LinuxCNC on RPI
- scotta
- Thank you received: 489
26 Jul 2019 23:32 #140699
by scotta
LinuxCNC on RPI was created by scotta
I have started to post details on how I have been getting LinuxCNC up and running on Raspberry Pi.
scottalford75.github.io/LinuxCNC-on-RPi/
I started with Raspbian but soon moved to Arch Linux due to the out of date OpenGL libraries. I will also start to put up details on my development of spiPRU that turns a cheap 32bit 3D Printer control board into a PRU (programmable real-time unit) connected to the RPi via the SPI bus. This then gives hard real-time step generators for the RPi similar to the Beaglebone inbuilt RPU’s.
For <$150 it’s now possible to have a LinuxCNC system!
Scott
Scott
- Thank you received: 1479
27 Jul 2019 03:13 #140712
Replied by Todd Zuercher on topic LinuxCNC on RPI
If making swarf for the least amount of money is your goal, dumpster dived PC is usually cheaper.
- scotta
27 Jul 2019 06:12 #140719
by scotta
Replied by scotta on topic LinuxCNC on RPI
Dollars not the main driver. Size and the challenge to get it to work.
Always need a challenge to keep the interest going.
- pl7i92
- Thank you received: 358
27 Jul 2019 06:16 #140720
by pl7i92
Replied by pl7i92 on topic LinuxCNC on RPI
what rasperian did you choose
- Thank you received: 7488
27 Jul 2019 09:11 #140729
Replied by tommylight on topic LinuxCNC on RPI
Arch linux !what rasperian did you choose
- pl7i92
27 Jul 2019 11:13 #140739
by pl7i92
my fault language problem the version of the hardware as there are many pi versions
- scotta
27 Jul 2019 21:16 #140771
by scotta
Hardware currently is RPi 3B and 3B+. Would love to get my hands on a 4 as well to test the LinuxCNC component. spiPRU is based 100% on the BCM2835 driver library by Mike McCauley. Only using the SPI portion but in theory would also give GPIO access to rtapi. The RPi 4 might have a suitable base thread... maybe not..
- pl7i92
28 Jul 2019 15:53 #140807
by pl7i92
the rapberryCNc club saying it is significant slower then the 3B version on printer setup
- Bari
- Thank you received: 234
03 Aug 2019 18:21 #141280
by Bari
Replied by Bari on topic LinuxCNC on RPI
Are they building a preemp_rt kernel? Which kernel version?
How much space can i save by using a Rpi to control this vs a PC?
imgur.com/ey5VtXu
Just kidding. The Rpi4 has an integrated Ethernet controller so you should be able to use Mesa Ethernet cards to control stepper, servos and galvos.
imgur.com/ey5VtXu
- Hakan
- Thank you received: 454
03 Aug 2019 21:13 #141297
by Hakan
Replied by Hakan on topic LinuxCNC on RPI
I have tested that. Works fine.
The following user(s) said Thank You: Mike_Eitel
Time to create page: 0.272 seconds
