First Run - Crashing on startup
- randypetersen
- Thank you received: 15
19 Jun 2019 23:04 #137313
by randypetersen
First Run - Crashing on startup was created by randypetersen
Probably something super simple here... Did I install the wrong version?
Older HP core2duo I believe, I can get full specs, I thought it would run LinuxCNC fine, but I can get better machine lined up if need be. I had a different version, but I believe since I am using the 7i92 with 7i77 I needed this version. Tried going through config builder a few times, but can't get it to actually open up. Crashes on startup. I tried 7i92 software downloaded from mesa site, but can't get linuxCNC to open that config.
Sorry for the newb question! I read through a few forum post, but didn't think I was having same problem, so I thought I'd post the log in case someone noticed something obvious. Is it parallel port not found causing it to crash?
Thanks for any input!!!
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
Machine configuration directory is '/home/user/linuxcnc/configs/my-mill'
Machine configuration file is 'my-mill.ini'
INIFILE=/home/user/linuxcnc/configs/my-mill/my-mill.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./my-mill.hal
config string '0 out'
Killing task linuxcncsvr, PID=7358
Debug file information:
Note: Using POSIX realtime
Linux parallel port #0 not found
hal_parport: rtapi_app_main: No such file or directory (-2)
./my-mill.hal:6: waitpid failed /usr/bin/rtapi_app hal_parport
./my-mill.hal:6: /usr/bin/rtapi_app exited without becoming ready
./my-mill.hal:6: insmod for hal_parport failed, returned -1
7358
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Linux version 4.9.0-8-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08)
[ 0.000000] x86/fpu: Legacy x87 FPU detected.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009afff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009b000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e4000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007ff9ffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007ffa0000-0x000000007ffadfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000007ffae000-0x000000007ffdffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007ffe0000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fff00000-0x00000000ffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: HP-Pavilion FK484AV-ABA m9400t/Benicia, BIOS 5.33 11/07/2008
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x7ffa0 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-DFFFF write-protect
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [c00ff780]
[ 0.000000] initial memory mapped: [mem 0x00000000-0x0fffffff]
[ 0.000000] Base memory trampoline at [c0097000] 97000 size 16384
[ 0.000000] BRK [0x0fa61000, 0x0fa61fff] PGTABLE
[ 0.000000] BRK [0x0fa62000, 0x0fa63fff] PGTABLE
[ 0.000000] BRK [0x0fa64000, 0x0fa64fff] PGTABLE
[ 0.000000] BRK [0x0fa65000, 0x0fa65fff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x353a9000-0x369cbfff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000FC440 000014 (v00 HPQOEM)
[ 0.000000] ACPI: RSDT 0x000000007FFA0000 000044 (v01 HPQOEM SLIC-CPC 20081107 MSFT 00000097)
[ 0.000000] ACPI: FACP 0x000000007FFA0200 000084 (v02 HPQOEM SLIC-CPC 20081107 MSFT 00000097)
[ 0.000000] ACPI: DSDT 0x000000007FFA0440 004E91 (v01 HPQOEM SLIC-CPC 00000000 INTL 20051117)
[ 0.000000] ACPI: FACS 0x000000007FFAE000 000040
[ 0.000000] ACPI: APIC 0x000000007FFA0390 00006C (v01 HPQOEM SLIC-CPC 20081107 MSFT 00000097)
[ 0.000000] ACPI: MCFG 0x000000007FFA0400 00003C (v01 HPQOEM SLIC-CPC 20081107 MSFT 00000097)
[ 0.000000] ACPI: OEMB 0x000000007FFAE040 000072 (v01 HPQOEM SLIC-CPC 20081107 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x000000007FFA52E0 000038 (v01 HPQOEM SLIC-CPC 20081107 MSFT 00000097)
[ 0.000000] ACPI: GSCI 0x000000007FFAE0C0 002024 (v01 HPQOEM SLIC-CPC 20081107 MSFT 00000097)
[ 0.000000] ACPI: SLIC 0x000000007FFB00F0 000176 (v01 HPQOEM SLIC-CPC 00000001 MSFT 00000001)
[ 0.000000] ACPI: SSDT 0x000000007FFB14B0 00082F (v01 HPQOEM SLIC-CPC 00000012 INTL 20051117)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1157MB HIGHMEM available.
[ 0.000000] 889MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 379fe000
[ 0.000000] low ram: 0 - 379fe000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] Normal [mem 0x0000000001000000-0x00000000379fdfff]
[ 0.000000] HighMem [mem 0x00000000379fe000-0x000000007ff9ffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009afff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x000000007ff9ffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000007ff9ffff]
[ 0.000000] On node 0 totalpages: 524090
[ 0.000000] free_area_init_node: node 0, pgdat cf829780, node_mem_map f3fa9028
[ 0.000000] DMA zone: 40 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3994 pages, LIFO batch:0
[ 0.000000] Normal zone: 2185 pages used for memmap
[ 0.000000] Normal zone: 223742 pages, LIFO batch:31
[ 0.000000] HighMem zone: 296354 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000
[ 0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009b000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000e3fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e4000-0x000fffff]
[ 0.000000] e820: [mem 0x80000000-0xfedfffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] percpu: Embedded 101 pages/cpu @f7867000 s381472 r0 d32224 u413696
[ 0.000000] pcpu-alloc: s381472 r0 d32224 u413696 alloc=101*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 521865
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-686-pae root=/dev/sda1 ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000379fe:0007ffa0)
[ 0.000000] Initializing Movable for node 0 (00000000:00000000)
[ 0.000000] Memory: 2039564K/2096360K available (6035K kernel code, 628K rwdata, 1756K rodata, 1060K init, 592K bss, 56796K reserved, 0K cma-reserved, 1185416K highmem)
[ 0.000000] virtual kernel memory layout:
fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
pkmap : 0xffa00000 - 0xffc00000 (2048 kB)
vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB)
lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB)
.init : 0xcf83d000 - 0xcf946000 (1060 kB)
.data : 0xcf5e51f4 - 0xcf83b280 (2392 kB)
.text : 0xcf000000 - 0xcf5e51f4 (6036 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=4.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS:2304 nr_irqs:456 16
[ 0.000000] CPU 0 irqstacks, hard=f703e000 soft=f7080000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2400.010 MHz processor
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.02 BogoMIPS (lpj=9600040)
[ 0.004005] pid_max: default: 32768 minimum: 301
[ 0.004021] ACPI: Core revision 20160831
[ 0.009993] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.010020] Security Framework initialized
[ 0.010021] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.010028] AppArmor: AppArmor disabled by boot time parameter
[ 0.010040] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.010042] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.010347] mce: CPU supports 6 MCE banks
[ 0.010353] CPU0: Thermal monitoring enabled (TM2)
[ 0.010357] process: using mwait in idle threads
[ 0.010363] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[ 0.010364] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[ 0.010366] Spectre V2 : Mitigation: Full generic retpoline
[ 0.010367] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.010367] Speculative Store Bypass: Vulnerable
[ 0.010609] Freeing SMP alternatives memory: 24K
[ 0.012006] ftrace: allocating 24078 entries in 48 pages
[ 0.036010] smpboot: Max logical packages: 1
[ 0.036017] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.036452] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.080000] smpboot: CPU0: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (family: 0x6, model: 0xf, stepping: 0xb)
[ 0.080000] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver.
[ 0.080000] core: PEBS disabled due to CPU errata
[ 0.080000] ... version: 2
[ 0.080000] ... bit width: 40
[ 0.080000] ... generic registers: 2
[ 0.080000] ... value mask: 000000ffffffffff
[ 0.080000] ... max period: 000000007fffffff
[ 0.080000] ... fixed-purpose events: 3
[ 0.080000] ... event mask: 0000000700000003
[ 0.132167] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.184033] CPU 1 irqstacks, hard=f71c6000 soft=f71c8000
[ 0.184035] x86: Booting SMP configuration:
[ 0.184038] .... node #0, CPUs: #1
[ 0.008000] Initializing CPU#1
[ 0.236033] CPU 2 irqstacks, hard=f71f0000 soft=f71f2000
[ 0.236036] #2
[ 0.008000] Initializing CPU#2
[ 0.288026] CPU 3 irqstacks, hard=f7222000 soft=f7224000
[ 0.288029] #3
[ 0.008000] Initializing CPU#3
[ 0.296115] x86: Booted up 1 node, 4 CPUs
[ 0.296115] smpboot: Total of 4 processors activated (19200.08 BogoMIPS)
[ 0.300222] devtmpfs: initialized
[ 0.300279] PM: Registering ACPI NVS region [mem 0x7ffae000-0x7ffdffff] (204800 bytes)
[ 0.300279] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.300279] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.300279] pinctrl core: initialized pinctrl subsystem
[ 0.300447] NET: Registered protocol family 16
[ 0.300749] cpuidle: using governor ladder
[ 0.300749] cpuidle: using governor menu
[ 0.300749] ACPI: bus type PCI registered
[ 0.300749] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.300749] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.300749] PCI: not using MMCONFIG
[ 0.300749] PCI: Using configuration type 1 for base access
[ 0.300749] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.300749] mtrr: probably your BIOS does not setup all CPUs.
[ 0.300749] mtrr: corrected configuration.
[ 0.301366] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.301366] ACPI: Added _OSI(Module Device)
[ 0.301366] ACPI: Added _OSI(Processor Device)
[ 0.301366] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.301366] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.301366] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.307020] ACPI: Dynamic OEM Table Load:
[ 0.307027] ACPI: SSDT 0x00000000F71CF800 000277 (v01 HPQOEM SLIC-CPC 00000011 INTL 20051117)
[ 0.307377] ACPI: Dynamic OEM Table Load:
[ 0.307383] ACPI: SSDT 0x00000000F71CD400 000277 (v01 HPQOEM SLIC-CPC 00000012 INTL 20051117)
[ 0.307734] ACPI: Dynamic OEM Table Load:
[ 0.307740] ACPI: SSDT 0x00000000F71CE000 000277 (v01 HPQOEM SLIC-CPC 00000012 INTL 20051117)
[ 0.308097] ACPI: Dynamic OEM Table Load:
[ 0.308105] ACPI: SSDT 0x00000000F71CC800 000277 (v01 HPQOEM SLIC-CPC 00000012 INTL 20051117)
[ 0.308546] ACPI: Interpreter enabled
[ 0.308578] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.308579] ACPI: Using IOAPIC for interrupt routing
[ 0.308615] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.309736] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.309738] PCI: Using MMCONFIG for extended config space
[ 0.309745] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.317008] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.317014] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.317019] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.317109] acpi PNP0A08:00: ignoring host bridge window [mem 0x000d0000-0x000dffff window] (conflicts with Adapter ROM [mem 0x000ce800-0x000d2dff])
[ 0.317353] PCI host bridge to bus 0000:00
[ 0.317356] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.317358] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.317360] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.317362] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.317364] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xffffffff window]
[ 0.317367] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.317377] pci 0000:00:00.0: [8086:29c0] type 00 class 0x060000
[ 0.317518] pci 0000:00:01.0: [8086:29c1] type 01 class 0x060400
[ 0.317566] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.317630] pci 0000:00:01.0: System wakeup disabled by ACPI
[ 0.317725] pci 0000:00:1a.0: [8086:2937] type 00 class 0x0c0300
[ 0.317776] pci 0000:00:1a.0: reg 0x20: [io 0xb400-0xb41f]
[ 0.317900] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.317965] pci 0000:00:1a.1: [8086:2938] type 00 class 0x0c0300
[ 0.318016] pci 0000:00:1a.1: reg 0x20: [io 0xb480-0xb49f]
[ 0.318141] pci 0000:00:1a.1: System wakeup disabled by ACPI
[ 0.318211] pci 0000:00:1a.7: [8086:293c] type 00 class 0x0c0320
[ 0.318231] pci 0000:00:1a.7: reg 0x10: [mem 0xf9efec00-0xf9efefff]
[ 0.318327] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.318393] pci 0000:00:1a.7: System wakeup disabled by ACPI
[ 0.318461] pci 0000:00:1b.0: [8086:293e] type 00 class 0x040300
[ 0.318483] pci 0000:00:1b.0: reg 0x10: [mem 0xf9ef4000-0xf9ef7fff 64bit]
[ 0.318579] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.318707] pci 0000:00:1c.0: [8086:2940] type 01 class 0x060400
[ 0.318796] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.318870] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.318938] pci 0000:00:1c.2: [8086:2944] type 01 class 0x060400
[ 0.319035] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.319109] pci 0000:00:1c.2: System wakeup disabled by ACPI
[ 0.319175] pci 0000:00:1d.0: [8086:2934] type 00 class 0x0c0300
[ 0.319228] pci 0000:00:1d.0: reg 0x20: [io 0xb800-0xb81f]
[ 0.319353] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.319417] pci 0000:00:1d.1: [8086:2935] type 00 class 0x0c0300
[ 0.319468] pci 0000:00:1d.1: reg 0x20: [io 0xb880-0xb89f]
[ 0.319594] pci 0000:00:1d.1: System wakeup disabled by ACPI
[ 0.319658] pci 0000:00:1d.2: [8086:2936] type 00 class 0x0c0300
[ 0.319710] pci 0000:00:1d.2: reg 0x20: [io 0xbc00-0xbc1f]
[ 0.319834] pci 0000:00:1d.2: System wakeup disabled by ACPI
[ 0.319900] pci 0000:00:1d.3: [8086:2939] type 00 class 0x0c0300
[ 0.319951] pci 0000:00:1d.3: reg 0x20: [io 0xc000-0xc01f]
[ 0.320089] pci 0000:00:1d.3: System wakeup disabled by ACPI
[ 0.320171] pci 0000:00:1d.7: [8086:293a] type 00 class 0x0c0320
[ 0.320191] pci 0000:00:1d.7: reg 0x10: [mem 0xf9eff800-0xf9effbff]
[ 0.320289] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.320354] pci 0000:00:1d.7: System wakeup disabled by ACPI
[ 0.320415] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.320538] pci 0000:00:1e.0: System wakeup disabled by ACPI
[ 0.320602] pci 0000:00:1f.0: [8086:2916] type 00 class 0x060100
[ 0.320683] pci 0000:00:1f.0: quirk: [io 0x0800-0x087f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.320689] pci 0000:00:1f.0: quirk: [io 0x0480-0x04bf] claimed by ICH6 GPIO
[ 0.320693] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0a00 (mask 00ff)
[ 0.320840] pci 0000:00:1f.2: [8086:2822] type 00 class 0x010400
[ 0.320861] pci 0000:00:1f.2: reg 0x10: [io 0xc880-0xc887]
[ 0.320871] pci 0000:00:1f.2: reg 0x14: [io 0xc800-0xc803]
[ 0.320881] pci 0000:00:1f.2: reg 0x18: [io 0xc480-0xc487]
[ 0.320891] pci 0000:00:1f.2: reg 0x1c: [io 0xc400-0xc403]
[ 0.320901] pci 0000:00:1f.2: reg 0x20: [io 0xc080-0xc09f]
[ 0.320912] pci 0000:00:1f.2: reg 0x24: [mem 0xf9eff000-0xf9eff7ff]
[ 0.320970] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.321094] pci 0000:00:1f.3: [8086:2930] type 00 class 0x0c0500
[ 0.321113] pci 0000:00:1f.3: reg 0x10: [mem 0xf9effc00-0xf9effcff 64bit]
[ 0.321141] pci 0000:00:1f.3: reg 0x20: [io 0x0400-0x041f]
[ 0.322005] pci 0000:04:00.0: [10de:06e0] type 00 class 0x030000
[ 0.322018] pci 0000:04:00.0: reg 0x10: [mem 0xfd000000-0xfdffffff]
[ 0.322029] pci 0000:04:00.0: reg 0x14: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.322040] pci 0000:04:00.0: reg 0x1c: [mem 0xfa000000-0xfbffffff 64bit]
[ 0.322048] pci 0000:04:00.0: reg 0x24: [io 0xdc00-0xdc7f]
[ 0.322055] pci 0000:04:00.0: reg 0x30: [mem 0xfeae0000-0xfeafffff pref]
[ 0.322168] pci 0000:00:01.0: PCI bridge to [bus 04]
[ 0.322171] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.322174] pci 0000:00:01.0: bridge window [mem 0xfa000000-0xfeafffff]
[ 0.322178] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.322241] pci 0000:00:1c.0: PCI bridge to [bus 03]
[ 0.322378] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.322454] pci 0000:02:00.0: reg 0x10: [io 0xe800-0xe8ff]
[ 0.322560] pci 0000:02:00.0: reg 0x18: [mem 0xfebff000-0xfebfffff 64bit]
[ 0.322628] pci 0000:02:00.0: reg 0x20: [mem 0xf8ff0000-0xf8ffffff 64bit pref]
[ 0.322672] pci 0000:02:00.0: reg 0x30: [mem 0xfebc0000-0xfebdffff pref]
[ 0.322949] pci 0000:02:00.0: supports D1 D2
[ 0.322951] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.323161] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.323165] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.323170] pci 0000:00:1c.2: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.323176] pci 0000:00:1c.2: bridge window [mem 0xf8f00000-0xf8ffffff 64bit pref]
[ 0.323245] pci 0000:01:05.0: [11c1:5811] type 00 class 0x0c0010
[ 0.323262] pci 0000:01:05.0: reg 0x10: [mem 0xf9fff000-0xf9ffffff]
[ 0.323345] pci 0000:01:05.0: supports D1 D2
[ 0.323347] pci 0000:01:05.0: PME# supported from D0 D1 D2 D3hot
[ 0.323444] pci 0000:00:1e.0: PCI bridge to [bus 01] (subtractive decode)
[ 0.323451] pci 0000:00:1e.0: bridge window [mem 0xf9f00000-0xf9ffffff]
[ 0.323458] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.323460] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.323462] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.323464] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xdfffffff window] (subtractive decode)
[ 0.323465] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xffffffff window] (subtractive decode)
[ 0.323490] pci_bus 0000:00: on NUMA node 0
[ 0.324265] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.324337] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.324407] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.324477] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[ 0.324547] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 *4 5 6 7 10 11 12 14 15)
[ 0.324617] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 0.324686] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.324756] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 *14 15)
[ 0.324833] ACPI: Enabled 2 GPEs in block 00 to 3F
[ 0.324968] vgaarb: setting as boot device: PCI:0000:04:00.0
[ 0.324968] vgaarb: device added: PCI:0000:04:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.324968] vgaarb: loaded
[ 0.324968] vgaarb: bridge control possible 0000:04:00.0
[ 0.324968] PCI: Using ACPI for IRQ routing
[ 0.333910] PCI: pci_cache_line_size set to 64 bytes
[ 0.333980] e820: reserve RAM buffer [mem 0x0009b000-0x0009ffff]
[ 0.333982] e820: reserve RAM buffer [mem 0x7ffa0000-0x7fffffff]
[ 0.334151] HPET: 4 timers in total, 0 timers will be used for per-cpu timer
[ 0.334151] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.334151] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[ 0.336035] clocksource: Switched to clocksource hpet
[ 0.351068] VFS: Disk quotas dquot_6.6.0
[ 0.351094] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.351213] pnp: PnP ACPI init
[ 0.351329] system 00:00: [mem 0xfed14000-0xfed19fff] has been reserved
[ 0.351334] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.351420] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.351717] system 00:02: [io 0x04d0-0x04d1] has been reserved
[ 0.351720] system 00:02: [io 0x0800-0x087f] has been reserved
[ 0.351723] system 00:02: [io 0x0480-0x04bf] has been reserved
[ 0.351725] system 00:02: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.351728] system 00:02: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.351732] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.351873] system 00:03: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.351876] system 00:03: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.351880] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.351960] pnp 00:04: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.352126] system 00:05: [io 0x0a00-0x0adf] has been reserved
[ 0.352130] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.352236] system 00:06: [mem 0xffc00000-0xffefffff] has been reserved
[ 0.352240] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.352336] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.352340] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.352564] system 00:08: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.352566] system 00:08: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.352569] system 00:08: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.352571] system 00:08: [mem 0x00100000-0x7fffffff] could not be reserved
[ 0.352575] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.352729] pnp: PnP ACPI: found 9 devices
[ 0.352732] PnPBIOS: Disabled
[ 0.392196] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.392218] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 03] add_size 1000
[ 0.392222] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[ 0.392225] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 03] add_size 200000 add_align 100000
[ 0.392246] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.392249] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.392251] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.392253] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.392256] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.392258] pci 0000:00:1c.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.392264] pci 0000:00:1c.0: BAR 14: assigned [mem 0x80000000-0x801fffff]
[ 0.392271] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref]
[ 0.392274] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.392277] pci 0000:00:01.0: PCI bridge to [bus 04]
[ 0.392280] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.392284] pci 0000:00:01.0: bridge window [mem 0xfa000000-0xfeafffff]
[ 0.392287] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.392291] pci 0000:00:1c.0: PCI bridge to [bus 03]
[ 0.392294] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.392300] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff]
[ 0.392304] pci 0000:00:1c.0: bridge window [mem 0x80200000-0x803fffff 64bit pref]
[ 0.392311] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.392314] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.392320] pci 0000:00:1c.2: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.392324] pci 0000:00:1c.2: bridge window [mem 0xf8f00000-0xf8ffffff 64bit pref]
[ 0.392331] pci 0000:00:1e.0: PCI bridge to [bus 01]
[ 0.392337] pci 0000:00:1e.0: bridge window [mem 0xf9f00000-0xf9ffffff]
[ 0.392347] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.392349] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.392351] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.392353] pci_bus 0000:00: resource 7 [mem 0x80000000-0xdfffffff window]
[ 0.392355] pci_bus 0000:00: resource 8 [mem 0xf0000000-0xffffffff window]
[ 0.392357] pci_bus 0000:04: resource 0 [io 0xd000-0xdfff]
[ 0.392359] pci_bus 0000:04: resource 1 [mem 0xfa000000-0xfeafffff]
[ 0.392361] pci_bus 0000:04: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.392363] pci_bus 0000:03: resource 0 [io 0x1000-0x1fff]
[ 0.392365] pci_bus 0000:03: resource 1 [mem 0x80000000-0x801fffff]
[ 0.392367] pci_bus 0000:03: resource 2 [mem 0x80200000-0x803fffff 64bit pref]
[ 0.392369] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.392371] pci_bus 0000:02: resource 1 [mem 0xfeb00000-0xfebfffff]
[ 0.392373] pci_bus 0000:02: resource 2 [mem 0xf8f00000-0xf8ffffff 64bit pref]
[ 0.392375] pci_bus 0000:01: resource 1 [mem 0xf9f00000-0xf9ffffff]
[ 0.392377] pci_bus 0000:01: resource 4 [io 0x0000-0x0cf7 window]
[ 0.392379] pci_bus 0000:01: resource 5 [io 0x0d00-0xffff window]
[ 0.392381] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.392383] pci_bus 0000:01: resource 7 [mem 0x80000000-0xdfffffff window]
[ 0.392385] pci_bus 0000:01: resource 8 [mem 0xf0000000-0xffffffff window]
[ 0.392465] NET: Registered protocol family 2
[ 0.392667] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.392687] TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
[ 0.392777] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.392808] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.392824] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.392898] NET: Registered protocol family 1
[ 0.394451] pci 0000:04:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.394464] PCI: CLS 32 bytes, default 64
[ 0.394533] Unpacking initramfs...
[ 0.839825] Freeing initrd memory: 22668K
[ 0.840570] audit: initializing netlink subsys (disabled)
[ 0.840603] audit: type=2000 audit(1560711113.840:1): initialized
[ 0.841215] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.844144] zbud: loaded
[ 0.845443] bounce: pool size: 64 pages
[ 0.845515] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.845584] io scheduler noop registered
[ 0.845586] io scheduler deadline registered
[ 0.845666] io scheduler cfq registered (default)
[ 0.846081] pcieport 0000:00:1c.0: enabling device (0104 -> 0107)
[ 0.846526] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.846534] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.846555] intel_idle: does not run on family 6 model 15
[ 0.846775] GHES: HEST is not enabled!
[ 0.846844] isapnp: Scanning for PnP cards...
[ 1.200012] isapnp: No Plug & Play device found
[ 1.200101] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.200753] Linux agpgart interface v0.103
[ 1.201575] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.201576] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.202353] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.202565] mousedev: PS/2 mouse device common for all mice
[ 1.202624] rtc_cmos 00:01: RTC can wake from S4
[ 1.202772] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.202862] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.203751] NET: Registered protocol family 10
[ 1.204202] mip6: Mobile IPv6
[ 1.204206] NET: Registered protocol family 17
[ 1.204210] mpls_gso: MPLS GSO support
[ 1.204524] microcode: sig=0x6fb, pf=0x10, revision=0xba
[ 1.204596] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.204600] Using IPI No-Shortcut mode
[ 1.204809] registered taskstats version 1
[ 1.204836] zswap: loaded using pool lzo/zbud
[ 1.204879] ima: No TPM chip found, activating TPM-bypass!
[ 1.204882] ima: Allocated hash algorithm: sha256
[ 1.205308] rtc_cmos 00:01: setting system clock to 2019-06-16 18:51:54 UTC (1560711114)
[ 1.205370] PM: Hibernation image not present or could not be loaded.
[ 1.205795] Freeing unused kernel memory: 1060K
[ 1.205921] Write protecting the kernel text: 6040k
[ 1.206031] Write protecting the kernel read-only data: 1760k
[ 1.206032] NX-protecting the kernel data: 4200k
[ 1.206290] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.222079] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.225722] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.225820] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.226990] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.290990] SCSI subsystem initialized
[ 1.291448] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 1.301701] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.301711] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 1.303126] ACPI: bus type USB registered
[ 1.303447] usbcore: registered new interface driver usbfs
[ 1.303637] usbcore: registered new interface driver hub
[ 1.304171] usbcore: registered new device driver usb
[ 1.313490] r8169 0000:02:00.0 eth0: RTL8168c/8111c at 0xf821a000, 00:23:54:49:59:7d, XID 1c4000c0 IRQ 27
[ 1.313493] r8169 0000:02:00.0 eth0: jumbo features [frames: 6128 bytes, tx checksumming: ko]
[ 1.314959] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.319994] libata version 3.00 loaded.
[ 1.322244] ehci-pci: EHCI PCI platform driver
[ 1.323006] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 1.323237] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 1.323251] ehci-pci 0000:00:1a.7: debug port 1
[ 1.324712] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.327168] ehci-pci 0000:00:1a.7: cache line size of 32 is not supported
[ 1.327211] ehci-pci 0000:00:1a.7: irq 18, io mem 0xf9efec00
[ 1.340084] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.340234] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.340236] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.340238] usb usb1: Product: EHCI Host Controller
[ 1.340240] usb usb1: Manufacturer: Linux 4.9.0-8-rt-686-pae ehci_hcd
[ 1.340242] usb usb1: SerialNumber: 0000:00:1a.7
[ 1.340440] hub 1-0:1.0: USB hub found
[ 1.340452] hub 1-0:1.0: 4 ports detected
[ 1.340808] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.340816] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 2
[ 1.340823] uhci_hcd 0000:00:1a.0: detected 2 ports
[ 1.340917] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000b400
[ 1.340994] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.340997] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.340999] usb usb2: Product: UHCI Host Controller
[ 1.341000] usb usb2: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.341002] usb usb2: SerialNumber: 0000:00:1a.0
[ 1.341221] hub 2-0:1.0: USB hub found
[ 1.341231] hub 2-0:1.0: 2 ports detected
[ 1.341427] ahci 0000:00:1f.2: version 3.0
[ 1.341586] ahci 0000:00:1f.2: controller can't do SNTF, turning off CAP_SNTF
[ 1.341671] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[ 1.341720] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl RAID mode
[ 1.341724] ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part ccc ems sxs
[ 1.376127] firewire_ohci 0000:01:05.0: added OHCI v1.0 device as card 0, 8 IR + 8 IT contexts, quirks 0x0
[ 1.401200] scsi host0: ahci
[ 1.401397] scsi host1: ahci
[ 1.401572] scsi host2: ahci
[ 1.401751] scsi host3: ahci
[ 1.401923] scsi host4: ahci
[ 1.402099] scsi host5: ahci
[ 1.402185] ata1: SATA max UDMA/133 abar m2048@0xf9eff000 port 0xf9eff100 irq 28
[ 1.402188] ata2: SATA max UDMA/133 abar m2048@0xf9eff000 port 0xf9eff180 irq 28
[ 1.402190] ata3: SATA max UDMA/133 abar m2048@0xf9eff000 port 0xf9eff200 irq 28
[ 1.402193] ata4: SATA max UDMA/133 abar m2048@0xf9eff000 port 0xf9eff280 irq 28
[ 1.402195] ata5: SATA max UDMA/133 abar m2048@0xf9eff000 port 0xf9eff300 irq 28
[ 1.402197] ata6: SATA max UDMA/133 abar m2048@0xf9eff000 port 0xf9eff380 irq 28
[ 1.402543] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.402552] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 3
[ 1.402569] ehci-pci 0000:00:1d.7: debug port 1
[ 1.406483] ehci-pci 0000:00:1d.7: cache line size of 32 is not supported
[ 1.406561] ehci-pci 0000:00:1d.7: irq 23, io mem 0xf9eff800
[ 1.420056] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.420179] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.420181] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.420183] usb usb3: Product: EHCI Host Controller
[ 1.420185] usb usb3: Manufacturer: Linux 4.9.0-8-rt-686-pae ehci_hcd
[ 1.420187] usb usb3: SerialNumber: 0000:00:1d.7
[ 1.420375] hub 3-0:1.0: USB hub found
[ 1.420384] hub 3-0:1.0: 8 ports detected
[ 1.420837] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.420846] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 1.420853] uhci_hcd 0000:00:1a.1: detected 2 ports
[ 1.420917] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000b480
[ 1.420987] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.420989] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.420991] usb usb4: Product: UHCI Host Controller
[ 1.420993] usb usb4: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.420995] usb usb4: SerialNumber: 0000:00:1a.1
[ 1.422595] hub 4-0:1.0: USB hub found
[ 1.422605] hub 4-0:1.0: 2 ports detected
[ 1.426064] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.426071] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[ 1.426078] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 1.426359] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000b800
[ 1.426433] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.426436] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.426438] usb usb5: Product: UHCI Host Controller
[ 1.426440] usb usb5: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.426446] usb usb5: SerialNumber: 0000:00:1d.0
[ 1.427253] hub 5-0:1.0: USB hub found
[ 1.427264] hub 5-0:1.0: 2 ports detected
[ 1.427523] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.427533] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 1.427539] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 1.427624] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000b880
[ 1.427694] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.427696] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.427698] usb usb6: Product: UHCI Host Controller
[ 1.427700] usb usb6: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.427702] usb usb6: SerialNumber: 0000:00:1d.1
[ 1.427896] hub 6-0:1.0: USB hub found
[ 1.427905] hub 6-0:1.0: 2 ports detected
[ 1.428151] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.428157] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 1.428163] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 1.428260] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000bc00
[ 1.428329] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.428332] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.428333] usb usb7: Product: UHCI Host Controller
[ 1.428335] usb usb7: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.428337] usb usb7: SerialNumber: 0000:00:1d.2
[ 1.428557] hub 7-0:1.0: USB hub found
[ 1.428566] hub 7-0:1.0: 2 ports detected
[ 1.428815] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.428821] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 8
[ 1.428827] uhci_hcd 0000:00:1d.3: detected 2 ports
[ 1.428897] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000c000
[ 1.428973] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.428975] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.428977] usb usb8: Product: UHCI Host Controller
[ 1.428979] usb usb8: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.428980] usb usb8: SerialNumber: 0000:00:1d.3
[ 1.429188] hub 8-0:1.0: USB hub found
[ 1.429197] hub 8-0:1.0: 2 ports detected
[ 1.714650] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.715443] ata1.00: ATA-8: ST3320813AS, HP21, max UDMA/100
[ 1.715447] ata1.00: 625142448 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 1.729381] ata1.00: configured for UDMA/100
[ 1.729646] scsi 0:0:0:0: Direct-Access ATA ST3320813AS HP21 PQ: 0 ANSI: 5
[ 1.748051] usb 3-5: new high-speed USB device number 2 using ehci-pci
[ 1.856039] tsc: Refined TSC clocksource calibration: 2399.950 MHz
[ 1.856048] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2298086d749, max_idle_ns: 440795294037 ns
[ 1.888201] firewire_core 0000:01:05.0: created device fw0: GUID 001e8c00019480b3, S400
[ 1.971624] usb 3-5: New USB device found, idVendor=0bda, idProduct=0152
[ 1.971628] usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.971630] usb 3-5: Product: USB2.0-CRW
[ 1.971633] usb 3-5: Manufacturer: Generic
[ 1.971636] usb 3-5: SerialNumber: 20060413092100000
[ 1.975195] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.981467] usbcore: registered new interface driver usbhid
[ 1.981469] usb-storage 3-5:1.0: USB Mass Storage device detected
[ 1.981472] usbhid: USB HID core driver
[ 1.981573] scsi host6: usb-storage 3-5:1.0
[ 1.982061] usbcore: registered new interface driver usb-storage
[ 1.982770] usbcore: registered new interface driver uas
[ 1.983684] hid-generic 0003:0BDA:0152.0001: hiddev0,hidraw0: USB HID v1.11 Device [Generic USB2.0-CRW] on usb-0000:00:1d.7-5/input1
[ 2.094618] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.094842] ata2.00: ATAPI: ATAPI DVD A DH16A6L-C, ZHCD, max UDMA/100
[ 2.095540] ata2.00: configured for UDMA/100
[ 2.097476] scsi 1:0:0:0: CD-ROM ATAPI DVD A DH16A6L-C ZHCD PQ: 0 ANSI: 5
[ 2.422693] ata3: SATA link down (SStatus 0 SControl 300)
[ 2.440044] usb 8-2: new low-speed USB device number 2 using uhci_hcd
[ 2.630080] usb 8-2: New USB device found, idVendor=045e, idProduct=076c
[ 2.630084] usb 8-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.630087] usb 8-2: Product: Microsoft® Comfort Mouse 4500
[ 2.630090] usb 8-2: Manufacturer: Microsoft
[ 2.698509] input: Microsoft Microsoft® Comfort Mouse 4500 as /devices/pci0000:00/0000:00:1d.3/usb8/8-2/8-2:1.0/0003:045E:076C.0002/input/input1
[ 2.734713] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.756229] microsoft 0003:045E:076C.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® Comfort Mouse 4500] on usb-0000:00:1d.3-2/input0
[ 2.880154] clocksource: Switched to clocksource tsc
[ 3.013270] scsi 6:0:0:0: Direct-Access Generic- Compact Flash 1.00 PQ: 0 ANSI: 0 CCS
[ 3.018255] scsi 6:0:0:1: Direct-Access Generic- SM/xD-Picture 1.00 PQ: 0 ANSI: 0 CCS
[ 3.023265] scsi 6:0:0:2: Direct-Access Generic- SD/MMC 1.00 PQ: 0 ANSI: 0 CCS
[ 3.028264] scsi 6:0:0:3: Direct-Access Generic- MS/MS-Pro 1.00 PQ: 0 ANSI: 0 CCS
[ 3.046708] ata5: SATA link down (SStatus 0 SControl 300)
[ 3.048395] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 3.048469] sd 0:0:0:0: [sda] Write Protect is off
[ 3.048472] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.048506] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.053756] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 3.056383] sd 6:0:0:3: [sde] Attached SCSI removable disk
[ 3.057248] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[ 3.061733] random: fast init done
[ 3.071270] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[ 3.075646] sda: sda1 sda2 < sda5 >
[ 3.076261] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.358491] ata6: SATA link down (SStatus 0 SControl 300)
[ 3.382633] sr 1:0:0:0: [sr0] scsi3-mmc drive: 40x/12x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.382634] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.382912] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 3.788725] PM: Starting manual resume from disk
[ 3.788730] PM: Hibernation image partition 8:5 present
[ 3.788731] PM: Looking for hibernation image.
[ 3.789000] PM: Image not found (code -22)
[ 3.789002] PM: Hibernation image not present or could not be loaded.
[ 4.149139] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.371254] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.568691] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 5.568892] systemd[1]: Detected architecture x86.
[ 5.587252] systemd[1]: Set hostname to <precix510>.
[ 6.403119] random: crng init done
[ 6.403123] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.591063] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[ 6.591098] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[ 6.591843] systemd[1]: Listening on udev Control Socket.
[ 6.591912] systemd[1]: Reached target Remote File Systems.
[ 6.592165] systemd[1]: Created slice System Slice.
[ 6.592341] systemd[1]: Created slice system-getty.slice.
[ 6.592383] systemd[1]: Listening on udev Kernel Socket.
[ 7.085465] lp: driver loaded but no devices found
[ 7.142659] ppdev: user-space parallel port driver
[ 7.379530] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 7.603011] systemd-journald[246]: Received request to flush runtime journal from PID 1
[ 8.440820] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 8.514903] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 8.514909] ACPI: Power Button [PWRB]
[ 8.519204] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 8.519211] ACPI: Power Button [PWRF]
[ 8.720932] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000800-0x000000000000084F (\PMRG) (20160831/utaddress-247)
[ 8.720942] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 8.720986] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 8.760864] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 8.793707] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 8.793760] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 8.793809] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 8.793857] sd 6:0:0:1: Attached scsi generic sg3 type 0
[ 8.793911] sd 6:0:0:2: Attached scsi generic sg4 type 0
[ 8.793959] sd 6:0:0:3: Attached scsi generic sg5 type 0
[ 8.878707] [drm] Initialized
[ 8.993326] iTCO_vendor_support: vendor-support=0
[ 9.061028] kvm: disabled by bios
[ 9.068907] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 9.068951] iTCO_wdt: Found a ICH9R TCO device (Version=2, TCOBASE=0x0860)
[ 9.069189] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 9.101177] wmi: Mapper loaded
[ 9.101763] coretemp coretemp.0: Using relative temperature scale!
[ 9.101778] coretemp coretemp.0: Using relative temperature scale!
[ 9.101806] coretemp coretemp.0: Using relative temperature scale!
[ 9.101841] coretemp coretemp.0: Using relative temperature scale!
[ 9.183564] intel_powerclamp: No package C-state available
[ 9.301053] snd_hda_codec_realtek hdaudioC0D0: ALC1200: SKU not ready 0x411111f0
[ 9.301878] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC1200: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[ 9.301880] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 9.301883] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 9.301885] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 9.301886] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x1e
[ 9.301888] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 9.301891] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 9.301893] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 9.301895] snd_hda_codec_realtek hdaudioC0D0: Line=0x1c
[ 9.301896] snd_hda_codec_realtek hdaudioC0D0: dig-in=0x1f
[ 9.322734] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 9.323920] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 9.324063] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 9.324164] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 9.324267] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 9.324366] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 9.324474] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 9.324576] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 9.324676] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 9.834750] nouveau 0000:04:00.0: NVIDIA G98 (298000a2)
[ 9.947589] nouveau 0000:04:00.0: bios: version 62.98.29.00.13
[ 9.968410] nouveau 0000:04:00.0: bios: M0203T not found
[ 9.968413] nouveau 0000:04:00.0: bios: M0203E not matched!
[ 9.968416] nouveau 0000:04:00.0: fb: 256 MiB DDR2
[ 10.025334] Adding 2095100k swap on /dev/sda5. Priority:-1 extents:1 across:2095100k FS
[ 11.268142] [TTM] Zone kernel: Available graphics memory: 438950 kiB
[ 11.268144] [TTM] Zone highmem: Available graphics memory: 1031658 kiB
[ 11.268145] [TTM] Initializing pool allocator
[ 11.268153] [TTM] Initializing DMA pool allocator
[ 11.268176] nouveau 0000:04:00.0: DRM: VRAM: 256 MiB
[ 11.268178] nouveau 0000:04:00.0: DRM: GART: 1048576 MiB
[ 11.268183] nouveau 0000:04:00.0: DRM: TMDS table version 2.0
[ 11.268185] nouveau 0000:04:00.0: DRM: DCB version 4.0
[ 11.268188] nouveau 0000:04:00.0: DRM: DCB outp 00: 02000300 00000028
[ 11.268191] nouveau 0000:04:00.0: DRM: DCB outp 01: 01000302 00020030
[ 11.268193] nouveau 0000:04:00.0: DRM: DCB outp 02: 02011312 00020010
[ 11.268195] nouveau 0000:04:00.0: DRM: DCB conn 00: 00002030
[ 11.268197] nouveau 0000:04:00.0: DRM: DCB conn 01: 00001161
[ 11.268199] nouveau 0000:04:00.0: DRM: DCB conn 02: 00000362
[ 11.300711] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 11.300713] [drm] Driver supports precise vblank timestamp query.
[ 11.351716] nouveau 0000:04:00.0: DRM: MM: using M2MF for buffer copies
[ 11.403901] nouveau 0000:04:00.0: DRM: allocated 1360x768 fb: 0x50000, bo f31d9800
[ 11.403998] fbcon: nouveaufb (fb0) is primary device
[ 11.507953] Console: switching to colour frame buffer device 170x48
[ 11.509165] nouveau 0000:04:00.0: fb0: nouveaufb frame buffer device
[ 11.544023] [drm] Initialized nouveau 1.3.1 20120801 for 0000:04:00.0 on minor 0
[ 14.276158] r8169 0000:02:00.0 eth0: link down
[ 14.276239] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[99247.378928] perf: interrupt took too long (2516 > 2500), lowering kernel.perf_event_max_sample_rate to 79250
[145507.023267] perf: interrupt took too long (3155 > 3145), lowering kernel.perf_event_max_sample_rate to 63250
[170411.276035] usb 3-2: new high-speed USB device number 4 using ehci-pci
[170411.425191] usb 3-2: New USB device found, idVendor=0781, idProduct=5583
[170411.425196] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[170411.425199] usb 3-2: Product: Ultra Fit
[170411.425201] usb 3-2: Manufacturer: SanDisk
[170411.425204] usb 3-2: SerialNumber: 4C530001271022122030
[170411.425640] usb-storage 3-2:1.0: USB Mass Storage device detected
[170411.426361] scsi host7: usb-storage 3-2:1.0
[170412.448971] scsi 7:0:0:0: Direct-Access SanDisk Ultra Fit 1.00 PQ: 0 ANSI: 6
[170412.472516] sd 7:0:0:0: Attached scsi generic sg6 type 0
[170412.473337] sd 7:0:0:0: [sdf] 120127488 512-byte logical blocks: (61.5 GB/57.3 GiB)
[170412.474587] sd 7:0:0:0: [sdf] Write Protect is off
[170412.474591] sd 7:0:0:0: [sdf] Mode Sense: 43 00 00 00
[170412.475582] sd 7:0:0:0: [sdf] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[170412.697127] sdf: sdf1
[170412.700836] sd 7:0:0:0: [sdf] Attached SCSI removable disk
- BigJohnT
- Thank you received: 994
20 Jun 2019 00:05 - 20 Jun 2019 00:06 #137317
by BigJohnT
Replied by BigJohnT on topic First Run - Crashing on startup
Looks like an error in your hal file
Can you run a sim?
A 7i92 does not need a parallel port. Have you setup the NIC to talk to the 7i92?
JT
Can you run a sim?
JT
Last edit: 20 Jun 2019 00:06 by BigJohnT.
- randypetersen
20 Jun 2019 00:26 #137319
by randypetersen
Replied by randypetersen on topic First Run - Crashing on startup
Thanks JT, I will make sure it's connecting and try to run a SIM, I thought I did, but that might have been the previous installation.
I tried configuring a few HAL files and used the config, but I must have screwed it up. I will try again, I had the 7i92 pinging, but i will double check it again next time i am there.
Guess I didn't think that linuxCNC would crash because it couldn't communicate. Figured I had something else wrong. Now I know and thanks for the help, I will try it again and reply back.
thanks
thanks
- Thank you received: 5334
20 Jun 2019 01:07 - 20 Jun 2019 01:08 #137327
Replied by PCW on topic First Run - Crashing on startup
It look like you are attempting to run a parallel port configuration.
This fails because there does not seem to be a parallel port on your PC.
( This is not really a crash, its LinuxCNC exiting because it was asked to do something
that was not possible )
How did you create your hal/ini files? If this is for a 7I92/7I77 you will need to use pncconf.
Last edit: 20 Jun 2019 01:08 by PCW.
- pl7i92
- Thank you received: 358
20 Jun 2019 07:10 #137349
by pl7i92
Replied by pl7i92 on topic First Run - Crashing on startup
hi
please post your config and ini to get behind your error
while
please check if you can ping your 7i92
in terminal
ping 192.168.1.121
CHECK jumpers
ip a will give you your eth config
make shure you are in the same namespace
192.168.1.4 woudt be a good pc number
sudo gedit /etc/network/interfaces
check the installed firmware
mesaflash --device 7i92 --addr 192.168.1.121 --readhmid
if it is there
show your pins are ok
cd linuxcnc
halrun
halcmd: show pin > mypins.txt
exit
look into the folder if the pins are there
YT vido on your issue
while
in terminal
ping 192.168.1.121
CHECK jumpers
#7i92 2019
auto eth0
iface eth0 inet static
address 192.168.1.4
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
gateway 192.168.1.1
dns-nameservers 8.8.8.8 4.4.4.4
hardware-irq-coalesce-rx-usecs 0
if it is there
cd linuxcnc
halrun
exit
- randypetersen
26 Jun 2019 03:30 - 26 Jun 2019 03:38 #137856
by randypetersen
Thanks for all the great input!
Just getting this thing started, so I would like to just hook up one axis motor/encoder to see if I can get it to move and report that movements. Is that a good way to begin to get this machine running?
Or is there an a good implementation procedure on how to hook things up in what order? Sorry for the basic questions, if I should read up on this I will. My experience has been with Mach3, but I wanted to get away from it on this project, hence the LinuxCNC because I think that's the future.
I went through the pnconf but kinda skipped through the details since I kinda wanted to focus on just one thing and edit it from there, maybe that's not the right way to do it, so I can re-run it with whatever you guys suggest. I don't have the motors connected to the pulleys so I know it won't home, nor do I have the home switches connected. Currently I just have the Y axis encoder (ENCODER 1) and Y axis driver (DRV 1) connected.
Here is my current info:
(First it gave me an error on this line so I commented it out)
# setp hm2_7i92.0.stepgen.timer-number 1
Debug:
HAL file:
INI
Thanks for everyone's help!
I am in the process of going through the linuxCNC documentation, sorry if I jumped the gun on posting. Should do some more research.
Debug:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
Machine configuration directory is '/home/user/linuxcnc/configs/precix5x10-20190624'
Machine configuration file is 'precix5x10-20190624.ini'
INIFILE=/home/user/linuxcnc/configs/precix5x10-20190624/precix5x10-20190624.ini
TASK=milltask
HALUI=halui
DISPLAY=axis
Found file(REL): ./precix5x10-20190624.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:13:04:87
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): IOPort
hm2/hm2_7i92.0: IO Pin 001 (P2-14): IOPort
hm2/hm2_7i92.0: IO Pin 002 (P2-02): IOPort
hm2/hm2_7i92.0: IO Pin 003 (P2-15): IOPort
hm2/hm2_7i92.0: IO Pin 004 (P2-03): IOPort
hm2/hm2_7i92.0: IO Pin 005 (P2-16): IOPort
hm2/hm2_7i92.0: IO Pin 006 (P2-04): IOPort
hm2/hm2_7i92.0: IO Pin 007 (P2-17): IOPort
hm2/hm2_7i92.0: IO Pin 008 (P2-05): IOPort
hm2/hm2_7i92.0: IO Pin 009 (P2-06): IOPort
hm2/hm2_7i92.0: IO Pin 010 (P2-07): IOPort
hm2/hm2_7i92.0: IO Pin 011 (P2-08): IOPort
hm2/hm2_7i92.0: IO Pin 012 (P2-09): IOPort
hm2/hm2_7i92.0: IO Pin 013 (P2-10): IOPort
hm2/hm2_7i92.0: IO Pin 014 (P2-11): Encoder #0, pin Index (Input)
hm2/hm2_7i92.0: IO Pin 015 (P2-12): Encoder #0, pin B (Input)
hm2/hm2_7i92.0: IO Pin 016 (P2-13): Encoder #0, pin A (Input)
hm2/hm2_7i92.0: IO Pin 017 (P1-01): IOPort
hm2/hm2_7i92.0: IO Pin 018 (P1-14): IOPort
hm2/hm2_7i92.0: IO Pin 019 (P1-02): IOPort
hm2/hm2_7i92.0: IO Pin 020 (P1-15): IOPort
hm2/hm2_7i92.0: IO Pin 021 (P1-03): IOPort
hm2/hm2_7i92.0: IO Pin 022 (P1-16): IOPort
hm2/hm2_7i92.0: IO Pin 023 (P1-04): IOPort
hm2/hm2_7i92.0: IO Pin 024 (P1-17): IOPort
hm2/hm2_7i92.0: IO Pin 025 (P1-05): IOPort
hm2/hm2_7i92.0: IO Pin 026 (P1-06): IOPort
hm2/hm2_7i92.0: IO Pin 027 (P1-07): IOPort
hm2/hm2_7i92.0: IO Pin 028 (P1-08): IOPort
hm2/hm2_7i92.0: IO Pin 029 (P1-09): IOPort
hm2/hm2_7i92.0: IO Pin 030 (P1-10): IOPort
hm2/hm2_7i92.0: IO Pin 031 (P1-11): IOPort
hm2/hm2_7i92.0: IO Pin 032 (P1-12): IOPort
hm2/hm2_7i92.0: IO Pin 033 (P1-13): IOPort
hm2/hm2_7i92.0: registered
hm2_eth: ERROR: Failed to execute '/sbin/sysctl -q net.ipv6.conf.eth0:avahi.disable_ipv6=1'
Running HAL shutdown script
Killing task linuxcncsvr, PID=16469
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
sysctl: cannot stat /proc/sys/net/ipv6/conf/eth0:avahi/disable_ipv6: No such file or directory
./precix5x10-20190624.hal:53: parameter or pin 'hm2_7i92.0.7i77.0.4.analogout0-scalemax' not found
16469
[ 0.000000] initial memory mapped: [mem 0x00000000-0x0dffffff]
[ 0.000000] BRK [0x0da51000, 0x0da51fff] PGTABLE
[ 0.000000] BRK [0x0da52000, 0x0da53fff] PGTABLE
[ 0.000000] BRK [0x0da54000, 0x0da54fff] PGTABLE
[ 0.000000] BRK [0x0da55000, 0x0da55fff] PGTABLE
[ 0.000000] free_area_init_node: node 0, pgdat cd829780, node_mem_map f3fa9028
[ 0.000000] Memory: 2039628K/2096360K available (6035K kernel code, 628K rwdata, 1756K rodata, 1060K init, 592K bss, 56732K reserved, 0K cma-reserved, 1185416K highmem)
.init : 0xcd83d000 - 0xcd946000 (1060 kB)
.data : 0xcd5e51f4 - 0xcd83b280 (2392 kB)
.text : 0xcd000000 - 0xcd5e51f4 (6036 kB)
[ 0.000000] tsc: Detected 2400.092 MHz processor
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.18 BogoMIPS (lpj=9600368)
[ 0.009990] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.010017] Security Framework initialized
[ 0.010018] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.010026] AppArmor: AppArmor disabled by boot time parameter
[ 0.010037] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.010039] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.010346] mce: CPU supports 6 MCE banks
[ 0.010352] CPU0: Thermal monitoring enabled (TM2)
[ 0.010356] process: using mwait in idle threads
[ 0.010366] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.010610] Freeing SMP alternatives memory: 24K
[ 0.036097] smpboot: Max logical packages: 1
[ 0.036104] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.036539] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.184037] .... node #0, CPUs: #1
[ 0.236034] CPU 2 irqstacks, hard=f71f0000 soft=f71f2000
[ 0.236037] #2
[ 0.288029] #3
[ 0.296116] x86: Booted up 1 node, 4 CPUs
[ 0.296116] smpboot: Total of 4 processors activated (19200.73 BogoMIPS)
[ 0.300228] devtmpfs: initialized
[ 0.300277] PM: Registering ACPI NVS region [mem 0x7ffae000-0x7ffdffff] (204800 bytes)
[ 0.300277] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.300277] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.300277] pinctrl core: initialized pinctrl subsystem
[ 0.300449] NET: Registered protocol family 16
[ 0.300751] cpuidle: using governor ladder
[ 0.300751] cpuidle: using governor menu
[ 0.300751] ACPI: bus type PCI registered
[ 0.300751] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.300751] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.300751] PCI: not using MMCONFIG
[ 0.300751] PCI: Using configuration type 1 for base access
[ 0.300751] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.300751] mtrr: probably your BIOS does not setup all CPUs.
[ 0.300751] mtrr: corrected configuration.
[ 0.301365] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.301365] ACPI: Added _OSI(Module Device)
[ 0.301365] ACPI: Added _OSI(Processor Device)
[ 0.301365] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.301365] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.301365] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.307011] ACPI: Dynamic OEM Table Load:
[ 0.307018] ACPI: SSDT 0x00000000F71CC400 000277 (v01 HPQOEM SLIC-CPC 00000011 INTL 20051117)
[ 0.307369] ACPI: Dynamic OEM Table Load:
[ 0.307375] ACPI: SSDT 0x00000000F71CD000 000277 (v01 HPQOEM SLIC-CPC 00000012 INTL 20051117)
[ 0.307728] ACPI: Dynamic OEM Table Load:
[ 0.307734] ACPI: SSDT 0x00000000F71CFC00 000277 (v01 HPQOEM SLIC-CPC 00000012 INTL 20051117)
[ 0.308095] ACPI: Dynamic OEM Table Load:
[ 0.308102] ACPI: SSDT 0x00000000F71CC000 000277 (v01 HPQOEM SLIC-CPC 00000012 INTL 20051117)
[ 0.308544] ACPI: Interpreter enabled
[ 0.308577] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.308578] ACPI: Using IOAPIC for interrupt routing
[ 0.308614] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.309733] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.309734] PCI: Using MMCONFIG for extended config space
[ 0.309741] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.317020] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.317355] PCI host bridge to bus 0000:00
[ 0.317358] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.317360] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.317362] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.317364] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.317366] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xffffffff window]
[ 0.317369] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.317378] pci 0000:00:00.0: [8086:29c0] type 00 class 0x060000
[ 0.317519] pci 0000:00:01.0: [8086:29c1] type 01 class 0x060400
[ 0.317567] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.317632] pci 0000:00:01.0: System wakeup disabled by ACPI
[ 0.317726] pci 0000:00:1a.0: [8086:2937] type 00 class 0x0c0300
[ 0.317777] pci 0000:00:1a.0: reg 0x20: [io 0xb400-0xb41f]
[ 0.317899] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.318230] pci 0000:00:1a.7: reg 0x10: [mem 0xf9efec00-0xf9efefff]
[ 0.318325] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.318391] pci 0000:00:1a.7: System wakeup disabled by ACPI
[ 0.318460] pci 0000:00:1b.0: [8086:293e] type 00 class 0x040300
[ 0.318482] pci 0000:00:1b.0: reg 0x10: [mem 0xf9ef4000-0xf9ef7fff 64bit]
[ 0.318577] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.318705] pci 0000:00:1c.0: [8086:2940] type 01 class 0x060400
[ 0.318795] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.318868] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.318936] pci 0000:00:1c.2: [8086:2944] type 01 class 0x060400
[ 0.319033] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.319106] pci 0000:00:1c.2: System wakeup disabled by ACPI
[ 0.319172] pci 0000:00:1d.0: [8086:2934] type 00 class 0x0c0300
[ 0.319223] pci 0000:00:1d.0: reg 0x20: [io 0xb800-0xb81f]
[ 0.319346] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.319410] pci 0000:00:1d.1: [8086:2935] type 00 class 0x0c0300
[ 0.319461] pci 0000:00:1d.1: reg 0x20: [io 0xb880-0xb89f]
[ 0.319587] pci 0000:00:1d.1: System wakeup disabled by ACPI
[ 0.319652] pci 0000:00:1d.2: [8086:2936] type 00 class 0x0c0300
[ 0.319702] pci 0000:00:1d.2: reg 0x20: [io 0xbc00-0xbc1f]
[ 0.319828] pci 0000:00:1d.2: System wakeup disabled by ACPI
[ 0.319894] pci 0000:00:1d.3: [8086:2939] type 00 class 0x0c0300
[ 0.319945] pci 0000:00:1d.3: reg 0x20: [io 0xc000-0xc01f]
[ 0.320082] pci 0000:00:1d.3: System wakeup disabled by ACPI
[ 0.320192] pci 0000:00:1d.7: reg 0x10: [mem 0xf9eff800-0xf9effbff]
[ 0.320286] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.320351] pci 0000:00:1d.7: System wakeup disabled by ACPI
[ 0.320411] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.320534] pci 0000:00:1e.0: System wakeup disabled by ACPI
[ 0.320598] pci 0000:00:1f.0: [8086:2916] type 00 class 0x060100
[ 0.320680] pci 0000:00:1f.0: quirk: [io 0x0800-0x087f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.320685] pci 0000:00:1f.0: quirk: [io 0x0480-0x04bf] claimed by ICH6 GPIO
[ 0.320689] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0a00 (mask 00ff)
[ 0.320836] pci 0000:00:1f.2: [8086:2822] type 00 class 0x010400
[ 0.320857] pci 0000:00:1f.2: reg 0x10: [io 0xc880-0xc887]
[ 0.320867] pci 0000:00:1f.2: reg 0x14: [io 0xc800-0xc803]
[ 0.320877] pci 0000:00:1f.2: reg 0x18: [io 0xc480-0xc487]
[ 0.320888] pci 0000:00:1f.2: reg 0x1c: [io 0xc400-0xc403]
[ 0.320898] pci 0000:00:1f.2: reg 0x20: [io 0xc080-0xc09f]
[ 0.320908] pci 0000:00:1f.2: reg 0x24: [mem 0xf9eff000-0xf9eff7ff]
[ 0.320966] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.321090] pci 0000:00:1f.3: [8086:2930] type 00 class 0x0c0500
[ 0.321109] pci 0000:00:1f.3: reg 0x10: [mem 0xf9effc00-0xf9effcff 64bit]
[ 0.321136] pci 0000:00:1f.3: reg 0x20: [io 0x0400-0x041f]
[ 0.321316] pci 0000:04:00.0: [10de:06e0] type 00 class 0x030000
[ 0.321328] pci 0000:04:00.0: reg 0x10: [mem 0xfd000000-0xfdffffff]
[ 0.321339] pci 0000:04:00.0: reg 0x14: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.321350] pci 0000:04:00.0: reg 0x1c: [mem 0xfa000000-0xfbffffff 64bit]
[ 0.321358] pci 0000:04:00.0: reg 0x24: [io 0xdc00-0xdc7f]
[ 0.321366] pci 0000:04:00.0: reg 0x30: [mem 0xfeae0000-0xfeafffff pref]
[ 0.321478] pci 0000:00:01.0: PCI bridge to [bus 04]
[ 0.321482] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.321485] pci 0000:00:01.0: bridge window [mem 0xfa000000-0xfeafffff]
[ 0.321489] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.321551] pci 0000:00:1c.0: PCI bridge to [bus 03]
[ 0.321687] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.321757] pci 0000:02:00.0: reg 0x10: [io 0xe800-0xe8ff]
[ 0.321863] pci 0000:02:00.0: reg 0x18: [mem 0xfebff000-0xfebfffff 64bit]
[ 0.321931] pci 0000:02:00.0: reg 0x20: [mem 0xf8ff0000-0xf8ffffff 64bit pref]
[ 0.321971] pci 0000:02:00.0: reg 0x30: [mem 0xfebc0000-0xfebdffff pref]
[ 0.322253] pci 0000:02:00.0: supports D1 D2
[ 0.322255] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.322467] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.322472] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.322476] pci 0000:00:1c.2: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.322483] pci 0000:00:1c.2: bridge window [mem 0xf8f00000-0xf8ffffff 64bit pref]
[ 0.322550] pci 0000:01:05.0: [11c1:5811] type 00 class 0x0c0010
[ 0.322567] pci 0000:01:05.0: reg 0x10: [mem 0xf9fff000-0xf9ffffff]
[ 0.322650] pci 0000:01:05.0: supports D1 D2
[ 0.322652] pci 0000:01:05.0: PME# supported from D0 D1 D2 D3hot
[ 0.322749] pci 0000:00:1e.0: PCI bridge to [bus 01] (subtractive decode)
[ 0.322756] pci 0000:00:1e.0: bridge window [mem 0xf9f00000-0xf9ffffff]
[ 0.322763] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.322765] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.322767] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.322769] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xdfffffff window] (subtractive decode)
[ 0.322771] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xffffffff window] (subtractive decode)
[ 0.322795] pci_bus 0000:00: on NUMA node 0
[ 0.323548] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.323620] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.323690] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.323761] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[ 0.323831] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 *4 5 6 7 10 11 12 14 15)
[ 0.323900] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 0.323970] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.324050] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 *14 15)
[ 0.324129] ACPI: Enabled 2 GPEs in block 00 to 3F
[ 0.324269] vgaarb: setting as boot device: PCI:0000:04:00.0
[ 0.324269] vgaarb: device added: PCI:0000:04:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.324269] vgaarb: loaded
[ 0.324269] vgaarb: bridge control possible 0000:04:00.0
[ 0.324269] PCI: Using ACPI for IRQ routing
[ 0.333210] PCI: pci_cache_line_size set to 64 bytes
[ 0.333279] e820: reserve RAM buffer [mem 0x0009b000-0x0009ffff]
[ 0.333281] e820: reserve RAM buffer [mem 0x7ffa0000-0x7fffffff]
[ 0.333449] HPET: 4 timers in total, 0 timers will be used for per-cpu timer
[ 0.333449] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.333449] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[ 0.336036] clocksource: Switched to clocksource hpet
[ 0.351033] VFS: Disk quotas dquot_6.6.0
[ 0.351058] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.351177] pnp: PnP ACPI init
[ 0.351293] system 00:00: [mem 0xfed14000-0xfed19fff] has been reserved
[ 0.351298] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.351385] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.351683] system 00:02: [io 0x04d0-0x04d1] has been reserved
[ 0.351686] system 00:02: [io 0x0800-0x087f] has been reserved
[ 0.351689] system 00:02: [io 0x0480-0x04bf] has been reserved
[ 0.351691] system 00:02: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.351694] system 00:02: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.351698] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.351839] system 00:03: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.351842] system 00:03: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.351846] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.351927] pnp 00:04: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.352091] system 00:05: [io 0x0a00-0x0adf] has been reserved
[ 0.352095] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.352201] system 00:06: [mem 0xffc00000-0xffefffff] has been reserved
[ 0.352206] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.352301] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.352305] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.352529] system 00:08: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.352532] system 00:08: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.352534] system 00:08: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.352537] system 00:08: [mem 0x00100000-0x7fffffff] could not be reserved
[ 0.352541] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.352694] pnp: PnP ACPI: found 9 devices
[ 0.352698] PnPBIOS: Disabled
[ 0.392160] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.392181] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 03] add_size 1000
[ 0.392185] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[ 0.392188] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 03] add_size 200000 add_align 100000
[ 0.392209] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.392212] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.392214] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.392217] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.392219] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.392221] pci 0000:00:1c.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.392227] pci 0000:00:1c.0: BAR 14: assigned [mem 0x80000000-0x801fffff]
[ 0.392234] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref]
[ 0.392237] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.392240] pci 0000:00:01.0: PCI bridge to [bus 04]
[ 0.392243] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.392247] pci 0000:00:01.0: bridge window [mem 0xfa000000-0xfeafffff]
[ 0.392250] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.392255] pci 0000:00:1c.0: PCI bridge to [bus 03]
[ 0.392258] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.392263] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff]
[ 0.392267] pci 0000:00:1c.0: bridge window [mem 0x80200000-0x803fffff 64bit pref]
[ 0.392275] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.392278] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.392283] pci 0000:00:1c.2: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.392287] pci 0000:00:1c.2: bridge window [mem 0xf8f00000-0xf8ffffff 64bit pref]
[ 0.392295] pci 0000:00:1e.0: PCI bridge to [bus 01]
[ 0.392300] pci 0000:00:1e.0: bridge window [mem 0xf9f00000-0xf9ffffff]
[ 0.392310] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.392312] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.392314] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.392316] pci_bus 0000:00: resource 7 [mem 0x80000000-0xdfffffff window]
[ 0.392318] pci_bus 0000:00: resource 8 [mem 0xf0000000-0xffffffff window]
[ 0.392320] pci_bus 0000:04: resource 0 [io 0xd000-0xdfff]
[ 0.392322] pci_bus 0000:04: resource 1 [mem 0xfa000000-0xfeafffff]
[ 0.392324] pci_bus 0000:04: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.392326] pci_bus 0000:03: resource 0 [io 0x1000-0x1fff]
[ 0.392328] pci_bus 0000:03: resource 1 [mem 0x80000000-0x801fffff]
[ 0.392330] pci_bus 0000:03: resource 2 [mem 0x80200000-0x803fffff 64bit pref]
[ 0.392332] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.392334] pci_bus 0000:02: resource 1 [mem 0xfeb00000-0xfebfffff]
[ 0.392336] pci_bus 0000:02: resource 2 [mem 0xf8f00000-0xf8ffffff 64bit pref]
[ 0.392338] pci_bus 0000:01: resource 1 [mem 0xf9f00000-0xf9ffffff]
[ 0.392340] pci_bus 0000:01: resource 4 [io 0x0000-0x0cf7 window]
[ 0.392342] pci_bus 0000:01: resource 5 [io 0x0d00-0xffff window]
[ 0.392344] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.392346] pci_bus 0000:01: resource 7 [mem 0x80000000-0xdfffffff window]
[ 0.392348] pci_bus 0000:01: resource 8 [mem 0xf0000000-0xffffffff window]
[ 0.392429] NET: Registered protocol family 2
[ 0.392625] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.392645] TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
[ 0.392735] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.392766] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.392781] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.392854] NET: Registered protocol family 1
[ 0.394406] pci 0000:04:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.394418] PCI: CLS 32 bytes, default 64
[ 0.394487] Unpacking initramfs...
[ 0.839763] Freeing initrd memory: 22668K
[ 0.840508] audit: initializing netlink subsys (disabled)
[ 0.840541] audit: type=2000 audit(1561049063.840:1): initialized
[ 0.841156] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.844070] zbud: loaded
[ 0.845407] bounce: pool size: 64 pages
[ 0.845455] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.845522] io scheduler noop registered
[ 0.845523] io scheduler deadline registered
[ 0.845580] io scheduler cfq registered (default)
[ 0.845931] pcieport 0000:00:1c.0: enabling device (0104 -> 0107)
[ 0.846375] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.846384] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.846404] intel_idle: does not run on family 6 model 15
[ 0.846623] GHES: HEST is not enabled!
[ 0.846696] isapnp: Scanning for PnP cards...
[ 1.200038] isapnp: No Plug & Play device found
[ 1.200123] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.200767] Linux agpgart interface v0.103
[ 1.201588] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.201589] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.202360] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.202572] mousedev: PS/2 mouse device common for all mice
[ 1.202630] rtc_cmos 00:01: RTC can wake from S4
[ 1.202777] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.202869] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.203758] NET: Registered protocol family 10
[ 1.204212] mip6: Mobile IPv6
[ 1.204216] NET: Registered protocol family 17
[ 1.204221] mpls_gso: MPLS GSO support
[ 1.204534] microcode: sig=0x6fb, pf=0x10, revision=0xba
[ 1.204606] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.204610] Using IPI No-Shortcut mode
[ 1.204819] registered taskstats version 1
[ 1.204846] zswap: loaded using pool lzo/zbud
[ 1.204898] ima: No TPM chip found, activating TPM-bypass!
[ 1.204900] ima: Allocated hash algorithm: sha256
[ 1.205334] rtc_cmos 00:01: setting system clock to 2019-06-20 16:44:25 UTC (1561049065)
[ 1.205389] PM: Hibernation image not present or could not be loaded.
[ 1.205820] Freeing unused kernel memory: 1060K
[ 1.205946] Write protecting the kernel text: 6040k
[ 1.206055] Write protecting the kernel read-only data: 1760k
[ 1.206056] NX-protecting the kernel data: 4200k
[ 1.206327] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.221654] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.225587] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.225686] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.226893] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.266230] ACPI: bus type USB registered
[ 1.266270] usbcore: registered new interface driver usbfs
[ 1.266288] usbcore: registered new interface driver hub
[ 1.266335] usbcore: registered new device driver usb
[ 1.270675] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.281207] ehci-pci: EHCI PCI platform driver
[ 1.281849] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 1.281995] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 1.282009] ehci-pci 0000:00:1a.7: debug port 1
[ 1.285897] ehci-pci 0000:00:1a.7: cache line size of 32 is not supported
[ 1.285983] ehci-pci 0000:00:1a.7: irq 18, io mem 0xf9efec00
[ 1.286311] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.289101] SCSI subsystem initialized
[ 1.294908] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.294918] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 1.295952] r8169 0000:02:00.0 eth0: RTL8168c/8111c at 0xf8214000, 00:23:54:49:59:7d, XID 1c4000c0 IRQ 27
[ 1.295956] r8169 0000:02:00.0 eth0: jumbo features [frames: 6128 bytes, tx checksumming: ko]
[ 1.300089] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.300188] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.300190] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.300192] usb usb1: Product: EHCI Host Controller
[ 1.300194] usb usb1: Manufacturer: Linux 4.9.0-8-rt-686-pae ehci_hcd
[ 1.300196] usb usb1: SerialNumber: 0000:00:1a.7
[ 1.300435] hub 1-0:1.0: USB hub found
[ 1.300449] hub 1-0:1.0: 4 ports detected
[ 1.301323] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.301332] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 2
[ 1.301340] uhci_hcd 0000:00:1a.0: detected 2 ports
[ 1.301544] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000b400
[ 1.301627] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.301630] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.301632] usb usb2: Product: UHCI Host Controller
[ 1.301633] usb usb2: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.301635] usb usb2: SerialNumber: 0000:00:1a.0
[ 1.301820] hub 2-0:1.0: USB hub found
[ 1.301831] hub 2-0:1.0: 2 ports detected
[ 1.302198] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 1.302416] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.302423] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 3
[ 1.302435] ehci-pci 0000:00:1d.7: debug port 1
[ 1.306345] ehci-pci 0000:00:1d.7: cache line size of 32 is not supported
[ 1.306849] ehci-pci 0000:00:1d.7: irq 23, io mem 0xf9eff800
[ 1.315723] libata version 3.00 loaded.
[ 1.320475] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.320621] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.320624] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.320627] usb usb3: Product: EHCI Host Controller
[ 1.320630] usb usb3: Manufacturer: Linux 4.9.0-8-rt-686-pae ehci_hcd
[ 1.320632] usb usb3: SerialNumber: 0000:00:1d.7
[ 1.320849] hub 3-0:1.0: USB hub found
[ 1.320864] hub 3-0:1.0: 8 ports detected
[ 1.321370] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.321377] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 1.321386] uhci_hcd 0000:00:1a.1: detected 2 ports
[ 1.321459] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000b480
[ 1.321556] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.321560] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.321562] usb usb4: Product: UHCI Host Controller
[ 1.321565] usb usb4: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.321567] usb usb4: SerialNumber: 0000:00:1a.1
[ 1.322530] hub 4-0:1.0: USB hub found
[ 1.322541] hub 4-0:1.0: 2 ports detected
[ 1.325149] ahci 0000:00:1f.2: version 3.0
[ 1.325454] ahci 0000:00:1f.2: controller can't do SNTF, turning off CAP_SNTF
[ 1.326001] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[ 1.326051] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl RAID mode
[ 1.326054] ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part ccc ems sxs
[ 1.360096] firewire_ohci 0000:01:05.0: added OHCI v1.0 device as card 0, 8 IR + 8 IT contexts, quirks 0x0
[ 1.385226] scsi host0: ahci
[ 1.385435] scsi host1: ahci
[ 1.385632] scsi host2: ahci
[ 1.385822] scsi host3: ahci
[ 1.386011] scsi host4: ahci
[ 1.386197] scsi host5: ahci
[ 1.386288] ata1: SATA max UDMA/133 abar m2048@0xf9eff000 port 0xf9eff100 irq 28
[ 1.386291] ata2: SATA max UDMA/133 abar m2048@0xf9eff000 port 0xf9eff180 irq 28
[ 1.386293] ata3: SATA max UDMA/133 abar m2048@0xf9eff000 port 0xf9eff200 irq 28
[ 1.386295] ata4: SATA max UDMA/133 abar m2048@0xf9eff000 port 0xf9eff280 irq 28
[ 1.386298] ata5: SATA max UDMA/133 abar m2048@0xf9eff000 port 0xf9eff300 irq 28
[ 1.386300] ata6: SATA max UDMA/133 abar m2048@0xf9eff000 port 0xf9eff380 irq 28
[ 1.386495] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.386509] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[ 1.386516] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 1.386586] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000b800
[ 1.386699] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.386702] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.386704] usb usb5: Product: UHCI Host Controller
[ 1.386706] usb usb5: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.386707] usb usb5: SerialNumber: 0000:00:1d.0
[ 1.386899] hub 5-0:1.0: USB hub found
[ 1.386913] hub 5-0:1.0: 2 ports detected
[ 1.387182] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.387189] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 1.387195] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 1.387286] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000b880
[ 1.387380] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.387383] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.387384] usb usb6: Product: UHCI Host Controller
[ 1.387386] usb usb6: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.387388] usb usb6: SerialNumber: 0000:00:1d.1
[ 1.387568] hub 6-0:1.0: USB hub found
[ 1.387581] hub 6-0:1.0: 2 ports detected
[ 1.387845] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.387855] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 1.387861] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 1.387931] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000bc00
[ 1.388080] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.388084] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.388087] usb usb7: Product: UHCI Host Controller
[ 1.388091] usb usb7: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.388094] usb usb7: SerialNumber: 0000:00:1d.2
[ 1.388358] hub 7-0:1.0: USB hub found
[ 1.388372] hub 7-0:1.0: 2 ports detected
[ 1.388632] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.388638] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 8
[ 1.388644] uhci_hcd 0000:00:1d.3: detected 2 ports
[ 1.388716] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000c000
[ 1.388849] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.388853] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.388856] usb usb8: Product: UHCI Host Controller
[ 1.388858] usb usb8: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.388861] usb usb8: SerialNumber: 0000:00:1d.3
[ 1.389096] hub 8-0:1.0: USB hub found
[ 1.389109] hub 8-0:1.0: 2 ports detected
[ 1.648035] usb 3-5: new high-speed USB device number 2 using ehci-pci
[ 1.698667] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.699397] ata1.00: ATA-8: ST3320813AS, HP21, max UDMA/100
[ 1.699401] ata1.00: 625142448 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 1.713338] ata1.00: configured for UDMA/100
[ 1.713613] scsi 0:0:0:0: Direct-Access ATA ST3320813AS HP21 PQ: 0 ANSI: 5
[ 1.856033] tsc: Refined TSC clocksource calibration: 2399.950 MHz
[ 1.856042] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2298086d749, max_idle_ns: 440795294037 ns
[ 1.871668] usb 3-5: New USB device found, idVendor=0bda, idProduct=0152
[ 1.871672] usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.871675] usb 3-5: Product: USB2.0-CRW
[ 1.871677] usb 3-5: Manufacturer: Generic
[ 1.871680] usb 3-5: SerialNumber: 20060413092100000
[ 1.875461] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.881992] usbcore: registered new interface driver usbhid
[ 1.881994] usb-storage 3-5:1.0: USB Mass Storage device detected
[ 1.881997] usbhid: USB HID core driver
[ 1.883337] hid-generic 0003:0BDA:0152.0001: hiddev0,hidraw0: USB HID v1.11 Device [Generic USB2.0-CRW] on usb-0000:00:1d.7-5/input1
[ 1.886141] scsi host6: usb-storage 3-5:1.0
[ 1.886288] usbcore: registered new interface driver usb-storage
[ 1.886774] usbcore: registered new interface driver uas
[ 1.888224] firewire_core 0000:01:05.0: created device fw0: GUID 001e8c00019480b3, S400
[ 2.082658] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.082878] ata2.00: ATAPI: ATAPI DVD A DH16A6L-C, ZHCD, max UDMA/100
[ 2.083619] ata2.00: configured for UDMA/100
[ 2.085770] scsi 1:0:0:0: CD-ROM ATAPI DVD A DH16A6L-C ZHCD PQ: 0 ANSI: 5
[ 2.128045] usb 8-2: new low-speed USB device number 2 using uhci_hcd
[ 2.318100] usb 8-2: New USB device found, idVendor=045e, idProduct=076c
[ 2.318104] usb 8-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.318107] usb 8-2: Product: Microsoft® Comfort Mouse 4500
[ 2.318109] usb 8-2: Manufacturer: Microsoft
[ 2.386236] input: Microsoft Microsoft® Comfort Mouse 4500 as /devices/pci0000:00/0000:00:1d.3/usb8/8-2/8-2:1.0/0003:045E:076C.0002/input/input1
[ 2.410840] ata3: SATA link down (SStatus 0 SControl 300)
[ 2.444232] microsoft 0003:045E:076C.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® Comfort Mouse 4500] on usb-0000:00:1d.3-2/input0
[ 2.722629] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.880136] clocksource: Switched to clocksource tsc
[ 2.917203] scsi 6:0:0:0: Direct-Access Generic- Compact Flash 1.00 PQ: 0 ANSI: 0 CCS
[ 2.922177] scsi 6:0:0:1: Direct-Access Generic- SM/xD-Picture 1.00 PQ: 0 ANSI: 0 CCS
[ 2.927181] scsi 6:0:0:2: Direct-Access Generic- SD/MMC 1.00 PQ: 0 ANSI: 0 CCS
[ 2.932182] scsi 6:0:0:3: Direct-Access Generic- MS/MS-Pro 1.00 PQ: 0 ANSI: 0 CCS
[ 2.959095] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 2.959579] sd 0:0:0:0: [sda] Write Protect is off
[ 2.959582] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.959618] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.963790] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 2.964662] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[ 2.965539] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[ 2.969041] sd 6:0:0:3: [sde] Attached SCSI removable disk
[ 2.974641] random: fast init done
[ 2.984090] sda: sda1 sda2 < sda5 >
[ 2.984812] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.034852] ata5: SATA link down (SStatus 0 SControl 300)
[ 3.346499] ata6: SATA link down (SStatus 0 SControl 300)
[ 3.370613] sr 1:0:0:0: [sr0] scsi3-mmc drive: 40x/12x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.370614] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.370990] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 3.838254] PM: Starting manual resume from disk
[ 3.838258] PM: Hibernation image partition 8:5 present
[ 3.838260] PM: Looking for hibernation image.
[ 3.838638] PM: Image not found (code -22)
[ 3.838640] PM: Hibernation image not present or could not be loaded.
[ 4.315006] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.578626] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.784357] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 5.784562] systemd[1]: Detected architecture x86.
[ 5.802929] systemd[1]: Set hostname to <precix510>.
[ 6.096550] random: crng init done
[ 6.096554] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.765040] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[ 6.765068] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[ 6.765896] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.765969] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.766021] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.766069] systemd[1]: Listening on udev Kernel Socket.
[ 6.766294] systemd[1]: Created slice System Slice.
[ 7.151252] lp: driver loaded but no devices found
[ 7.284701] ppdev: user-space parallel port driver
[ 7.412679] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 7.575505] systemd-journald[247]: Received request to flush runtime journal from PID 1
[ 8.753662] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 8.753668] ACPI: Power Button [PWRB]
[ 8.753753] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 8.753756] ACPI: Power Button [PWRF]
[ 8.778941] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 8.891483] snd_hda_codec_realtek hdaudioC0D0: ALC1200: SKU not ready 0x411111f0
[ 8.892366] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC1200: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[ 8.892369] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 8.892371] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 8.892373] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 8.892375] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x1e
[ 8.892377] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 8.892379] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 8.892381] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 8.892383] snd_hda_codec_realtek hdaudioC0D0: Line=0x1c
[ 8.892385] snd_hda_codec_realtek hdaudioC0D0: dig-in=0x1f
[ 8.909640] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000800-0x000000000000084F (\PMRG) (20160831/utaddress-247)
[ 8.909650] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 8.909702] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 8.913577] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4
[ 8.914707] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 8.914762] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 8.914816] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 8.914868] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 8.914921] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 8.914975] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 8.915026] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 8.915080] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 8.984806] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 8.984874] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 8.984937] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 8.984999] sd 6:0:0:1: Attached scsi generic sg3 type 0
[ 8.985062] sd 6:0:0:2: Attached scsi generic sg4 type 0
[ 8.985125] sd 6:0:0:3: Attached scsi generic sg5 type 0
[ 9.184137] iTCO_vendor_support: vendor-support=0
[ 9.301339] input: PC Speaker as /devices/platform/pcspkr/input/input13
[ 9.344294] [drm] Initialized
[ 9.476207] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 9.476257] iTCO_wdt: Found a ICH9R TCO device (Version=2, TCOBASE=0x0860)
[ 9.476411] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 9.682815] kvm: disabled by bios
[ 9.900682] coretemp coretemp.0: Using relative temperature scale!
[ 9.900700] coretemp coretemp.0: Using relative temperature scale!
[ 9.900718] coretemp coretemp.0: Using relative temperature scale!
[ 9.900737] coretemp coretemp.0: Using relative temperature scale!
[ 9.914646] intel_powerclamp: No package C-state available
[ 9.952551] wmi: Mapper loaded
[ 10.377593] nouveau 0000:04:00.0: NVIDIA G98 (298000a2)
[ 10.482571] Adding 2095100k swap on /dev/sda5. Priority:-1 extents:1 across:2095100k FS
[ 10.494522] nouveau 0000:04:00.0: bios: version 62.98.29.00.13
[ 10.515323] nouveau 0000:04:00.0: bios: M0203T not found
[ 10.515326] nouveau 0000:04:00.0: bios: M0203E not matched!
[ 10.515328] nouveau 0000:04:00.0: fb: 256 MiB DDR2
[ 11.816141] [TTM] Zone kernel: Available graphics memory: 438982 kiB
[ 11.816144] [TTM] Zone highmem: Available graphics memory: 1031690 kiB
[ 11.816146] [TTM] Initializing pool allocator
[ 11.816159] [TTM] Initializing DMA pool allocator
[ 11.816183] nouveau 0000:04:00.0: DRM: VRAM: 256 MiB
[ 11.816185] nouveau 0000:04:00.0: DRM: GART: 1048576 MiB
[ 11.816190] nouveau 0000:04:00.0: DRM: TMDS table version 2.0
[ 11.816192] nouveau 0000:04:00.0: DRM: DCB version 4.0
[ 11.816195] nouveau 0000:04:00.0: DRM: DCB outp 00: 02000300 00000028
[ 11.816198] nouveau 0000:04:00.0: DRM: DCB outp 01: 01000302 00020030
[ 11.816200] nouveau 0000:04:00.0: DRM: DCB outp 02: 02011312 00020010
[ 11.816202] nouveau 0000:04:00.0: DRM: DCB conn 00: 00002030
[ 11.816204] nouveau 0000:04:00.0: DRM: DCB conn 01: 00001161
[ 11.816207] nouveau 0000:04:00.0: DRM: DCB conn 02: 00000362
[ 11.848729] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 11.848731] [drm] Driver supports precise vblank timestamp query.
[ 11.899533] nouveau 0000:04:00.0: DRM: MM: using M2MF for buffer copies
[ 11.954021] nouveau 0000:04:00.0: DRM: allocated 1360x768 fb: 0x50000, bo f6123400
[ 11.954136] fbcon: nouveaufb (fb0) is primary device
[ 12.058043] Console: switching to colour frame buffer device 170x48
[ 12.059341] nouveau 0000:04:00.0: fb0: nouveaufb frame buffer device
[ 12.092051] [drm] Initialized nouveau 1.3.1 20120801 for 0000:04:00.0 on minor 0
[ 15.688133] r8169 0000:02:00.0 eth0: link down
[ 15.688252] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6941.387419] r8169 0000:02:00.0 eth0: link up
[ 6941.387433] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 6951.178204] r8169 0000:02:00.0 eth0: link down
[ 6958.164060] r8169 0000:02:00.0 eth0: link up
[ 6958.501189] r8169 0000:02:00.0 eth0: link down
[ 7177.064135] r8169 0000:02:00.0 eth0: link up
[ 7737.704091] r8169 0000:02:00.0 eth0: link down
[89164.643444] r8169 0000:02:00.0 eth0: link up
[89180.277062] r8169 0000:02:00.0 eth0: link down
[89182.364122] r8169 0000:02:00.0 eth0: link up
[90867.962867] r8169 0000:02:00.0 eth0: link down
[90872.546754] r8169 0000:02:00.0 eth0: link up
[90985.859605] r8169 0000:02:00.0 eth0: link down
[90990.027135] r8169 0000:02:00.0 eth0: link up
[90990.521210] r8169 0000:02:00.0 eth0: link down
[90996.894964] r8169 0000:02:00.0 eth0: link up
[90998.052455] r8169 0000:02:00.0 eth0: link down
[91001.372150] r8169 0000:02:00.0 eth0: link up
[91006.910986] r8169 0000:02:00.0 eth0: link down
[91008.712133] r8169 0000:02:00.0 eth0: link up
[91011.300622] r8169 0000:02:00.0 eth0: link down
[91013.094942] r8169 0000:02:00.0 eth0: link up
[91016.019487] r8169 0000:02:00.0 eth0: link down
[91021.441359] r8169 0000:02:00.0 eth0: link up
[91049.100169] r8169 0000:02:00.0 eth0: link down
[91050.968567] r8169 0000:02:00.0 eth0: link up
[91054.920989] r8169 0000:02:00.0 eth0: link down
[91056.777549] r8169 0000:02:00.0 eth0: link up
[91057.999686] r8169 0000:02:00.0 eth0: link down
[91059.702921] r8169 0000:02:00.0 eth0: link up
[91076.634952] r8169 0000:02:00.0 eth0: link down
[91226.628359] r8169 0000:02:00.0 eth0: link up
[91768.670533] perf: interrupt took too long (2519 > 2500), lowering kernel.perf_event_max_sample_rate to 79250
[93964.759438] r8169 0000:02:00.0 eth0: link down
[133900.705558] perf: interrupt took too long (3155 > 3148), lowering kernel.perf_event_max_sample_rate to 63250
[255234.882817] perf: interrupt took too long (3984 > 3943), lowering kernel.perf_event_max_sample_rate to 50000
[262618.700051] r8169 0000:02:00.0 eth0: link up
[262637.195476] r8169 0000:02:00.0 eth0: link down
[262897.324797] r8169 0000:02:00.0 eth0: link up
[265362.409786] r8169 0000:02:00.0 eth0: link down
[442793.524032] usb 3-2: new high-speed USB device number 4 using ehci-pci
[442793.672851] usb 3-2: New USB device found, idVendor=0781, idProduct=557d
[442793.672855] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[442793.672858] usb 3-2: Product: Cruzer Force
[442793.672861] usb 3-2: Manufacturer: SanDisk
[442793.672863] usb 3-2: SerialNumber: 4C530001101009105071
[442793.673314] usb-storage 3-2:1.0: USB Mass Storage device detected
[442793.673448] scsi host7: usb-storage 3-2:1.0
[442794.689127] scsi 7:0:0:0: Direct-Access SanDisk Cruzer Force 1.00 PQ: 0 ANSI: 6
[442794.712467] sd 7:0:0:0: Attached scsi generic sg6 type 0
[442794.713614] sd 7:0:0:0: [sdf] 123174912 512-byte logical blocks: (63.1 GB/58.7 GiB)
[442794.715107] sd 7:0:0:0: [sdf] Write Protect is off
[442794.715111] sd 7:0:0:0: [sdf] Mode Sense: 43 00 00 00
[442794.717188] sd 7:0:0:0: [sdf] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[442794.945634] sdf: sdf1
[442794.948980] sd 7:0:0:0: [sdf] Attached SCSI removable disk
[442880.320496] r8169 0000:02:00.0 eth0: link upHAL file:
# Generated by PNCconf at Sun Jun 23 12:51:13 2019
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=1 num_pwmgens=0 num_stepgens=0 sserial_port_0=000000"
setp hm2_7i92.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf hm2_7i92.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_7i92.0.write servo-thread
setp hm2_7i92.0.dpll.01.timer-us -50
# external output signals
# external input signals
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# ---PWM Generator signals/setup---
setp hm2_7i92.0.7i77.0.4.analogout0-scalemax [AXIS_0]OUTPUT_SCALE
setp hm2_7i92.0.7i77.0.4.analogout0-minlim [AXIS_0]OUTPUT_MIN_LIMIT
setp hm2_7i92.0.7i77.0.4.analogout0-maxlim [AXIS_0]OUTPUT_MAX_LIMIT
net x-output => hm2_7i92.0.7i77.0.4.analogout0
net x-pos-cmd axis.0.motor-pos-cmd
net x-enable axis.0.amp-enable-out
# enable _all_ sserial pwmgens
net x-enable hm2_7i92.0.7i77.0.4.analogena
setp hm2_7i92.0.encoder.00.counter-mode 0
setp hm2_7i92.0.encoder.00.filter 1
setp hm2_7i92.0.encoder.00.index-invert 0
setp hm2_7i92.0.encoder.00.index-mask 0
setp hm2_7i92.0.encoder.00.index-mask-invert 0
setp hm2_7i92.0.encoder.00.scale [AXIS_0]ENCODER_SCALE
net x-pos-fb <= hm2_7i92.0.encoder.00.position
net x-vel-fb <= hm2_7i92.0.encoder.00.velocity
net x-pos-fb => axis.0.motor-pos-fb
net x-index-enable axis.0.index-enable <=> hm2_7i92.0.encoder.00.index-enable
net x-pos-rawcounts <= hm2_7i92.0.encoder.00.rawcounts
# ---setup home / limit switch signals---
net x-home-sw => axis.0.home-sw-in
net x-neg-limit => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp pid.y.error-previous-target true
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp hm2_7i92.0.7i77.0.4.analogout1-scalemax [AXIS_1]OUTPUT_SCALE
setp hm2_7i92.0.7i77.0.4.analogout1-minlim [AXIS_1]OUTPUT_MIN_LIMIT
setp hm2_7i92.0.7i77.0.4.analogout1-maxlim [AXIS_1]OUTPUT_MAX_LIMIT
net y-output => hm2_7i92.0.7i77.0.4.analogout1
net y-pos-cmd axis.1.motor-pos-cmd
net y-enable axis.1.amp-enable-out
setp hm2_7i92.0.encoder.01.counter-mode 0
setp hm2_7i92.0.encoder.01.filter 1
setp hm2_7i92.0.encoder.01.index-invert 0
setp hm2_7i92.0.encoder.01.index-mask 0
setp hm2_7i92.0.encoder.01.index-mask-invert 0
setp hm2_7i92.0.encoder.01.scale [AXIS_1]ENCODER_SCALE
net y-pos-fb <= hm2_7i92.0.encoder.01.position
net y-vel-fb <= hm2_7i92.0.encoder.01.velocity
net y-pos-fb => axis.1.motor-pos-fb
net y-index-enable axis.1.index-enable <=> hm2_7i92.0.encoder.01.index-enable
net y-pos-rawcounts <= hm2_7i92.0.encoder.01.rawcounts
net y-home-sw => axis.1.home-sw-in
net y-neg-limit => axis.1.neg-lim-sw-in
net y-pos-limit => axis.1.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_7i92.0.7i77.0.4.analogout2-scalemax [AXIS_2]OUTPUT_SCALE
setp hm2_7i92.0.7i77.0.4.analogout2-minlim [AXIS_2]OUTPUT_MIN_LIMIT
setp hm2_7i92.0.7i77.0.4.analogout2-maxlim [AXIS_2]OUTPUT_MAX_LIMIT
net z-output => hm2_7i92.0.7i77.0.4.analogout2
net z-pos-cmd axis.2.motor-pos-cmd
net z-enable axis.2.amp-enable-out
setp hm2_7i92.0.encoder.02.counter-mode 0
setp hm2_7i92.0.encoder.02.filter 1
setp hm2_7i92.0.encoder.02.index-invert 0
setp hm2_7i92.0.encoder.02.index-mask 0
setp hm2_7i92.0.encoder.02.index-mask-invert 0
setp hm2_7i92.0.encoder.02.scale [AXIS_2]ENCODER_SCALE
net z-pos-fb <= hm2_7i92.0.encoder.02.position
net z-vel-fb <= hm2_7i92.0.encoder.02.velocity
net z-pos-fb => axis.2.motor-pos-fb
net z-index-enable axis.2.index-enable <=> hm2_7i92.0.encoder.02.index-enable
net z-pos-rawcounts <= hm2_7i92.0.encoder.02.rawcounts
net z-home-sw => axis.2.home-sw-in
net z-neg-limit => axis.2.neg-lim-sw-in
net z-pos-limit => axis.2.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---toolchange signals for custom tool changer---
net tool-number <= iocontrol.0.tool-prep-number
net tool-change-request <= iocontrol.0.tool-change
net tool-change-confirmed => iocontrol.0.tool-changed
net tool-prepare-request <= iocontrol.0.tool-prepare
net tool-prepare-confirmed => iocontrol.0.tool-prepared
INI
[EMC]
MACHINE = precix5x10-20190624
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/user/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.016670
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_eth
# BOARD0=7i92
[HAL]
HALUI = halui
HALFILE = precix5x10-20190624.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.10
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 30.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
ENCODER_SCALE = 4000.0
OUTPUT_SCALE = 10.0
OUTPUT_MIN_LIMIT = -10.0
OUTPUT_MAX_LIMIT = 10.0
MIN_LIMIT = -0.001
MAX_LIMIT = 8.0
HOME_OFFSET = 0.0
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 1.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
OUTPUT_SCALE = 10.0
MIN_LIMIT = -0.001
MAX_LIMIT = 8.0
HOME_OFFSET = 0.0
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 1.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
OUTPUT_SCALE = 10.0
MIN_LIMIT = -4.0
MAX_LIMIT = 0.001
HOME_OFFSET = 0.0
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000Thanks for everyone's help!
Last edit: 26 Jun 2019 03:38 by randypetersen. Reason: added bit about RTM :)
26 Jun 2019 04:24 - 26 Jun 2019 04:39 #137860
So the actual error is this:
I dont think I have ever seen this error but as far as I can tell it related to not setting up
a static IP address for eth0
(man hm2_eth)
Edit:
For initial setup of analog drive systems, I would follow JTs guide here:
gnipsel.com/linuxcnc/tuning/servo.html
(man hm2_eth)
Edit:
Last edit: 26 Jun 2019 04:39 by PCW.
- randypetersen
- Thank you received: 15
26 Jun 2019 13:01 - 26 Jun 2019 13:01 #137896
by randypetersen
I thought I set up static IP for eth0 and since this computer is only connected to the Mesa 7i92 I just set it up as 192.168.1.100, that was with IPv4 though, don't usually mess with IPv6. Left the 7i92 as 192.168.1.121.
Thanks for the clarification, I will dig into that more thoroughly.
Oh, and I will check out that link too, thanks!!
Last edit: 26 Jun 2019 13:01 by randypetersen.
Time to create page: 0.275 seconds
