 days ago - 7 years 4 days ago #149248
by Nitram
Replied by Nitram on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Thanks for everyone's input on this, I have found the above is really a very easy pathway to get a system going for LinuxCNC.
One thing which may assist, in my situation, I had very slow boot times with the 4.16.12-rt5-kona-rt_amd64 kernel.
Using the 4.14.28-rt23-kona-rt_amd64 from the same page resolved this.
Latency testing results are unchanged.
Last edit: 7 years 4 days ago by Nitram.
Time to create page: 0.159 seconds
