LinuxCNC on RPI
7 years 3 months ago #140771 by scotta
Replied by scotta on topic LinuxCNC on RPI
Hardware currently is RPi 3B and 3B+. Would love to get my hands on a 4 as well to test the LinuxCNC component. spiPRU is based 100% on the BCM2835 driver library by Mike McCauley. Only using the SPI portion but in theory would also give GPIO access to rtapi. The RPi 4 might have a suitable base thread... maybe not..
7 years 3 months ago #140807 by pl7i92
Replied by pl7i92 on topic LinuxCNC on RPI
the rapberryCNc club saying it is significant slower then the 3B version on printer setup
7 years 2 months ago #141280 by Bari
Replied by Bari on topic LinuxCNC on RPI
Are they building a preemp_rt kernel? Which kernel version?
How much space can i save by using a Rpi to control this vs a PC?
imgur.com/ey5VtXu
Just kidding. The Rpi4 has an integrated Ethernet controller so you should be able to use Mesa Ethernet cards to control stepper, servos and galvos.
7 years 2 months ago #141297 by Hakan
Replied by Hakan on topic LinuxCNC on RPI
I have tested that. Works fine.
The following user(s) said Thank You: Mike_Eitel
7 years 2 months ago #141299 by Bari
Great work! Thank you!
We will work on getting the latest 3D graphics drivers and getting a Gentoo ISO going with latest Linuxcnc for the pi4.
Maybe someone else can work on Debian/Raspian packages for this.
The following user(s) said Thank You: spma
7 years 2 months ago - 7 years 2 months ago #141994 by andypugh
Replied by andypugh on topic LinuxCNC on RPI
I made an SD card image:
www.linuxcnc.org/dists/buster/2.8-uspace/
It's a run-in-place image, I couldn't figure out the packaging for Raspbian. This means you have to use
. ./linuxcnc-dev/scripts/rip-environment
linuxcnc
to start it. But then it works.
Last edit: 7 years 2 months ago by andypugh.
