Pncconf for 6i25+7i76 on Stretch with 4.19.0-5-rt
08 Jul 2019 15:40 #138868 by manuano
Hello everybody,
First my questions:
1. Do I need to "install" firmware if I want to use the Mesacards? If hostmot2 is installed but my card numbers are not mentioned?
2. about Pncconf:
* does Boardname: "5i25-Internal Data" work for 6i25?
* is Firmeware: "7i76x2" the correct choice?
I'm reading through this Forum and all sources that i can get a hold of but just don't get it.
Thx for you patience in advance.
08 Jul 2019 15:49 #138871 by pl7i92
if you have orderd a plug and play set
you are up to go
7i76x2 is then installed you can check it
with connected 7i76 and powerd up
by typing
mesaflash --device 7i76 --readhmid
the pinout can be usefull to be in a file so
mesaflash --device 7i76 --readhmid > test.pin
  • Moderator
  • Moderator
08 Jul 2019 15:52 #138872 by tommylight
Replied by tommylight on topic Pncconf for 6i25+7i76 on Stretch with 4.19.0-5-rt
1 usually they come with preinstalled firmware, sometimes depending on what you want to use them for and how, you might need to install firmware. A single line in a terminal does that.
2 Yes, 5i25 and 6i25 are the same thing for different types of slots, PCI or PCI-E.
First check the firmware that is already pressent, might be the one you need. You can use the 7i76x2 or 7i76 with one 7i76. Cant remember the exact name.
Time to create page: 0.096 seconds
