LinuxCNC on RPI
- Bari
- Thank you received: 234
03 Aug 2019 21:44 #141299
by Bari
Replied by Bari on topic LinuxCNC on RPI
Great work! Thank you!
We will work on getting the latest 3D graphics drivers and getting a Gentoo ISO going with latest Linuxcnc for the pi4.
Maybe someone else can work on Debian/Raspian packages for this.
The following user(s) said Thank You: spma
12 Aug 2019 19:55 - 12 Aug 2019 19:55 #141994
Replied by andypugh on topic LinuxCNC on RPI
I made an SD card image:
www.linuxcnc.org/dists/buster/2.8-uspace/
It's a run-in-place image, I couldn't figure out the packaging for Raspbian. This means you have to use
. ./linuxcnc-dev/scripts/rip-environment
linuxcnc
to start it. But then it works.
linuxcnc
Last edit: 12 Aug 2019 19:55 by andypugh.
- Bari
15 Aug 2019 22:12 #142291
by Bari
We worked with the pi 3 and 4 a bit and stopped development. The HDMI was too flaky for 4K output. Not sure if we will ever return to using them.
15 Aug 2019 22:31 #142294
I don't think a CNC machine needs 4k, though.The HDMI was too flaky for 4K output. Not sure if we will ever return to using them.
- Bari
15 Aug 2019 23:50 #142298
by Bari
I do for some of mine so we end up having to support too many different boards. Maybe the Rock64 or Odroid quad core + mali or similar board that does a good job of having ports that conform to spec (SATA, PCIe, HDMI etc) vs more Broadcom junk.
Heatsink definitely required for the pi4.
- mjoconr
26 Dec 2020 11:46 #193219
by mjoconr
Replied by mjoconr on topic LinuxCNC on RPI
Very Cool, Scott. Will be very interested to see the code once released.
Time to create page: 0.335 seconds
